The SMF maintains the following metrics as part of the Diameter endpoint.
diameter_request_message_total
Description: Indicate the count of diameter requests processed by diameter endpoint.
![](https://www.cisco.com/content/dam/en/us/td/i/templates/note.gif)
Note
The peer_address counter is empty for inbound requests and depending on the point of failure, this counter can be empty for
the outbound requests.
The retry counter is always logged as zero for IPC timeout.
The transaction_type counter is hard-coded to "origin".
The endpoint_name counter is empty for inbound requests and depending on the point of failure, this counter can empty for
outbound requests.
Metrics Type: Counter
Default Level: MetricsVerboseLevelProduction
Label Details:
interface: gx, gy
message_name: ccri, ccru, ccrt, rar, asr peer_address
status: attempted, peer_down, err_cfg, err_maxout, timeout_ipc, err_ipc, err_unmarshal
retry: retry count gr_instance transcation_type
endpoint_name: name of endpoint profile used during processing
message_direction: inbound, outbound
Label Production:
interface
message_name
peer_address status
Label Debug:
retry
gr_instance
transaction_type
Label Trace:
endpoint_name
message_direction
diameter_response_message_total
Description: Indicate the count of diameter responses that the Diameter endpoint processes.
Note
The result_code counter is logged as " " for outbound responses, local failure, response timeout, and IPC timeout.
The action or subaction counter is empty for outbound responses and "success" responses.
outbound requests.
Label Details:
interface: gx, gy
message_name: ccai, ccau, ccat, raa, asa
peer_address
status: success, err_cfg, err_maxout, err_send, timeout_res, timeout_ipc, err_ipc, err_unmarshal, err_rc, err_exp_rc
result_code
action: continue, terminate
subaction: discard-traffic, local-fallback, retry-server-on-event, send-ccrt-on-call-termination, with-term-req, without-term-req
gr_instance
Label Production:
interface
message_name
peer_address status
status
result_code
Label Debug:
action
subaction
gr_instance
Label Trace:
endpoint_name
message_direction
diameter_response_message_seconds_total
Description: Indicate the cumulative response time in seconds of diameter requests that the Diameter endpoint processes.
Note
The result_code counter is logged as " for outbound responses, local failure, response timeout, and IPC timeout.
outbound requests.
This counter is not incremented for local failure or IPC timeout.
Label Details:
interface: gx, gy
peer_address
result_code
gr_instance
Label Production:
message_name
origin_host
origin_realm
disconnect_cause
result_code
Label Debug:
action
subaction
gr_instance
Label Trace:
endpoint_name
message_direction
diam_base_msg_total
Description: Indicate the count of diameter base message requests that the Diameter endpoint processes.
Note
The DPR counter is supported only for the DPR that is received from a peer.
The result_code counter is logged as 5012 if the DPR received has the mandatory AVP missing or if origin-host and origin-realm
in DPR does not match with destination-host and destination-realm in connection details.
Label Details:
Label Production:
message_name
origin_host
origin_realm
disconnect_cause
result_code
Label Debug:
Label Trace:
endpoint_name
message_direction
diam_base_msg_seconds_total
Description: Indicate the cumulative response time in seconds of diameter base message requests that the Diameter endpoint
processes.
Note
Label Details:
Label Production:
interface
message_name
diameter_dictionary_type
status
unknown_avp
Label Debug:
diameter_encode_message_total
Note
Label Details:
interface: gx, gy, ""
message_name: ccri, ccru, ccrt, raa, asa
dict_name
status: success, failure, partial
unknown_avp: 0, 1
gr_instance
Label Production:
interface
message_name
status
unknown_avp
Label Debug:
diameter_decode_message_total
Description: Indicate the count of decoding that the Diameter endpoint performed.
Note
The interface is empty for unsupported interface or command code.
The message_name counter is empty for the unsupported interface or command code
The dict_name counter is empty when default dictionary is used. Else, this counter indicates the name of dictionary that is
used for an operation.
The status counter is logged as failure only for the unsupported interface or command code. This counter is logged as partial
if an issue that is seen during the encoding is ignored. For example, an unknown AVP.
The unknown_avp counter indicates if any unknown AVPs are found during encoding, where zero indicates not found and 1 indicates
found.
Label Details:
message_name: ccai, ccau, ccat, rar, asr
dict_name
unknown_avp: 0, 1
gr_instance
Label Production:
interface
message_name
status
unknown_avp
Label Debug:
status_code
result_code
gr_instance
Label Trace:
diameter_pod_status
Description: Indicate the pod status as active or standby.
Note
Value 1 indicates the status as active and zero indicates the status as standby.
The VIP counter is not used to determine the pod status when a Diameter pod is running in server mode. In this case, VIP is
empty in the server mode.
Metrics Type: Gauge
Label Details:
Label Production:
Label Debug:
Label Trace:
dispatch_error_total
Description: Indicate the count of inbound requests that had error or timeout during dispatch to service.
Label Details:
application
command_code
error_code
gr_instance
Label Production:
application
command_code
error_code
Label Debug:
dispatch_error_seconds_total
Description: Indicate the cumulative time in seconds spent during dispatching of inbound requests to service that had error
or timeout.
Label Details:
application
command_code
error_code
gr_instance
Label Production:
application
command_code
error_code
Label Debug:
policy_engine_message_total
Description: Indicate the count of messages that are sent to service for which response is received.
Label Details:
application
command_code
gr_instance
Label Production:
Label Debug:
policy_engine_message_seconds_total
Description: Indicate the cumulative time in seconds spent during processing of a message sent to service.
Label Details:
application
command_code
gr_instance
Label Production:
Label Debug:
