The Event Logging feature captures procedure-level information per subscriber. Upon completing a procedure, either successfully
or unsuccessfully, the SMF generates event data records capturing the details of procedures and events.
The EDR generation per procedure is configurable. For configuration details, see the Configure EDR Files for Generation section in this guide.
The following table lists the supported procedures and the corresponding IDs.
Table 4. Procedure List
Procedure |
Procedure-ID |
PDN-SESSION-CREATE or PDU-SESSION-CREATE |
PDN-SESSION-DELETE or PDU-SESSION-DELETE |
PDN-SESSION-MODIFY
Note |
The procedure IDs remain the same for both roaming and non-roaming procedures.
Further, the SMF captures event-level information per procedure. The following table provides details on the subscriber events
and the respective event IDs.
The events captured per procedure are configurable. For configuration details, see the Configure EDR Files for Generation section in this guide.
Table 5. Event IDs
EVENT |
EVENT-ID |
Applicability of Events to Procedures |
Create |
Release |
Modify |
N11SmContextCreateReq |
1287 |
Yes |
N11SmContextUpdateReq |
1290 |
Yes |
Yes |
Yes |
N11N1N2MessageTransferReq |
1299 |
Yes |
Yes |
Yes |
N11SmContextUpdateModifyReq |
1293 |
N11EbiAssignmentReq |
1302 |
Yes |
Yes |
N11SmContextReleaseReq |
1304 |
Yes |
N11SmContextStatusNotifyReq |
1310 |
Yes |
N11N1N2MessageTransfer FailNotificationReq |
1339 |
Yes |
Yes |
N4SessionModificationReq |
527 |
Yes |
Yes |
Yes |
N4SessionReleaseReq |
530 |
Yes |
Yes |
N4SessionEstablishmentReq |
524 |
Yes |
N7SmPolicyCreateReq |
3329 |
Yes |
N7SmPolicyDeleteReq |
3335 |
Yes |
Yes |
N7SmPolicyUpdateReq |
3332 |
Yes |
Yes |
N7SmPolicyTerminateNotifyReq |
3341 |
Yes |
N7SmPolicyUpdateNotifyReq |
3338 |
Yes |
N10UnsubscribeForNotificationReq |
1432 |
Yes |
N10SubscribeForNotificationReq |
1319 |
Yes |
N10RegistrationRequest |
1313 |
Yes |
N10SubscriptionFetchReq |
1316 |
Yes |
N10DeregistrationRequest |
1325 |
Yes |
Yes |
S5S8DeleteBearerCmd |
2066 |
N10UpdateNotifyReq |
1322 |
Yes |
Yes |
N40ChargingDataCreateReq |
1003 |
Yes |
N40ChargingDataUpdateReq |
1004 |
Yes |
N40ChargingDataReleaseReq |
1005 |
Yes |
N40ChargingNotificationReq |
3588 |
Yes |
Yes |
SecondaryAuthenReq |
2307 |
Yes |
S5S8CreateSessReq |
2051 |
Yes |
S5S8DeleteBearerReq |
2057 |
Yes |
S5S8DeleteSessReq |
2055 |
Yes |
RadiusCoaDisconnectReq |
2313 |
Yes |
RadiusAcctReq |
2309 |
Yes |
Yes |
Yes |
metaData |
1000 |
Yes |
Yes |
Yes |
N16PduSessionCreateReq |
1444 |
Yes |
N16VsmfPduSessionReleaseReq |
1471 |
Yes |
Yes |
N16PduSessionHsmfUpdateReq |
1447 |
Yes |
Yes |
Yes |
N16PduSessionHsmf UpdateReqClient |
1477 |
Yes |
Yes |
Yes |
N16VsmfPduSessionCreateReq |
1468 |
Yes |
N16PduSessionVsmfUpdateReq |
1451 |
Yes |
Yes |
Yes |
N16PduSessionNotifyReq |
1458 |
Yes |
N11SmContextRetrieveReq |
1307 |
Yes |
N16PduSessionVsmf UpdateReqClient |
1478 |
Yes |
Yes |
Yes |
N16PduSessionNotifyReqClient |
1488 |
Yes |
NInternalTxnMsg¹ |
1001 (xxxx) |
Yes |
Yes |
Yes |
NTimerNotificationMsg¹ |
1002 (xxxx) |
Yes |
Yes |
Yes |
¹ - SMF uses several internal messages for handling 3GPP call flows. These internal events are sent and received by SMF and
are not 3GPP compliant. NInternalTxnMsg and NTimerNotificationMsg are two generic event IDs defined to represent such internal
messages used by SMF. The xxxx in the Event IDs represent the original message type that is used by SMF internally for easy debuggability.
The SMF uses N40ChargingDataCreateReq, N40ChargingDataUpdateReq, and N40ChargingDataReleaseReq instead of N40ChargingDataReq
for PDU/PDN create and release.
The following tables list the detailed event record for the PDU Session Create, Modify, and Delete procedures.
Table 6. PDU Session Create Events
Number |
Attributes |
Name |
Presence |
Type |
Description |
TXN EDR
fields
M |
1 |
PROCEDURE
ID
EVENT-ID |
VERSION |
M |
Event=N11Sm Context CreateReq |
FIELD-COUNT |
M |
SUPI |
M |
IMEI/PEI |
M |
IMSI |
M |
MSISDN |
M |
GPSI |
M |
STATUS |
M |
STATUS-CODE |
O |
N1-REQ-PDU(PDN)- SESSION-TYPE |
O |
PduSessionType |
N1-REQ-SSC-MODE |
O |
CAUSE |
O |
N1-PCO |
O |
PCO |
N1-REQ-MSG-TYPE |
O |
N1N2MSG REQCONTENT |
PDU-SESSION- ESTB-REQUEST |
N2-REQ-MSG-TYPE |
O |
N1-RSP-MSG-TYPE |
O |
N1N2MSG RSPCONTENT |
N2-RSP-MSG-TYPE |
O |
N1-REQ-MAX- SUPP-FILTERS |
O |
N1-ALWAYS-ON |
O |
RAT-TYPE |
M |
S-NSSAI-REQUESTED |
O |
NSSAI |
GUAMI |
O |
REQUEST-TYPE |
O |
AN-TYPE |
O |
OLD-PDU-SESS-ID |
O |
N1-DNN/APN |
O |
SERVING-NFID |
O |
SERVING-PLMN |
O |
UNAUTH-SUPI |
O |
S-NSSAI-ASSIGNED |
O |
NSSAI |
UP-CONTEXT-STATE |
O |
N1-PDU-SESS-ID |
M |
NA |
2 |
PROCEDURE
ID
EVENT-ID |
VERSION |
M |
Client |
Event=N11Sm ContextUpdateReq |
FIELD-COUNT |
M |
STATUS |
M |
STATUS-CODE |
O |
SUPI |
M |
IMEI |
M |
IMSI |
M |
MSISDN |
M |
O |
N1-REQ-MSG-TYPE |
O |
pdu_session_ modification_request
pdu_sess_ modification_command
pdu_session_ release_req
pdu_session_ release_command
pdu_session_ release_complete
pdu_session_ modification_reject
pdu_session_ modification_complete
pdu_session_ release_reject
N2-REQ-MSG-TYPE |
O |
N1-RSP-MSG-TYPE |
O |
N2-RSP-MSG-TYPE |
O |
N1-PCO |
NA |
PCO |
N1-QOS-RULE |
O |
QOS-RULE |
N1-QOS-DESC |
O |
QOS-DESC |
CAUSE |
O |
N1-ALWAYS-ON |
O |
5G-SM-CAP |
O |
N1-RSP-MAX- SUPP-FILTERS |
O |
RAT-TYPE |
O |
UP-CONTEXT-STATE |
O |
HO-STATE |
O |
N1-BACKOFF-TIME |
NA |
N1-PDU-SESS-ID |
M |
N1-VGSM-RE- ATTEMPT-IND |
NA |
N1-RE-ATTEMPT-IND |
NA |
N1-SESS-AMBR |
O |
N1-CONG-RE- ATTEMPT-IND |
O |
N1-RSP-ALWAYS-ON |
NA |
3 |
PROCEDURE
ID
EVENT-ID |
VERSION |
M |
Event=N11N1N2 MessageTransferReq |
FIELD-COUNT |
M |
STATUS |
M |
STATUS-CODE |
O |
PDU-SESSION-TYPE |
M |
N1-REQ-MSG-TYPE |
O |
PDU-SESSION- ESTB-ACCEPT
PDU-SESSION- ESTB-REJECT etc.,
PDU_SESSION_ RELEASE_COMMAND
PDU_SESSION_ MODIFICATION_COMMAND
N2-REQ-MSG-TYPE |
N1-RSP-MSG-TYPE |
O |
N2-RSP-MSG-TYPE |
N1-PCO |
O |
PCO |
N1-QOS-RULE |
O |
QOS-RULE |
N1-QOS-DESC |
O |
QOS-DESC |
CAUSE |
O |
N1-ALWAYS-ON |
O |
N1-SESSION-AMBR |
O |
SESS-AMBR |
N1-PAA |
O |
PAA |
N1-S-NSSAI |
O |
NSSAI |
N1-PDU-SESS-ID |
N1-DNN/APN |
O |
N1-BACKOFF-TIME |
NA |
N1-REQ-SSC- MODE-SELECTED |
O |
N1-REQ-PDU(PDN)- SESSION-TYPE- SELECTED |
O |
N1-SSC- MODE- ALLOWED |
O |
N1-CONG- RE-ATTEMPT- IND |
O |
N1-RE-ATTEMPT-IND |
NA |
N1-RSP-AN-TYPE |
NA |
4 |
PROCEDURE
ID
EVENT-ID |
VERSION |
M |
Event=N7SmPolicyCreateReq
FIELD-COUNT |
M |
SUPI |
M |
IMEI/PEI |
M |
GPSI |
M |
STATUS |
M |
STATUS-CODE |
O |
O |
QOS-DESC |
O |
QOS-DESC |
SESSION-AMBR |
O |
SESS-AMBR |
CAUSE |
O |
5 |
PROCEDURE
ID
EVENT-ID |
VERSION |
M |
EVENT= N4SessionModificationReq
N7SmPolicyUpdateReq
SecondaryAuthenReq
N7SmPolicyDeleteReq
N11EbiAssignmentReq
N4SessionReleaseReq
RadiusAcctReq
N11SmContext RetrieveReq
FIELD-COUNT |
M |
STATUS |
M |
STATUS-CODE |
O |
PDU-SESSION-TYPE |
M |
CAUSE |
O |
6 |
PROCEDURE
ID
EVENT-ID |
VERSION |
M |
Event=S5S8CreateSessReq |
FIELD-COUNT |
M |
SUPI |
M |
IMEI/PEI |
M |
IMSI |
M |
MSISDN |
M |
GPSI |
M |
STATUS |
M |
STATUS-CODE |
O |
PCO |
O |
PCO |
PDU-SESSION-TYPE |
O |
SSC-MODE |
O |
DNN/APN |
O |
QOS-RULE |
O |
QOS-RULE |
QOS-DESC |
O |
QOS-DESC |
SESSION-AMBR |
O |
SESS-AMBR |
CAUSE |
O |
PAA |
O |
PAA |
S-NSSAI |
O |
NSSAI |
RAT-TYPE |
M |
7 |
PROCEDURE
ID
EVENT-ID |
VERSION |
M |
Event=N16Pdu SessionCreateReq N16VsmfPdu SessionCreateReq
FIELD-COUNT |
M |
SUPI |
O |
IMEI/PEI |
O |
GPSI |
O |
GUAMI |
O |
GUAMI |
REQUEST-TYPE |
M |
RequestType |
STATUS |
M |
STATUS-CODE |
O |
PDU/PDN- SESSION- TYPE |
O |
PduSessionType |
DNN/APN |
M |
RAT-TYPE |
O |
S-NSSAI |
O |
NSSAI |
SERVING-PLMN |
M |
PLMN-ID |
VSMF-ID |
M |
VCNTUNNEL-INFO |
M |
TUNNEL-INFO |
HO-PREP-INDICATION |
O |
PGW-S8-CFTEID |
O |
ALWAYS-ON-REQUESTED |
O |
UE-LOCATION |
O |
UE-LOCATION |
ROAMING-CHRG- PROF-REQUESTED |
O |
CHARGING- PROF |
ALWAYS-ON-GRANTED |
O |
SSC-MODE |
O |
HCNTUNNEL-INFO |
M |
TUNNEL-INFO |
SESSION-AMBR |
O |
SESS-AMBR |
UE-IPV4-ADDRESS |
O |
UE-IPV6-PREFIX |
O |
QOS-FLOWS- SETUP-LIST |
O |
QFS |
ROAMING-CHRG- PROF-SELECTED |
O |
CHARGING- PROF |
CAUSE |
O |
N1SM-CAUSE |
O |
UE-IPV6-INTERFACE-ID |
O |
N1-REQ-MSG-TYPE |
O |
PDU_SESSION_ ESTABLISHMENT_REQ |
N2-REQ-MSG-TYPE |
O |
N1-RSP-MSG-TYPE |
O |
PDU_SESSION_ ESTABLISHMENT_ACCEPT |
N2-RSP-MSG-TYPE |
O |
N1-PDU-SESS-ID |
N1-REQ-PDU(PDN) -SESSION-TYPE |
N1-REQ-SSC-MODE |
N1-PCO |
N1-ALWAYS-ON |
N1-REQ-PDU(PDN)- SESSION- TYPE-SELECTED |
N1-REQ-SSC- MODE- SELECTED |
N1-QOS-RULES |
N1-QOS-DESC |
N1-SESS-AMBR |
N1-REQ-ALWAYS-ON |
N1-REQ-SSC- MODE-ALLOWED |
N1-CONG- RE-ATTEMPT-IND |
N1-RSP- RE- ATTEMPT-IND |
N1-DNN/APN |
8 |
PROCEDURE
ID
EVENT-ID |
VERSION |
M |
Event= N16VsmfPdu SessionReleaseReq |
FIELD-COUNT |
M |
STATUS |
M |
STATUS-CODE |
O |
CAUSE |
O |
VGMM-CAUSE |
O |
NGAP-CAUSE |
O |
NGAP-CAUSE |
9 |
PROCEDURE
ID
EVENT-ID |
VERSION |
Event= N16PduSession VsmfUpdateReq
N16PduSession VsmfUpdateReqClient
FIELD-COUNT |
M |
STATUS |
STATUS-CODE |
REQUEST-INDICATION |
SESSION-AMBR |
ALWAYS-ON-GRANTED |
Request Indication |
CAUSE |
SESS-AMBR |
N1SM-CAUSE |
BACKOFF-TIMER |
N1-REQ-MSG-TYPE |
O |
PDU_SESSION_ MODIFICATION_ COMMAND
PDU_SESSION_ MODIFICATION_ COMMAND_REJECT
N1-RSP-MSG-TYPE |
PDU_SESSION_ MODIFICATION_ REJECT
N1-PCO |
O |
N1-QOS-RULE |
O |
N1-QOS-DESC |
O |
N1-PDU-SESS-ID |
O |
N1-ALWAYS-ON |
O |
N1-SESSION-AMBR |
O |
PROCEDURE
ID
EVENT-ID |
VERSION |
M |
Event=
N16PduSession HsmfUpdateReq
N16PduSession HsmfUpdateReqClient
FIELD-COUNT |
M |
STATUS |
M |
STATUS-CODE |
O |
IMEI/PEI |
O |
M |
VCNTUNNEL-INFO |
O |
TUNNEL-INFO |
SERVING-PLMN |
O |
AN-TYPE |
O |
AccessType |
RAT-TYPE |
O |
O |
CAUSE |
O |
VGMM-CAUSE |
O |
NGAP-CAUSE |
O |
NGAP -CAUSE |
ALWAYS-ON |
O |
EPS-IWK |
O |
AN-TYPE-CAN- BE-CHANGED |
O |
UE-LOCATION |
O |
UE- LOCATION |
N1-REQ-MSG-TYPE |
O |
PDU_SESSION_ MODIFICATION_REQUEST
PDU_SESSION_ RELEASE_REQUEST
N1-RSP-MSG-TYPE |
O |
N1-PDU-SESS-ID |
O |
N1-PCO |
O |
N1-RSP-MAX -SUPP-FILTERS |
O |
N1-REQ-ALWAYS-ON |
O |
N1-QOS-RULES |
O |
N1-QOS-DESC |
O |
11 |
PROCEDURE
ID
EVENT-ID=
1000
VERSION |
M |
Event=META DATA |
FIELD-COUNT |
M |
SUPI |
M |
IMEI/PEI |
M |
IMSI |
M |
MSISDN |
M |
GPSI |
SERVING-PLMN |
M |
UE-LOCATION |
M |
UE-LOCATION |
START-TIME |
M |
END-TIME |
M |
TRIGGER-NF |
M |
TRIGGER-EVENT |
M |
USERPLANE-STATUS |
M |
Userplane-status |
CAUSE |
M |
SGW-ID |
O |
DISCONNECT-REASON |
O |
STATUS |
M |
STATUS-CODE |
O |
DNN/APN |
M |
RAT-TYPE |
M |
UE-TIMEZONE |
M |
PDU-SESSION-TYPE |
M |
UE-PLMN |
M |
SUBSCRIBED-SESS- AMBR-UPLINK |
M |
SUBSCRIBED-SESS- AMBR-DOWNLINK |
M |
SUBSCRIBED-5QI |
M |
SUBSCRIBED-ARP |
M |
PAA |
M |
LOCAL-SEID |
M |
REMOTE-SEID |
M |
ROAMING-STATUS |
M |
CONNECTION-TIME |
M |
NA |
NA |
PDU-SESSION-ID |
O |
ALWAYS-ON |
O |
EPS-IWK |
O |
S-NSSAI |
O |
MAX-SUPP-FILTERS |
O |
SSC-MODE |
O |
UE-TYPE |
O |
LOCAL-CFTEID-TEID |
O |
LOCAL-CFTEID-IP |
O |
REMOTE-CFTEID-TEID |
O |
REMOTE-CFTEID-IP |
O |
VIRTUAL-DNN/APN |
O |
Table 7. PDU Session Modify Events
Attributes |
Name |
Presence |
Description |
TIME-
STAMP
EVENT-ID1=
1290
PROCEDURE-ID |
M |
EVENT-
LIST
VERSION |
M |
PduSessionModificationRequest (MESSAGE-ID=201)
5G-SM-CAP
MAX-SUPP-FILTERS
PCO
ALWAYS-ON
QOS-RULE
QOS-DESC
CAUSE
FIELD-COUNT |
M |
STATUS |
M |
STATUS-CODE |
O |
SUPI |
M |
IMEI |
M |
IMSI |
M |
MSISDN |
M |
O |
N1-REQ-MSG-TYPE |
O |
N1N2MSGREQCONTENT |
N2-REQ-MSG-TYPE |
O |
N1N2MSGREQCONTENT |
N1-RSP-MSG-TYPE |
O |
N1N2MSGRSPCONTENT |
N2-RSP-MSG-TYPE |
O |
N1N2MSGRSPCONTENT |
N1-PCO |
Not applicable* |
PCO |
N1-QOS-RULE |
O |
QOS-RULE |
N1-QOS-DESC |
O |
QOS-DESC |
CAUSE |
O |
N1-ALWAYS-ON |
O |
5G-SM-CAP |
O |
O |
RAT-TYPE |
O |
UP-CONTEXT-STATE |
O |
HO-STATE |
O |
N1-BACKOFF-TIME |
Not applicable* |
N1-PDU-SESS-ID |
M |
Not applicable* |
N1-RE-ATTEMPT-IND |
Not applicable* |
N1-SESS-AMBR |
O |
O |
N1-RSP- ALWAYS-ON |
O |
EVENT-ID3=
3332
PROCEDURE-ID |
M |
VERSION |
M |
FIELD-COUNT |
M |
STATUS |
M |
STATUS-CODE |
O |
SUPI |
M |
CAUSE |
O |
EVENT-ID4=
1299
PROCEDURE-ID |
M |
FIELD-COUNT |
M |
STATUS |
M |
STATUS-CODE |
O |
PDU-SESSION-TYPE |
M |
N1MSGREQTYPE |
O |
N1N2MSGREQCONTENT |
N2MSGREQTYPE |
O |
N1N2MSGREQCONTENT |
N1-PCO |
O |
PCO |
N1-QOS-RULE |
O |
QOS-RULE |
N1-QOS-DESC |
O |
QOS-DESC |
CAUSE |
O |
N1-ALWAYS-ON |
O |
N1-SESSION-AMBR |
O |
SESS-AMBR |
N1-PAA |
O |
PAA |
N1-S-NSSAI |
O |
NSSAI |
N1-PDU-SESS-ID |
N1-DNN/APN |
O |
N1-BACKOFF-TIME |
Not applicable* |
O |
N1-REQ-PDU(PDN)-SESSION-TYPE -SELECTED |
O |
N1-SSC- MODE-ALLOWED |
O |
O |
N!-RSP-RE- ATTEMPT-IND |
Not applicable* |
N1-RSP-AN-TYPE |
Not applicable* |
PROCEDURE
ID
EVENT-ID |
VERSION |
M |
Event=N16PduSessionHsmfUpdateReq,
N16PduSessionHsmfUpdateReqClient,
FIELD-COUNT |
M |
STATUS |
M |
STATUS-CODE |
O |
IMEI/PEI |
O |
REQUEST- INDICATION |
M |
RequestIndication |
VCNTUNNEL-INFO |
O |
TUNNEL-INFO |
SERVING-PLMN |
O |
AN-TYPE |
O |
AccessType |
RAT-TYPE |
O |
HO-PREP- INDICATION |
O |
CAUSE |
O |
VGMM-CAUSE |
O |
NGAP-CAUSE |
O |
NGAP-CAUSE |
ALWAYS-ON |
O |
EPS-IWK |
O |
AN-TYPE-CAN-BE-CHANGED |
O |
N1-PDU-SESS-ID |
O |
N1-PCO |
O |
N1-RSP-MAX -SUPP- FILTERS -REQUESTED |
O |
N1-ALWAYS-ON |
O |
N1-QOS-RULES |
O |
N1-QOS-DESC |
O |
PROCEDURE
ID
EVENT-ID |
VERSION |
Event=N16PduSessionVsmfUpdateReq
N16PduSessionVsmfUpdateReqClient
FIELD-COUNT |
M |
STATUS |
STATUS-CODE |
N1N2MSGREQCONTENT |
SESSION-AMBR |
N1N2MSGREQCONTENT |
ALWAYS-ON- GRANTED |
RequestIndication |
CAUSE |
SESS-AMBR |
N1SM-CAUSE |
BACKOFF-TIMER |
N1-REQ-MSG-TYPE |
O |
PDU_SESSION_MODIFICATION _COMMAND_REJECT
N1-RSP-MSG-TYPE |
PDU_SESSION_MODIFICATION_REJECT
N1-PCO |
O |
N1-QOS-RULE |
O |
N1-QOS-DESC |
O |
N1-PDU-SESS-ID |
O |
N1-ALWAYS-ON |
O |
N1-SESSION-AMBR |
O |
EVENT-ID |
PROCEDURE-ID |
M |
N11N1N2MessageTransferFailNotificationReq
RadiusAcctReq
N11EbiAssignmentReq
N7SmPolicyUpdateReq
VERSION |
M |
FIELD-COUNT |
M |
STATUS |
M |
STATUS-CODE |
O |
PDU-SESSION- TYPE |
O |
CAUSE |
O |
EVENT-ID1=
1000
PROCEDURE-ID |
M |
META-DATA |
VERSION |
M |
FIELD-COUNT |
M |
SUPI |
M |
IMEI |
M |
IMSI |
M |
MSISDN |
M |
GPSI |
M |
SERVING-PLMN |
M |
UE-LOCATION |
M |
START-TIME |
M |
END-TIME |
M |
TRIGGER-NF |
M |
TRIGGER-EVENT |
M |
USERPLANE-STATUS |
M |
SGW-ID |
O |
DISCONNECT- REASON |
Not applicable* |
STATUS |
M |
M |
SUBSCRIBED -SESS-AMBR - DOWNLINK |
M |
ALWAYS-ON |
O |
MAX-SUPP-FILTERS |
O |
LOCAL-CFTEID-TEID |
O |
LOCAL-CFTEID-IP |
O |
O |
REMOTE-CFTEID-IP |
O |
* - The field is not applicable to this procedure for the stated event. However, it still holds a place holder in the EDR.
Where it is not applicable, the field is left empty.
Table 8. PDU Session Delete Events
Number |
Attributes |
Name |
Presence |
Type |
Description |
TXN EDR fields |
M |
1 |
PROCEDURE ID |
EVENT-ID |
VERSION |
M |
EVENT=N11Sm ContextReleaseReq,
N40ChargingDataReleaseReq,
N7SmPolicyDeleteReq,
N10UnsubscribeForNotificationReq,
N10DeregistrationRequest,
N7SmPolicyTerminateNotifyReq,
N40ChargingNotificationReq,
RadiusCoaDisconnectReq,
RadiusAcctReq,
N10UpdateNotifyReq,
N11SmContextStatusNotifyReq,
FIELD-COUNT |
M |
STATUS |
M |
STATUS-CODE |
O |
PDU(PDN)-SESSION-TYPE |
M |
CAUSE |
O |
2 |
PROCEDURE ID |
EVENT-ID |
VERSION |
M |
Client |
Event=N11SmContextUpdateReq |
FIELD-COUNT |
M |
STATUS |
M |
STATUS-CODE |
O |
SUPI |
M |
IMEI |
M |
IMSI |
M |
MSISDN |
M |
O |
N1-REQ-MSG-TYPE |
O |
pdu_session_modification_request
pdu_sess_modification_command
pdu_session_release_req
pdu_session_release_command
pdu_session_release_complete
pdu_session_modification_reject
pdu_session_modification_complete
pdu_session_release_reject
N2-REQ-MSG-TYPE |
O |
N1-RSP-MSG-TYPE |
O |
N2-RSP-MSG-TYPE |
O |
N1-PCO |
NA |
PCO |
N1-QOS-RULE |
O |
QOS-RULE |
N1-QOS-DESC |
O |
QOS-DESC |
CAUSE |
O |
N1-ALWAYS-ON |
O |
5G-SM-CAP |
O |
O |
RAT-TYPE |
O |
UP-CONTEXT-STATE |
O |
HO-STATE |
O |
N1-BACKOFF-TIME |
NA |
N1-PDU-SESS-ID |
M |
N1-VGSM-RE-ATTEMPT-IND |
NA |
N1-RE-ATTEMPT-IND |
NA |
N1-SESS-AMBR |
O |
N1-CONG-RE-ATTEMPT-IND |
O |
N1-RSP-ALWAYS-ON |
NA |
3 |
PROCEDURE ID |
EVENT-ID |
PROCEDURE-ID |
M |
Event=N11N1N2MessageTransferReq |
FIELD-COUNT |
M |
STATUS |
M |
STATUS-CODE |
O |
PDU-SESSION-TYPE |
M |
N1-REQ-MSG-TYPE |
O |
PDU-SESSION-ESTB-ACCEPT,
PDU-SESSION-ESTB-REJECT etc.,
N2-REQ-MSG-TYPE |
O |
N1-RSP-MSG-TYPE |
N2-RSP-MSG-TYPE |
N1-PCO |
O |
PCO |
N1-QOS-RULE |
O |
QOS-RULE |
N1-QOS-DESC |
O |
QOS-DESC |
CAUSE |
O |
N1-ALWAYS-ON |
O |
N1-SESSION-AMBR |
O |
SESS-AMBR |
N1-PAA |
O |
PAA |
N1-S-NSSAI |
O |
NSSAI |
N1-PDU-SESS-ID |
N1-DNN/APN |
O |
N1-BACKOFF-TIME |
NA |
N1-REQ- SSC-MODE-SELECTED |
O |
N1-REQ-PDU(PDN)- SESSION-TYPE-SELECTED |
O |
N1-SSC-MODE-ALLOWED |
O |
O |
N1-RE-ATTEMPT-IND |
NA |
N1-RSP-AN-TYPE |
NA |
PROCEDURE ID |
EVENT-ID |
VERSION |
M |
Event=N16PduSession HsmfUpdateReq
FIELD-COUNT |
M |
STATUS |
M |
STATUS-CODE |
O |
IMEI/PEI |
O |
M |
RequestIndication |
VCNTUNNEL-INFO |
O |
TUNNEL-INFO |
SERVING-PLMN |
O |
AN-TYPE |
O |
AccessType |
RAT-TYPE |
O |
O |
CAUSE |
O |
VGMM-CAUSE |
O |
NGAP-CAUSE |
O |
NGAP-CAUSE |
ALWAYS-ON |
O |
EPS-IWK |
O |
O |
N1-PDU-SESS-ID |
O |
N1-PCO |
O |
N1-RSP-MAX-SUPP-FILTERS |
O |
N1-ALWAYS-ON |
O |
N1-QOS-RULES |
O |
N1-QOS-DESC |
O |
5 |
PROCEDURE ID |
EVENT-ID |
VERSION |
Event= N16PduSessionVsmfUpdateReq
FIELD-COUNT |
M |
STATUS |
STATUS-CODE |
SESSION-AMBR |
ALWAYS-ON-GRANTED |
CAUSE |
SESS-AMBR |
N1SM-CAUSE |
BACKOFF-TIMER |
N1-REQ-MSG-TYPE |
O |
N1-RSP-MSG-TYPE |
PDU_SESSION_ MODIFICATION_REJECT
N1-PCO |
O |
N1-QOS-RULE |
O |
N1-QOS-DESC |
O |
N1-PDU-SESS-ID |
O |
N1-ALWAYS-ON |
O |
N1-SESSION-AMBR |
O |
6 |
PROCEDURE ID |
EVENT-ID |
VERSION |
M |
Event=N16VsmfPdu SessionReleaseReq
FIELD-COUNT |
M |
STATUS |
O |
STATUS-CODE |
O |
CAUSE |
O |
VGMM-CAUSE |
O |
7 |
PROCEDURE ID |
EVENT-ID |
VERSION |
M |
Event=N16Pdu SessionNotifyReqClient
FIELD-COUNT |
M |
STATUS |
M |
STATUS-CODE |
O |
RESOURCE-STATUS |
O |
Resourcestatus |
CAUSE |
O |
8 |
PROCEDURE ID |
EVENT-ID =1000 |
VERSION |
M |
Event= META-DATA |
FIELD-COUNT |
M |
SUPI |
M |
IMSI |
M |
IMEI |
M |
MSISDN |
M |
GPSI |
SERVING-PLMN |
M |
UE-LOCATION |
M |
START-TIME |
M |
END-TIME |
M |
TRIGGER-NF |
M |
TRIGGER-EVENT |
M |
USERPLANE-STATUS |
M |
CAUSE |
M |
SGW-ID |
O |
DISCONNECT-REASON |
O |
STATUS |
M |
UPDATE-TIME |
NA |
For details on the listed attributes, see the table in the EDR Transaction File section.
The following tables list the detailed event record for the SMF DEDICATED BEARER and SMF IDLE-MODE procedures.
Table 9. SMF IDLE-MODE Events
Attributes
Type
Category
Instances
Description
EVENT-ID |
string |
M |
SINGLE |
pdn-im |
EDR-PROFILE-ID |
string |
M |
SINGLE |
from config |
VERSION |
string |
M |
SINGLE |
from config |
NODE-ID |
string |
M |
SINGLE |
SERVICE |
string |
M |
SINGLE |
SMF or AMF or PCF or SGW-C or PGW-C |
KEY |
string |
M |
SINGLE |
IMSI+PDU-SESSION-ID |
IMSI |
string |
M |
SINGLE |
OPERATION |
string |
M |
SINGLE |
IM ENTRY or IM EXIT |
TRIGGER-NF |
string |
M |
SINGLE |
smf or amf or upf |
TRIGGER-EVENT |
string |
M |
SINGLE |
DLDR/ERIR/UPIR/AN-INIT |
UE-LOCATION |
string |
M |
SINGLE |
mcc-mnc-tac-ncgi or mcc-mnc-tac-ecgi |
SERVING-PLMN |
string |
M |
SINGLE |
LOCAL-UFTEID-TEID |
integer |
O |
SINGLE |
LOCAL-UFTEID-IP |
string |
O |
SINGLE |
REMOTE-UFTEID-TEID |
integer |
O |
SINGLE |
REMOTE-UFTEID-IP |
string |
O |
SINGLE |
AMF-ID |
string |
M |
SINGLE |
USERPLANE-STATUS |
string |
M |
SINGLE |
activated or deactivated |
UPDATE-TIME |
string |
M |
SINGLE |
CAUSE |
string |
M |
SINGLE |
DISCONNECT-REASON |
string |
O |
SINGLE |
N1-MESSAGES |
protobuf |
O |
MULTIPLE |
N2-MESSAGES |
protobuf |
O |
MULTIPLE |
N11-MESSAGES |
protobuf |
O |
MULTIPLE |
Procedure EDR Example:
1,2021/03/18 13:43:40.892,1448,imsi-123456789012345,1287,N11SmContextCreateReq,
3,1313,V1,Success,201,1,,3,1316,V1,Success,200,1,,3,1319,V1,Success,201,1,,3,1287,V1,
imsi-123456789012345,imei-123456786666660,123456789012345,9999988888,msisdn-9999988888,
Success,,1,0,,,193|,,,,,,,NR,3,3329,V1,imsi-123456789012345,imei-123456786666660,msisdn-9999988888,
Success,201,1,3|1;2;7|3000 mbps|4000 mbps|1000 mbps|2000 mbps,20 kbps|20 kbps,,3,3332,V1,Success,
204,1,,3,3585,V1,Success,201,1,,3,524,V1,Success,,1,Request_Accepted,3,1299,V1,Success,200,194|,
77|,,,,1,1,intershat,2|1|0|2|128|1|filters:0;3;1;;|3|1|0|2|192|1|filters:0;3;1;;|1|1|1|1|255|1|
filters:0;3;1;;,5||0 kbps|0 kbps|0 kbps|0 kbps|3||6000 mbps|8000 mbps|2000 mbps|4000 mbps,20 kbps|
20 kbps,N1_N2_TRANSFER_INITIATED,209.165.200.235|,2|Abf123||,0
In the preceding example, the initial entries represent the transaction EDRs and last part provided here represents the procedure-level
EDRs.
