Sample Configuration
The following is only a sample configuration file provided solely for your reference. You must create and modify your own configuration file according to the specific needs of your deployment.
profile compliance comp1
service nsmf-pdusession
version uri v1
version full 1.0.2
version spec 15.4.0
exit
service namf-comm
version uri v1
version full 1.0.2
version spec 15.4.0
exit
service n1
version uri v1
version full 1.0.0
version spec 15.4.0
exit
service n2
version uri v1
version full 1.0.0
version spec 15.4.0
exit
service nudm-sdm
version uri v2
version full 2.0.1
version spec 15.4.0
exit
service nudm-uecm
version uri v1
version full 1.0.2
version spec 15.4.0
exit
service nnrf-disc
version uri v1
version full 1.0.2
version spec 15.4.0
exit
service nnrf-nfm
version uri v1
version full 1.0.2
version spec 15.4.0
exit
service npcf-smpolicycontrol
version uri v1
version full 1.0.2
version spec 15.4.0
exit
service nchf-convergedcharging
version uri v2
version full 2.0.1
version spec 15.3.0
exit
exit
profile network-element amf amf1
nf-client-profile AP1
failure-handling-profile FH3
query-params [ dnn target-nf-instance-id ]
exit
profile network-element udm udm1
nf-client-profile UP1
failure-handling-profile FH1
query-params [ target-plmn target-nf-instance-id ]
query-target-plmn primary
exit
profile network-element pcf pcf1
nf-client-profile PP1
query-params [ dnn target-plmn target-nf-instance-id requester-snssais ]
rulebase-prefix cbn#
predefined-rule-prefix crn#
use-amf-provided-pcf true
exit
profile network-element chf chf1
nf-client-profile CP1
failure-handling-profile FH2
query-params [ dnn target-plmn chf-supported-plmn ]
nf-client-profile-offline CP2
failure-handling-profile-offline FH2
exit
profile network-element chf chgser1
exit
profile network-element sepp sepp1
nf-client-profile hsepp
exit
profile network-element upf upf1
n4-peer-address ipv4 209.165.200.231
n4-peer-port 8805
upf-group-profile upfGroup1
dnn-list [ cisco intershat starent ]
capacity 65535
priority 1
exit
profile network-element upf upf2
n4-peer-address ipv4 209.165.200.232
n4-peer-port 8805
capacity 65535
priority 2
exit
profile network-element upf upf3
node-id toolsUPF
n4-peer-address ipv4 209.165.200.233
n4-peer-port 8805
capacity 32768
priority 10
exit
profile upf-group upfGroup1
heartbeat
interval 63
retransmission-timeout 3
max-retransmissions 5
exit
supported-features [ secondary-pdr ]
exit
profile wps wps1
arp 1-15
dscp n3 0x14
dscp sxa 0x22
dscp s5e 0x24
dscp s11 0x26
message-priority [ pfcp gtpc ]
exit
profile wps wps_F5972
arp 1-4,14
dscp n3 0x0F
exit
profile pcscf pcscf1
v4-list
precedence 3
primary 209.165.201.1
secondary 209.165.201.2
exit
exit
v6-list
precedence 3
primary 33:33::1
secondary 33:33::2
exit
exit
v4v6-list
precedence 3
primary ipv4 209.165.200.225
primary ipv6 fd01:976a:c305:9::5
secondary ipv4 209.165.200.26
secondary ipv6 46:46:33::2
exit
exit
exit
profile icmpv6 icmpprf1
options virtual-mac b6:6d:57:45:45:45
exit
profile charging chgprf1
method [ offline ]
limit volume 10000000
limit duration 7200
accounting limit volume downlink 100000 total 100000 uplink 100000
accounting triggers [ qos-change rat-change serv-node-change ambr-change ue-time-change plmn-change user-loc-change ]
tight-interworking-mode true
quota request always
quota suppress triggers [ qht ]
reporting-level online rating-group
reporting-level offline service-id
exit
profile charging chgprf2
method [ offline ]
exit
profile charging chgprf3_roaming
method [ offline ]
exit
profile charging-characteristics 1
charging-profile chgprf2
charging-qbc-profile qbc_general
exit
profile charging-qbc qbc_general
limit volume 20500
limit duration 70
max-charging-condition 1
max-deferred-urr 2
triggers [ ambr-change qos-change user-loc-change ]
exit
profile charging-qbc qbc_hsmf1
limit volume 40500
limit duration 140
triggers [ ambr-change qos-change serv-node-change user-loc-change ]
exit
profile failure-handling FH1
interface pfcp
message N4SessionEstablishmentReq
cause-code pfcp-entity-in-congestion action retry-terminate max-retry 2
cause-code system-failure action terminate
cause-code service-not-supported action terminate
cause-code no-resource-available action retry-terminate max-retry 3
cause-code no-response-received action retry-terminate max-retry 1
cause-code reject action terminate
exit
message N4SessionModificationReq
cause-code mandatory-ie-incorrect action terminate
cause-code session-ctx-not-found action terminate
exit
exit
interface sxa
message SessionEstablishmentReq
cause-code 2-255 action retry-terminate max-retry 4
exit
exit
exit
profile failure-handling gtp1
interface gtpc message S5S8CreateBearerReq
cause-code temp-fail
action retry timeout 1000 max-retry 2
exit
exit
interface gtpc message S5S8UpdateBearerReq
exit
exit
interface gtpc message S5S8DeleteBearerReq
exit
exit
exit
profile access access1
n26 idft enable timeout 15
n2 idft enable timeout 15
gtpc gtpc-failure-profile gtp1
erir delay 1
eps-fallback cbr delay 3000 max-retry 1 timeout 1
exit
profile access idft
n1 t3591-pdu-mod-cmd timeout 2 max-retry 1
n1 t3592-pdu-rel-cmd timeout 2 max-retry 1
erir delay 2000
exit
profile tai-group TA1
mcc 123 mnc 456
tac list [ 00092a 2346 2356 ]
exit
mcc 310 mnc 260
tac range start 1234 end 7890
exit
exit
mcc 310 mnc 310
tac list [ 2346 2356 2378 ]
tac range start 5676 end 5767
exit
exit
exit
profile tai-group TA2
mcc 310 mnc 260
tac list [ 2346 5676 ]
exit
exit
profile tai-group tgp2
mcc 091 mnc 05
exit
exit
profile ecgi-group ECGI1
mcc 122 mnc 234
ecgi range start 1234567 end 1234577
exit
exit
mcc 123 mnc 456
exit
exit
mcc 310 mnc 260
exit
exit
mcc 310 mnc 310
exit
exit
profile ecgi-group ECGI2
exit
profile ncgi-group NCGI1
mcc 123 mnc 456
ncgi range start 123456788 end 133456789
exit
exit
mcc 310 mnc 260
ncgi list [ 123456789 ]
ncgi range start 123456788 end 234567891
exit
exit
mcc 310 mnc 310
ncgi list [ 123456789 133456789 ]
ncgi range start 234567891 end 244567891
exit
exit
exit
profile ncgi-group NCGI2
mcc 123 mnc 456
ncgi range start 123456789 end 133456789
exit
exit
exit
mcc 310 mnc 260
exit
exit
exit
profile location-area-group loc1
tai-group TA1
ecgi-group ECGI1
ncgi-group NCGI1
exit
profile location-area-group loc2
tai-group TA2
ncgi-group NCGI1
exit
profile radius
deadtime 2
detect-dead-server response-timeout 2
max-retry 2
timeout 2
enable-packet-dump
server 209.165.200.248 1812
type auth
secret $8$j1Tgf1IvRvdywBgDZsP7q7FPzo87+/c1QV99bLxz6AY=
priority 1
exit
server 209.165.200.248 1813
type acct
secret $8$bANgMCn/x7CspByC/q5Jm1sMo5d9TZMKdTbEq7543wc=
priority 10
exit
attribute
nas-identifier CISCO-SMF
exit
accounting
algorithm first-server
max-retry 3
timeout 1
attribute
nas-identifier CISCO-ACCT-SMF
exit
exit
server-group sg1
server auth 209.165.200.248 1812
exit
server acct 209.165.200.248 1813
exit
attribute
nas-ip 209.165.200.226
exit
accounting
attribute
exit
exit
exit
exit
profile radius-dynamic-author
client 209.165.200.248
secret $8$G7fLQoqcBFPFpZNstAQUT/VtoxHqGqwPdLNB1PliHOI=
exit
exit
profile dnn cisco
dns primary ipv4 209.165.200.239
dns primary ipv6 2001:4870:e00b:1a::3
dns secondary ipv6 2001:4870:e00b:1a::5
network-element-profiles chf chf1
network-element-profiles amf amf1
network-element-profiles pcf pcf1
network-element-profiles udm udm1
network-element-profiles sepp sepp1
dnn cisco network-function-list [ upf upf2 ]
dnn rmgr cisco
timeout absolute 360000 up-idle 900 cp-idle 1500
charging-profile chgprf1
charging-qbc-profile qbc_hsmf1
virtual-mac b6:6d:47:47:47:47
pcscf-profile pcscf1
wps-profile wps1
ssc-mode 1 allowed [ 3 ]
session type IPV4 allowed [ IPV6 IPV4V6 ]
upf apn cisco
qos-profile qos_nonStdQci
authentication secondary radius group sg1
authentication algorithm pap 1 password-use-pco chap 2 convert-to-mschap mschap 3
always-on false
userplane-inactivity-timer 300
only-nr-capable-ue true
exit
profile dnn intershat
nexthop-forwarding-address ipv4 209.165.200.254
nexthop-forwarding-address ipv6 8454:8454::8454
wps-profile wps1
ssc-mode 1
always-on false
dcnr true
userplane-inactivity-timer 1800
emergency false
exit
profile dnn sos
ssc-mode 1
authorization local
emergency true
exit
profile dnn starent
dns primary ipv4 10.168.220.239
timeout absolute 360000 up-idle 60 cp-idle 600
wps-profile wps2
ssc-mode 1
upf apn intershat
qos-profile qos_F5972
always-on false
emergency false
exit
profile sgw-qos-profile sgw-non-standardqci
dscp-map operator-defined-qci 128 non-gbr arp-priority-level 5 uplink user-datagram dscp-marking 0x1e
dscp-map operator-defined-qci 128 non-gbr arp-priority-level 5 downlink user-datagram dscp-marking 0x22 encaps-header copy-inner
exit
profile qos 5qi-to-dscp-mapping-table
dscp-map qi5 1 uplink user-datagram dscp-marking 0x2D
dscp-map qi5 1 downlink encsp-header dscp-marking 0x2F
dscp-map qi5 3 uplink user-datagram dscp-marking 0x0c
dscp-map qi5 3 downlink encsp-header dscp-marking 0x0c
dscp-map qi5 5 uplink user-datagram dscp-marking 0x3D
dscp-map qi5 5 downlink encsp-header dscp-marking 0x3F
dscp-map qi5 6 uplink user-datagram dscp-marking 0x0c
dscp-map qi5 6 downlink encsp-header dscp-marking 0x0c
dscp-map qi5 7 uplink user-datagram dscp-marking 0x0e
dscp-map qi5 7 downlink encsp-header dscp-marking 0x0e
dscp-map qi5 8 uplink user-datagram dscp-marking 0x0e
dscp-map qi5 8 downlink encsp-header dscp-marking 0x0e
dscp-map qi5 9 uplink user-datagram dscp-marking 0x0a
dscp-map qi5 9 downlink encsp-header dscp-marking 0x0a
dscp-map qi5 43 uplink user-datagram dscp-marking 0x1D
dscp-map qi5 43 downlink encsp-header dscp-marking 0x1F
exit
profile qos abc
ambr ul "250 Kbps"
ambr dl "500 Kbps"
qi5 7
arp priority-level 14
arp preempt-cap NOT_PREEMPT
arp preempt-vuln PREEMPTABLE
priority 120
max data-burst 2000
dscp-map qi5 1 arp-priority-level 12 uplink user-datagram dscp-marking 0x2e
dscp-map qi5 1 arp-priority-level 12 downlink user-datagram dscp-marking 0x12 encsp-header copy-inner
dscp-map qi5 1 uplink user-datagram dscp-marking 0x2e
dscp-map qi5 1 downlink user-datagram dscp-marking 0x12 encsp-header copy-inner
dscp-map qi5 2 uplink user-datagram dscp-marking 0x3f
dscp-map qi5 2 downlink user-datagram dscp-marking 0x2a encsp-header dscp-marking 0x0a
dscp-map qi5 3 uplink user-datagram dscp-marking 0x2e
dscp-map qi5 3 downlink user-datagram dscp-marking 0x12 encsp-header copy-inner
dscp-map qi5 4 uplink user-datagram dscp-marking 0x3f
dscp-map qi5 4 downlink user-datagram dscp-marking 0x2a encsp-header dscp-marking 0x0a
dscp-map qi5 5 uplink user-datagram dscp-marking 0x2e
dscp-map qi5 5 downlink user-datagram dscp-marking 0x12 encsp-header copy-inner
dscp-map qi5 6 uplink user-datagram dscp-marking 0x3f
dscp-map qi5 6 downlink user-datagram dscp-marking 0x2a encsp-header dscp-marking 0x0a
dscp-map qi5 7 uplink user-datagram dscp-marking 0x3f
dscp-map qi5 7 downlink user-datagram dscp-marking 0x2a encsp-header dscp-marking 0x0a
dscp-map qi5 8 uplink user-datagram dscp-marking 0x2e
dscp-map qi5 8 downlink user-datagram dscp-marking 0x12 encsp-header copy-inner
dscp-map qi5 9 uplink user-datagram dscp-marking 0x3f
dscp-map qi5 9 downlink user-datagram dscp-marking 0x2a encsp-header dscp-marking 0x0a
dscp-map qi5 65 uplink user-datagram dscp-marking 0x2e
dscp-map qi5 65 downlink user-datagram dscp-marking 0x12 encsp-header copy-inner
dscp-map qi5 66 uplink user-datagram dscp-marking 0x3f
dscp-map qi5 66 downlink user-datagram dscp-marking 0x2a encsp-header dscp-marking 0x0a
dscp-map qi5 69 uplink user-datagram dscp-marking 0x2e
dscp-map qi5 69 downlink user-datagram dscp-marking 0x12 encsp-header copy-inner
dscp-map qi5 70 uplink user-datagram dscp-marking 0x3f
dscp-map qi5 70 downlink user-datagram dscp-marking 0x2a encsp-header dscp-marking 0x0a
dscp-map qi5 80 uplink user-datagram dscp-marking 0x2e
dscp-map qi5 80 downlink user-datagram dscp-marking 0x12 encsp-header copy-inner
dscp-map qi5 82 uplink user-datagram dscp-marking 0x3f
dscp-map qi5 82 downlink user-datagram dscp-marking 0x2a encsp-header dscp-marking 0x0a
dscp-map qi5 83 uplink user-datagram dscp-marking 0x3f
dscp-map qi5 83 downlink user-datagram dscp-marking 0x2a encsp-header dscp-marking 0x0a
exit
profile qos qos1
qi5 128
arp priority-level 8
arp preempt-vuln NOT_PREEMPTABLE
priority 9
max data-burst 2048
exit
profile qos qos_F5972
dscp-map qi5 1 arp-priority-level 5 uplink user-datagram dscp-marking 0x1e
dscp-map qi5 1 arp-priority-level 5 downlink user-datagram dscp-marking 0x22 encsp-header copy-inner
exit
profile qos qos_nonStdQci
ambr ul "250 Kbps"
ambr dl "500 Kbps"
qi5 128
arp priority-level 12
dscp-map qi5 2 arp-priority-level 6 uplink user-datagram dscp-marking 0x3e
dscp-map qi5 2 arp-priority-level 6 downlink user-datagram dscp-marking 0x23 encsp-header copy-inner
dscp-map qi5 3 arp-priority-level 12 uplink user-datagram dscp-marking 0x2f
dscp-map qi5 3 arp-priority-level 12 downlink user-datagram dscp-marking 0x14 encsp-header copy-inner
dscp-map qi5 6 downlink encsp-header copy-inner
dscp-map qi5 7 downlink encsp-header dscp-marking 0x01
dscp-map qi5 15 arp-priority-level 12 uplink user-datagram dscp-marking 0x2f
dscp-map qi5 15 arp-priority-level 12 downlink user-datagram dscp-marking 0x14 encsp-header copy-inner
dscp-map qi5 65 arp-priority-level 5 uplink user-datagram dscp-marking 0x1e
dscp-map qi5 65 arp-priority-level 5 downlink user-datagram dscp-marking 0x22 encsp-header copy-inner
dscp-map qi5 70 arp-priority-level 12 uplink user-datagram dscp-marking 0x2f
dscp-map qi5 70 arp-priority-level 12 downlink user-datagram dscp-marking 0x14 encsp-header copy-inner
dscp-map qi5 80 downlink encsp-header copy-inner
dscp-map qi5 81 downlink encsp-header copy-inner
dscp-map qi5 83 arp-priority-level 6 uplink user-datagram dscp-marking 0x3e
dscp-map qi5 83 arp-priority-level 6 downlink user-datagram dscp-marking 0x23 encsp-header copy-inner
dscp-map qi5 85 downlink encsp-header dscp-marking 0x01
dscp-map qi5 128 arp-priority-level 5 uplink user-datagram dscp-marking 0x1e
dscp-map qi5 128 arp-priority-level 5 downlink user-datagram dscp-marking 0x22 encsp-header copy-inner
dscp-map qi5 230 arp-priority-level 6 uplink user-datagram dscp-marking 0x3e
dscp-map qi5 230 arp-priority-level 6 downlink user-datagram dscp-marking 0x23 encsp-header copy-inner
dscp-map qi5 254 downlink encsp-header dscp-marking 0x01
exit
profile ppd ppd1
fqi 1,10-15,43,65
dscp 0 ppi 3
dscp 1 ppi 2
dscp 43 ppi 3
exit
profile nf-client nf-type udm
udm-profile UP1
locality LOC1
priority 30
service name type nudm-sdm
endpoint-profile EP1
capacity 30
uri-scheme http
version
uri-version v2
exit
exit
endpoint-name EP1
primary ip-address ipv4 209.165.200.248
primary ip-address port 9001
exit
exit
exit
service name type nudm-uecm
capacity 30
uri-scheme http
endpoint-name EP1
exit
exit
exit
service name type nudm-ee
capacity 30
api-uri-prefix PREFIX
api-root ROOT
uri-scheme http
endpoint-name EP1
priority 56
exit
exit
exit
exit
exit
exit
profile nf-client nf-type pcf
pcf-profile PP1
locality LOC1
priority 30
service name type npcf-smpolicycontrol
capacity 30
uri-scheme http
endpoint-name EP1
priority 100
primary ip-address port 9003
exit
endpoint-name realPCF
priority 50
primary ip-address ipv4 10.1.2.138
primary ip-address port 9082
exit
exit
exit
exit
exit
exit
profile nf-client nf-type amf
amf-profile AP1
locality LOC1
priority 30
service name type namf-comm
endpoint-profile EP2
capacity 30
uri-scheme http
endpoint-name EP1
priority 56
primary ip-address port 9002
exit
endpoint-name realAMF
priority 100
primary ip-address ipv4 209.165.202.138
primary ip-address port 8090
exit
exit
exit
exit
exit
exit
profile nf-client nf-type chf
chf-profile CP1
locality LOC1
priority 30
service name type nchf-convergedcharging
capacity 30
uri-scheme http
version
uri-version v2
exit
exit
endpoint-name EP1
priority 100
primary ip-address port 9004
exit
exit
exit
exit
exit
chf-profile CP2
locality LOC1
priority 31
capacity 30
uri-scheme http
version
uri-version v2
exit
exit
endpoint-name EP1
priority 56
primary ip-address port 9005
exit
exit
exit
exit
exit
exit
profile nf-client nf-type sepp
sepp-profile hsepp
locality LOC1
priority 30
service name type nsmf-pdusession
capacity 30
uri-scheme http
endpoint-name EP1
priority 56
primary ip-address ipv4 209.165.200.250
exit
endpoint-name lfs-hsepp
priority 10
primary ip-address port 8888
secondary ip-address ipv4 209.165.200.249
secondary ip-address port 8889
exit
exit
exit
exit
exit
exit
profile nf-pair nf-type UDM
nrf-discovery-group DISC1
locality client LOC1
locality preferred-server LOC1
locality geo-server GEO
cache invalidation true timeout 20000
exit
profile nf-pair nf-type AMF
exit
profile nf-pair nf-type PCF
exit
profile nf-pair nf-type SEPP
exit
profile nf-pair nf-type UPF
exit
profile nf-pair nf-type CHF
exit
profile nf-client-failure nf-type udm
message type UdmSdmGetUESMSubscriptionData
status-code httpv2 504
retry 1
action continue
exit
exit
message type UdmSdmSubscribeToNotification
retry 1
action continue
exit
exit
message type UdmSubscriptionReq
retry 1
action continue
exit
exit
exit
message type UdmUecmRegisterSMF
retry 1
action continue
exit
exit
message type UdmUecmUnregisterSMF
action continue
exit
exit
message type UdmRegistrationReq
action continue
exit
exit
exit
exit
exit
profile nf-client-failure nf-type pcf
responsetimeout 4000
message type PcfSmpolicycontrolCreate
status-code httpv2 0,403
action retry-and-ignore
exit
status-code httpv2 400,504
action continue
exit
status-code httpv2 404
action terminate
exit
status-code httpv2 500
retry 2
exit
status-code httpv2 503
retry 2
action retry-and-continue
exit
exit
message type PcfSmpolicycontrolUpdate
exit
action continue
exit
action terminate
exit
retry 2
exit
retry 2
exit
exit
message type PcfSmpolicycontrolDelete
exit
action continue
exit
action terminate
exit
retry 2
exit
retry 2
exit
exit
exit
exit
exit
profile nf-client-failure nf-type chf
profile failure-handling FH2
message type ChfConvergedchargingCreate
status-code httpv2 0,500,504
action continue
exit
status-code httpv2 400,404
retry 3
action retry-and-terminate
exit
status-code httpv2 403
retry 3
exit
action terminate
exit
exit
message type ChfConvergedchargingUpdate
action continue
exit
retry 3
exit
retry 3
exit
action terminate
exit
exit
message type ChfConvergedchargingDelete
action continue
exit
retry 3
exit
retry 3
exit
action terminate
exit
exit
exit
exit
exit
profile nf-client-failure nf-type sepp
profile failure-handling sepp
message type VsmfPduSessionCreate
retry 5
exit
retry 3
exit
exit
message type VsmfPduSessionUpdate
status-code httpv2 0,401,404,503-504
exit
action terminate
exit
exit
message type VsmfPduSessionRelease
status-code httpv2 0,504
exit
exit
exit
exit
exit
profile smf smf1
locality LOC1
allowed-nssai [ slice1 slice2 ]
load-profile gtp-load1
instances 1 fqdn 5gc.mnc456.mcc123.3gppnetwork.org
instances 1 inter-plmn-fqdn 5gc.mnc210.mcc310.3gppnetwork.org
instances 1 supported-features [ vsmf ]
plmn-list mcc 123 mnc 456
exit
plmn-list mcc 310 mnc 310
exit
service name nsmf-pdu
type pdu-session
schema http
service-id 1
version 1.Rn.0.0
http-endpoint base-url http://smf-service
icmpv6-profile icmpprf1
compliance-profile comp1
access-profile access1
subscriber-policy polSub
exit
exit
profile sgw sgw1
locality LOC1
fqdn cisco.com.apn.epc.mnc456.mcc123
ddn failure-action-drop-timer 60
ddn no-user-connect-retry-timer 60
qci-qos-profile sgw-non-standardqci
wps-profile wps1
exit
plmn-list mcc 310 mnc 260
exit
exit
profile sgw-charging-threshold thre1
cc profile value 1
volume total 100000
buckets 2
duration 180
exit
cc profile value 2
volume uplink 100000
buckets 4
duration 120
exit
cc profile value 4
volume total 10000000
buckets 4
duration 300
exit
cc profile value 8
volume total 100000
buckets 2
duration 3000
exit
exit
profile overload gtp-overload1
overload-exclude-profile self-protection gtp-overloadExclude1
node-level
tolerance minimum 15
tolerance maximum 35
reduction-metric minimum 20
reduction-metric maximum 90
advertise
interval 300
change-factor 15
validity-period 60
exit
interface gtpc
overloaded-action [ advertise ]
exit
exit
exit
profile overload-exclude gtp-overloadExclude1
dnn-list [ sos ]
arp-list [ 1 2 3 ]
procedure-list [ session-delete ]
message-priority s5
upto 0
exit
exit
profile load gtp-load1
load-calc-frequency 30
load-fetch-frequency 15
advertise
interval 30
change-factor 5
exit
interface gtpc
action advertise
exit
exit
profile gtpp-profile pf1 gtpp
local-storage
file
rotation
volume 5
cdr-count 1000
time-interval 60
exit
name
prefix hSMF-cnsgw1
format .%Y-%m-%d%H-%M-%S.%4Q
max-file-seq-num 9
start-file-seq-num 1
recover-file-seq-num true
exit
format custom1
exit
exit
dictionary custom24
exit
profile gtpp-profile pf2 gtpp
local-storage
file
rotation
volume 5
cdr-count 1000
time-interval 60
exit
name
prefix hSMF-cnsgw1
max-file-seq-num 9
exit
format custom1
exit
exit
dictionary custom24
exit
profile gtpp-profile pf4 gtpp
local-storage
file
rotation
volume 5
cdr-count 1000
time-interval 60
exit
name
prefix hSMF-cnsgw1
max-file-seq-num 9
exit
format custom1
exit
exit
dictionary custom24
exit
profile dns-proxy
timeout 6000
round-robin-answers
servers serv1
ip 209.165.202.143
port 53
protocol tcp
exit
servers serv2
ip 209.165.200.225
port 53
protocol tcp
exit
exit
profile converged-core cc1
max-upf-index 150
exit
nf-tls certificates cert1
cert-data abc
private_key k1
exit
active-charging service acs1
bandwidth-policy BWP
flow limit-for-bandwidth id 1 group-id 2
flow limit-for-bandwidth id 2 group-id 3
flow limit-for-bandwidth id 3 group-id 4
group-id 2 direction uplink peak-data-rate 64000 peak-burst-size 8000 violate-action discard
group-id 2 direction downlink peak-data-rate 64000 peak-burst-size 8000 violate-action discard
group-id 3 direction uplink peak-data-rate 128000 peak-burst-size 12000 violate-action discard
group-id 3 direction downlink peak-data-rate 128000 peak-burst-size 12000 violate-action discard
group-id 4 direction uplink peak-data-rate 3000000000 peak-burst-size 100 violate-action discard
group-id 4 direction downlink peak-data-rate 3000000000 peak-burst-size 100 violate-action discard
exit
packet-filter pkt1
ip local-port range 2 to 23
ip protocol = 23
ip remote-address = 209.165.201.0/27
ip remote-port range 12 to 34
ip tos-traffic-class = 23 mask = 23
priority 23
exit
charging-action ca1
billing-action egcdr
content-id 51
flow action redirect-url http://www.google.com
service-identifier 6000
tft-notify-ue
tos af11
tft packet-filter pkt1
exit
charging-action caStaticOfflineOnline
cca charging credit
content-id 30
flow limit-for-bandwidth direction uplink peak-data-rate 1000000000 peak-burst-size 100 violate-action discard committedDataRate 1000000000 committed-burst-size 100 exceed-action discard
flow limit-for-bandwidth direction downlink peak-data-rate 1000000000 peak-burst-size 100 violate-action discard committedDataRate 1000000000 committed-burst-size 100 exceed-action discard
tft-notify-ue
tos af11
exit
rulebase cisco
billing-records egcdr
edr transaction-complete http charging-edr http-edr
dynamic-rule order first-if-tied
egcdr threshold interval 1000
action priority 1 ruledef ip-any-rule charging-action cisco
route priority 1000 ruledef http-port-route analyzer http
exit
rulebase rba1
action priority 1 dynamic-only ruledef rda1 charging-action ca1 description myrule1
action priority 10 ruledef rda1 charging-action ca1
exit
urr-list urr_smf
rating-group 10 urr-id 1
rating-group 10 service-identifier 20 urr-id 2
rating-group 10 service-identifier 21 urr-id 50
rating-group 11 urr-id 3
rating-group 11 service-identifier 21 urr-id 4
rating-group 11 service-identifier 201 urr-id 11
rating-group 12 urr-id 5
rating-group 12 service-identifier 22 urr-id 6
rating-group 13 urr-id 7
rating-group 13 service-identifier 23 urr-id 8
rating-group 30 urr-id 17
rating-group 30 service-identifier 60 urr-id 18
rating-group 30 service-identifier 61 urr-id 19
rating-group 31 urr-id 20
rating-group 31 service-identifier 61 urr-id 21
rating-group 31 service-identifier 62 urr-id 22
rating-group 32 urr-id 23
rating-group 40 urr-id 24
rating-group 51 service-identifier 6000 urr-id 32
rating-group 100 urr-id 9
rating-group 100 service-identifier 200 urr-id 10
rating-group 100 service-identifier 201 urr-id 51
rating-group 101 urr-id 11
rating-group 101 service-identifier 201 urr-id 12
rating-group 102 urr-id 13
rating-group 102 service-identifier 202 urr-id 14
rating-group 103 urr-id 15
rating-group 103 service-identifier 203 urr-id 16
rating-group 110 urr-id 25
rating-group 199 urr-id 199
exit
ruledef adc_Youtube
multi-line-or all-lines
exit
credit-control group onlineoffline
diameter ignore-service-id true
exit
group-of-ruledefs adc_specific
add-ruledef priority 1 ruledef adc_google
add-ruledef priority 2 ruledef adc_facebook_https
add-ruledef priority 3 ruledef adc_sni
exit
gtpp group group1
gtpp egcdr service-data-flow threshold interval 60
gtpp egcdr service-data-flow threshold volume downlink 100000 uplink 100000 total 200000
exit
apn cisco
gtpp group group1
active-charging rulebase rba1
exit
apn intershat
gtpp group group1
exit
policy subscriber polSub
precedence 1
sst 22
sdt Abf123
serving-plmn mcc 123
serving-plmn mnc 456
supi-start-range 100000000000001
supi-stop-range 299999999999999
gpsi-start-range 1000000000
gpsi-stop-range 9999999999
operator-policy opPol1
exit
precedence 511
operator-policy defOprPol1
exit
exit
policy upf-selection up-policy1
precedence 1
[ dnn slice ]
exit
precedence 2
[ dnn location ]
exit
precedence 3
[ dnn pdn-type-session ]
exit
precedence 4
[ dnn ]
exit
exit
policy operator defOprPol1
policy dnn defPolDnn
policy network-capability nc1
exit
policy operator opPol1
policy dnn polDnn
exit
policy operator opPol2
policy dnn polDnn
exit
profile default-profile
dnn cisco profile cisco
dnn dnn2 profile profile2
dnn intershat profile intershat
dnn sos profile sos
dnn starent profile abc.com
exit
policy dnn dnnPol1
profile default
exit
policy dnn polDnn
exit
nw-support-local-address-tft true
exit
nssai name slice1
sst 1
dnn [ cisco intershat sos starent ]
exit
nssai name slice2
sst 2
sdt abf123
exit
system-diagnostics session-consistency action monitor
ipam
instance 1
source local
address-pool v4pool1
vrf-name ISP
tags
dnn intershat
exit
ipv4
split-size
per-cache 65536
per-dp 65536
exit
address-range 209.165.201.1 209.165.201.30
exit
exit
exit
exit
group nf-mgmt NFMGMT1
nrf-mgmt-group MGMT
locality LOC1
exit
group nrf discovery DISC1
nrf-type PLMN
service type nrf nnrf-disc
endpoint-profile
name EP1
uri-scheme http
version
uri-version v1
full-version 209.165.200.224/27
exit
exit
endpoint-name sauNRF
priority 80
capacity 56
primary ip-address ipv4 209.165.201.4
primary ip-address port 8095
exit
exit
exit
exit
cdl system-id 2
cdl enable-geo-replication true
cdl zookeeper replica 1
cdl remote-site 1
db-endpoint host 209.165.202.154
db-endpoint port 8882
kafka-server 10.1.8.54 10092
exit
exit
cdl label-config session
endpoint key smi.cisco.com/node-type
endpoint value smf-cdl
slot map 1
value smf-cdl
exit
slot map 2
value smf-cdl-1
exit
index map 1
value smf-cdl-1
exit
exit
cdl logging default-log-level error
cdl logging logger datastore.ep.session
level debug
exit
cdl logging logger datastore.index.session
level debug
exit
cdl logging logger datastore.slot.session
level debug
exit
cdl datastore session
geo-remote-site [ 1 ]
slice-names [ 1 2 ]
endpoint replica 1
endpoint external-ip 209.165.202.158
endpoint external-port 8882
index replica 1
index map 1
index write-factor 1
slot replica 1
slot map 2
slot write-factor 1
exit
cdl kafka replica 1
cdl kafka ssl-settings enable-ssl false
cdl kafka label-config key smi.cisco.com/pod-type
cdl kafka label-config value cdl-kafka-1
cdl kafka external-ip 209.165.202.158 10092
exit
etcd replicas 1
edr reporting enable
edr subscribers [ 112233445566776 112233445566777 112233445566778 imsi-123456789012345 imsi-123456789012346 imsi-310310789012345 ]
edr file transaction
reporting enable
exit
edr file transaction-collision
reporting enable
exit
instance instance-id 1
endpoint li
replicas 1
nodes 1
vip-ip 209.165.201.3
exit
endpoint nodemgr
replicas 1
nodes 2
exit
endpoint gtp
replicas 1
nodes 1
vip-ip 209.165.200.232
interface s5
exit
interface s5e
vip-ip 209.165.200.233
exit
interface s11
vip-ip 209.165.200.236
exit
exit
endpoint pfcp
replicas 1
nodes 2
interface n4
heartbeat
interval 0
exit
exit
exit
endpoint service
replicas 1
nodes 1
exit
endpoint protocol
replicas 1
nodes 2
vip-ip 209.165.200.253
interface sxa
vip-ip 209.165.200.254
exit
interface n4
vip-ip 209.165.200.230
exit
exit
endpoint radius
replicas 1
nodes 1
vip-ip 209.165.200.226
interface coa-nas
vip-ip 209.165.200.226 vip-port 3799
exit
exit
endpoint sgw-service
replicas 1
nodes 1
exit
endpoint dns-proxy
replicas 1
exit
endpoint sbi
replicas 1
nodes 1
interface nrf
exit
exit
exit
logging transaction message enable
logging transaction duplicate enable
logging level application trace
logging level transaction trace
logging level tracing debug
logging name infra.application.core level application warn
logging name infra.application.core level tracing warn
logging name infra.config.core level application trace
logging name infra.config.core level transaction trace
logging name infra.config.core level tracing off
logging name infra.dispatcher.core level application warn
logging name infra.dispatcher.core level transaction warn
logging name infra.dispatcher.core level tracing warn
logging name infra.heap_dump.core level application warn
logging name infra.ipcstream.core level application error
logging name infra.ipcstream.core level transaction warn
logging name infra.ipcstream.core level tracing warn
logging name infra.memory_cache.core level application error
logging name infra.memory_cache.core level transaction error
logging name infra.message_log.core level transaction trace
logging name infra.resource_monitor.core level application warn
logging name infra.resource_monitor.core level transaction warn
logging name infra.rest_server.core level application error
logging name infra.rest_server.core level tracing off
logging name infra.topology.core level application off
logging name infra.topology.core level transaction off
logging name infra.topology.core level tracing off
deployment
app-name cnsgw-smf-1
cluster-name Local
dc-name DC
model small
logical-nf-instance-id 1
exit
k8 label protocol-layer key smi.cisco.com/vm-type value smf-proto-1
exit
k8 label cdl-layer key smi.cisco.com/node-type value smf-cdl-1
exit
k8 label oam-layer key smi.cisco.com/node-type value oam
exit
instances instance 1
system-id smf
cluster-id smf
slice-name 1
exit
local-instance instance 1
system mode running
helm default-repository roaming-ph2
helm repository cnsgw-1
access-token dev-deployer.gen:AKCp5ekcXA7TknM9DbLASNBw4jwVEsx9Z9WpQwEvCvCQ2mJhLymcz6BfbH38YJiWC6fn1cKmw
url https://engci-maven-master.cisco.com/artifactory/smi-fuse-internal-snapshot/mobile-cnat-cn/cn-products/master/
exit
helm repository roaming-cx
url https://engci-maven-master.cisco.com/artifactory/mobile-cnat-charts-release/releng-builds/2021.03.m0.d4.0/ccg/2021.03.m0.d4.0.i77/ccg.2021.03.m0.d4.0.i77/
exit
helm repository roaming-ph2
url https://engci-maven-master.cisco.com/artifactory/smi-fuse-internal-snapshot/mobile-cnat-cn/cn-products/dev-smf-amigos/
exit
k8s name cnsgw-smf-1
k8s namespace cnsgw-1
k8s nf-name smf
k8s registry dockerhub.cisco.com/smi-fuse-docker-internal
k8s single-node true
k8s use-volume-claims false
k8s ingress-host-name 209.165.200.238.nip.io
aaa authentication users user admin
uid 117
gid 117
password $1$bQRuPxWc$ESF/KLDQBkmdQNtrReTJN1
ssh_keydir /tmp/admin/.ssh
homedir /tmp/admin
exit
aaa authentication users user liadmin
uid 201
gid 2011
password $1$LugH/seF$hi4y0QnpOZoEiJDqGLd0L.
ssh_keydir /tmp/liadmin/.ssh
homedir /tmp/liadmin
exit
aaa authentication users user liadmin2
uid 202
gid 2021
password $1$HBRlXp0W$pmaMFhDV9QIayXTxEZtxc0
ssh_keydir /tmp/liadmin2/.ssh
homedir /tmp/liadmin2
exit
aaa authentication users user liadmin3
uid 203
gid 2031
password $1$kE6v4ZBD$sv97OlhMCmTtjm7Q35Esq1
ssh_keydir /tmp/liadmin3/.ssh
homedir /tmp/liadmin3
exit
aaa ios level 0
prompt "\h> "
exit
aaa ios level 15
prompt "\h# "
exit
aaa ios privilege exec
level 0
command action
exit
command autowizard
exit
command enable
exit
command exit
exit
command help
exit
command startup
exit
exit
level 15
command configure
exit
exit
exit
nacm write-default deny
nacm groups group LI
user-name [ liadmin ]
exit
nacm groups group LI2
user-name [ liadmin2 ]
exit
nacm groups group LI3
user-name [ liadmin3 ]
exit
nacm groups group admin
user-name [ admin ]
exit
nacm rule-list admin
group [ admin ]
rule li-deny-tap
module-name lawful-intercept
path /lawful-intercept
access-operations *
action deny
exit
rule li-deny-clear
module-name tailf-mobile-smf
path /clear/lawful-intercept
access-operations *
action deny
exit
rule any-access
action permit
exit
exit
nacm rule-list confd-api-manager
group [ confd-api-manager ]
rule any-access
action permit
exit
exit
nacm rule-list ops-center-security
group [ * ]
rule change-self-password
module-name ops-center-security
path /smiuser/change-self-password
access-operations exec
action permit
exit
rule smiuser
path /smiuser
action deny
exit
exit
nacm rule-list lawful-intercept
group [ LI LI2 LI3 ]
rule li-accept-tap
access-operations *
action permit
exit
rule li-accept-clear
access-operations *
action permit
exit
exit
