GTPP Endpoint
Summary Data
Table 1. Summary Data
Applicable Products or Functional Area SMF
Applicable Platform(s) SMI
Feature Default Setting Enabled – Always-on
Related Documentation Not Applicable
Revision History
Table 2. Revision History
Revision Details Release
First introduced. 2023.03.0
Feature Description
The GTPP Endpoint is an App-infra-based service that enables the GPRS Tunneling Protocol Prime (GTPP) protocol functionality for the SMF service. The SMF with Legacy Interfaces supports the GTPP Charging (Gz) interface in the GTPP Endpoint.
For offline charging, the Gz is the reference point from a Charging Data Function (CDF) to the CGF for transporting of CDRs.
The GTPP Endpoint provides the following support to the SMF service:
  • Handles the usage and event accounting at a Bearer level and the accounting information gets stored as part of the subscriber session.
  • Generates CDR content from this accounting information and then transfers to the GTPP Endpoint. The GTPP Endpoint is responsible for encoding the received CDRs into ASN.1 (based on the configured dictionary).
  • Sends the received CDRs to the CGF server using the GTPP protocol.
For more information on this feature, see the UCC 5G SMF Configuration and Administration Guide > GTPP Endpoint chapter.
For more information on this feature, see the GTPP Endpoint chapter.
CDR Transport through GTPP
GTPP delivers Charging Dara Records (CDR) from the Charging Data Function (CDF), which generates CDRs to the Charing Gateway Function CGF(s). The GTPP protocol is required if the CGF resides outside the CDFs. It utilizes some aspects of GTP, which is used for packet data tunnelling in the backbone network.
GTPP operates on the Gz interface and peforms the following functions:
  • Transfers CDR between the CDF and the CGF.
  • Redirects CDRs to another CGF.
  • Detects communication failures between the communicating peers, using echo messaging.
  • Advertises to peers about its CDR transfer capability. For example, after a period of service downtime.
  • Prevents duplicate CDRs that might arise during redundancy operations. If configured, the CDR duplication prevention function is carried out by marking potentially duplicated CDR packets, and delegating the final duplicate deletion task to a CGF, or the Billing Domain.
Path Protocol
GTPP uses path protocol to transport CDRs from CDF to CGF over the Gz interface to facilitate charging. The UDP path protocols is supported for GTPP:
Note
Path Protocol TCP is not supported
  • Ports for signalling the request messages:
    • The UDP Destination Port with the server port number 3386 is reserved for GTPP. Alternatively, another port can be used as configured by O&M.
    • The UDP Source Port is a locally allocated port number for sending network element.
  • Ports for signalling the response messages:
    • The UDP Destination Port is the value of the Source Port of the corresponding request message.
    • The UDP Source Port is the value from the Destination Port of the corresponding request
GTPP Message Types
GTPP defines a set of messages between two associated nodes. The following table lists GTPP messages.
Table 3. GTPP Messages
Message Type Value (Decimal) GTPP Message
Echo Request
Echo Response
Version Not Supported.
Node Alive Request
Node Alive Response
6
Redirection Request
7
Redirection Response
240
Data Record Transfer Request
241
Data Record Transfer Response
Endpoint GTP Prime
The Endpoint GTP Prime is primarily used to set the storage size limit (default 1 GB), which is applicable when k8s use-volume-claim Pod is set to true. Though gtpp-profiles configuration alone brings up gtpp-ep pod, it is recommended to configure gtpprime endpoint as well, with basic configuration such as storage , or replica . This configuration is used by the gtpp-ep pod.
Ensure to configure GTPP profiles charging agent ip address and ports in the Endpoint under the Gz interface.
Note
The gtpp-ep always ignores nodes config. When k8s single-node is set to false, it spawns 2 replicas of gtpp-ep in the Active or Standby mode independent of replicas and nodes configuration.
GTPP Resiliency
The GTPP endpoint provides resiliency by supporting CDR archiving and file storage.
CDR Archiving
In an overload of CDRs scenario, the CGF server becomes slow in providing a response. This scenario leads to unacknowledged CDRs due to sendReqList buffer being full and then the CDRs drop. To avoid the CDR drop in such a case, the GTPP endpoint enqueues new CDRs into the archive list.
GTPP performs the CDR archiving in the following way:
  • The archive list flush happens in a paced manner depending on the network load condition.
  • After all the CGFs become inactive or due to back-to-back switchovers, an archive record is written into HDD in the paced manner to avoid losing the archived CDRs.
  • Archive list is replicated on standby GTPP endpoint pod.
Note
  • The archive list is maintained per GTPP profile level. The maximum size of the archive list is 5M.
  • After reaching the maximum configured size, the oldest record is purged and a new record is added.
  • Archive list gets replicated on the standby pod. When the active pod is inactive, the standby pod becomes the active pod and starts processing the CDRs to retain all the archive records.
CDR File Storage
GTPP performs the CDR file storage in the following way:
  1. When all the CGFs are inactive, all the CDRs are written into a file in HDD on the active GTTP endpoint.
  2. The CDRs are stored on the standby GTPP endpoint.
  3. After the inactive CGF becomes active, the CDRs are read from the file on the active GTPP endpoint and sent to the CGF.
  4. After all the CDRs are read from one file, the file gets deleted from the active GTPP endpoint. Then, the file delete replication information is sent to the standby GTPP endpoint.
  5. Standby GTPP endpoint deletes the file from HDD.
Note
During the CDR reading from HDD process, when some CDRs are sent to CGF and some CDRs are still in the file and the active GTPP endpoint becomes inactive, then the last read file is sent from the new active GTPP endpoint pod. The CGF receives various duplicate CDRs in such a case.
How it Works
This section describes how this feature works.
Call Flows
Information Elements Support
Following are the Information Elements (IEs) supported for the Gz support with GTPP feature.
Table 4. TLV and TV IEs
Information Element Description
TLV Information Elements
254
Address of Recommended Node
253
Requests Responded
252
Data Record Packet
251
Charging Gateway Address (this IE is also used in TS 29.060 [200])
250
Sequence numbers of Cancelled Packets
249
Sequence numbers of Released Packets
TV Information Elements
127
Charging ID
126
Packet Transfer Command
Standards Compliance
The GTPP endpoint support complies with the following Charging specific 3GPP standards:
  • 3GPP TS 32.251 "Telecommunication management;Charging management;Packet Switched (PS) domain charging"
  • 3GPP TS 32.295 "Telecommunication management; Charging management; Charging Data Record (CDR) transfer"
  • 3GPP TS 32.297 "Telecommunication management; Charging management; Charging Data Record (CDR) file format and transfer"
  • 3GPP TS 32.298 "Telecommunication management; Charging management; Charging Data Record (CDR) parameter description"
Limitations
The following are the limitations in the SMF with Diameter Interfaces Charging feature:
  • The SMF with Diameter Interface does not support Local storage mode, TCP, and Redirect Request or Responses.
  • The SMF with Diameter Interfaces supports only the custom24 CDR Dictionary.
  • In case of switchover, only the new CDR Send Request buffer is checked on the new standby GTPP pod.
  • In case of switchover, only the new archive is checked on the new stand by GTPP pod.
  • In case of double fault, old archive CDR and old Send Request buffer are lost.
Configuring the GTPP Profile
To configure the GTPP profile, use the following configuration:
config
   profile gtpp-profile profile_name gtpp
      dictionary
      ignore  ignore_value
      instance-id
         charging-agent address IPv4_adress port UDP_port
         server{ cgf address IPv4_adress max-cdrs max_cdrs { node-alive Enable | Disable}
               port UDP_port priority priority deadtime time_interval
               echo-interval  echo_interval timeout timeout_val max-retry
               max_retry max-pdu-size max_pdu_size wait-time time_interval }
      local-storage
      mode
         local
         streaming-parallel
      cgf-server-redundancy-support
     exit
  exit
exit
NOTES:
  • dictionary : Specify a dictionary for ASN.1 based encoding of a CDR.
  • ignore ignore_value : Specify the configuration to ignore the echo-rc-change. This CLI control option provides a flexibility to detect a CGF path failure due to a change in the echo response RC.
  • instance-id : Specify the instance ID of a GR instance.
    • charging-agent : Configure the charging agent.
      • addressIPv4_address : Specify the IP address of the interface configured within the endpoint that is used to transmit CDR records to the CGF.
      • port : Specify the UDP port.
        Note
        The Charging agent IP address and port configured in GTPP profiles should also be configured in the endpoint gtpprime under the Gz interface. The Runtime configuration update of the Charging agent IP address and port is not recommended. Ensure to add new profile with new Charging agent IP address and port.
    • server : Configures server details.
      • cgf : Configure the CGF server with the following parameters:
        • address IPv4_address: Enter the IPv4 address of CGF server, using dotted-decimal notation range.
        • max : Configure maximum number of unacknowledged CDRs for a CGF. Must be an integer ranging from 1 to 2000.
          Note
          The runtime configuration change of max is not recommended. Follow the Method of procedure:
          1. Delete the cgf having old max and then commit the change.
          2. Add the cgf again with a new max value.
        • node-alive Enable | Disable : Enable or disable sending Node Alive Request to a GTPP Server (such as CGF).
        • port : Specify which port that the CGF is using.
        • priority : Specify the relative priority of this server when system is selecting which CGF server to use.
    • deadtime : Configure the deadtime in seconds. Must be an integer ranging from 1 to 65535. Default value is 120.
    • max-cdrs : Designate the maximum number of CDRs in a GTPP message. Must be an integer ranging from 1 to 255.
    • max-pdu-size : Designate the maximum size of the PDU, in bytes. Must be an ranging from 1024 to 1460.
    • timeout : Specify the number of times the system attempts to communicate with a CGF that is not responding.
    • wait-time : Specify the time to wait before sending the GTPP request.
  • local-storage : Specify local storage details.
  • mode : Specify a storage mode to be used.
    • local : Specify the use of HDD to store CDRs
    • streaming-parallel : Specify the use of HDD to store CDRs, if CGF fails. When CGF comes up, stream the CDRs to the CGF. Streaming is in a parallel and newly generated CDRs are sent to CGF along with CDRs streamed from HDD.
  • cgf-server-redundancy-support : Enable or disable the CGF server redundancy support per GTPP profile. By default this configuration is disabled.
Configuration Example
The following is an example configuration for GTPP profile.
profile gtpp-profile pf2 gtpp
 dictionary custom24
 mode       streaming
 cgf-server-redundancy-support disable
 instance-id 1
  charging-agent
   address 10.10.10.205
   port    3386
  exit
  server
   max-pdu-size  1460
   timeout       30
   max-retry     3
   max-cdrs      5
   wait-time     30
   echo-interval 60
   deadtime      120
   cgf address 10.10.10.80 port 3386 max 100 priority 1 node-alive disable
   cgf address 10.10.10.90 port 3386 max 100 priority 2 node-alive disable
  exit
 exit
exit
Verifying GTPP Profiles
Use the show running-config profile gtpp-profile pf2 gtpp command to verify the GTPP Profile configuration.
The following is an example output of the show running-config profile gtpp-profile pf2 gtpp command.
 dictionary custom24
 mode       streaming
 instance-id 1
  charging-agent
   port    3386
  exit
  server
   max-pdu-size  1460
   timeout       30
   max-retry     3
   max-cdrs      5
   wait-time     30
   echo-interval 60
   deadtime      120
  exit
 exit
exit
Configuring the GTPP Endpoint
Note
  • GTPP-EP pod uses this configuration.
  • GTPP-EP pod always ignores nodes configuration.
  • When the k8s single-node is set to false, it spawns two replicas of a GTPP-EP pod in active or standby mode, which is independent of replicas and nodes configuration.
  • When the k8s single-node is set to true, the configured replicas have its impact.
  • When the k8s use-volume-claim is set to true, endpoint GTP prime is used to set the storage size limit. Default value of storage size limit is one GB.
  • When the system is up and running, we can't change the storage size.
To configure a GTPP endpoint, use the following commands:
config
 instance instance-id instance_id
   endpoint gtpprime
      storage storage_capacity
      replicas replicas_count
      nodes nodes_count
      interface Gz
        vip-ip   vip_ip vip-port vip-port vip-interface vip-interface vrf vrf
      end
NOTES:
  • endpoint gtpprime : Specifiy the following parameters to configure an endpoint:
    • storage storage_capacity —Specify the storage size of persistent volume in GB. Must be an integer in the range of 1-100.
      Note
      CLI doesn't allow changing storage size while the system is running. To change the storage size, bring the system down first.
    • replicas replicas_count —Specify the number of replicas per node. Must be an integer.
    • nodes nodes_count —This property is ignored. You may skip configuring it.
    • interface Gz : Configure the Gz interface details, such as vip IPv4 address, vip port, vip interface, and virtual routing and forwarding details.
      Note
      When the system is active and under the Gz Interface, if there are any add or update vip configurations to use new values, ensure to restart the udp-proxy.
The following is an example configuration for the endpoint gtppprime configuration:
instance instance-id 1
 endpoint gtpprime
  replicas 1
  nodes    1
  storage  1
  interface gz
   vip-ip 10.10.10.205 vip-port 7202 vip-interface v303 vrf GTPP-VRF
  exit
 exit
exit
Verifying GTPP Endpoints
Use the show gtpp-ep endpoints command to verify the GTPP Enpoints.
The following is an example output of the show gtpp-ep endpoints command.
result List of gtpp pods with their names and IPs
gtpp-ep-0		192.168.42.116
gtpp-ep-1		192.168.42.126
Verifying GTP Prime Configuration
Use the show running-config instance instance-id 1 endpoint gtpprime command to verify the GTP Prime configuration.
The following is an example output of the show running-config instance instance-id 1 endpoint gtpprime command.
 endpoint gtpprime
  replicas 1
  nodes    1
  storage  1
  interface gz
  exit
 exit
exit
