SMF Interface for Metrics
Summary Data
Feature Summary
Applicable Product(s) or Functional Area
SMF
Applicable Platform(s)
SMI
Feature Default Setting
Enabled – Always-on
Related Changes in this Release
Not Applicable
Related Documentation
Not Applicable
Revision History
Table 1. Revision History
Revision Details Release
First introduced. Pre-2020.02.0
Feature Description
SMF uses Prometheus for gathering statistics/counters from its microservices.
Grafana is used as the user interface to view metrics. It pulls the data from the Prometheus data store. Default graphs for KPI are available using Grafana for rendering a graphical view of the statistics with timelines.
For each microservice, counters and a set of labels are defined. Counters are incremented/decremented with the set of labels depending on the functionality.
The following snapshot is a sample of the Grafana dashboard.
Figure 1. Grafana Dashboard
SMF Rest EP Microservice
This section describes the supported counters and set of labels for the SMF Rest EP microservice.
Counters
The SMF REST EP microservice includes the following counters:
Table 2. SMF REST EP Microservice Counters
Number
Metric
Description
smf_restep_http_msg_total
This counter is incremented with every HTTP message received/sent at rest-ep microservice.
smf_restep_http_msg
This counter is incremented with every HTTP message received/sent at rest-ep microservice along with the time taken to serve the message.
Labels
The SMF REST EP microservice includes the following labels for the counters:
Table 3. SMF REST EP Microservice Labels for Counters
Number
Label
Description
NF TYPE
This label can be any 5G Node that interacts with SMF. For example: AMF, PCF, NRF
MESSAGE DIRECTION
Displays the direction of the HTTP message with respect to the REST EP microservice. The possible values are:
“inbound”
“outbound”
API NAME
Displays the service name being served. It can be:
"register_ue"
"deregister_ue"
"subscription_req"
"nf_registration"
"nf_discovery"
"slice_selection"
"amf_create_sm_context"
"amf_update_sm_context"
"amf_release_sm_context"
"amf_n1_n2_transfer"
"pcf_sm_policy_control_create"
"pcf_sm_policy_control_update"
"pcf_sm_policy_control_delete"
"pcf_sm_policy_control_update_notify"
"pcf_sm_policy_control_terminate_notify"
NF URI
Displays the rest-ep URI used in the HTTP message (can be FQDN).
RESPONSE STATUS
Displays the HTTP Response. It can be any 2xx, 4xx or 5xx response.
SMF Service
This section describes the supported counters and set of labels for the SMF service.
Labels
The SMF service includes the following labels for the counters:
Table 4. SMF Service Labels for Counters
Number
Label
Description
PROCEDURE TYPE
This label can take any value depending on the type of procedure queried for:
"pdu_sess_create"
"ue_req_pdu_sess_mod"
"smf_req_pdu_sess_mod"
"pcf_req_pdu_sess_mod"
"ue_req_pdu_sess_rel"
"smf_req_pdu_sess_rel"
"pcf_req_pdu_sess_rel"
"amf_req_pdu_sess_rel"
STATUS
Displays the status type. The possible values are:
“attempted”
“success”
“failure”
PDU CONNECTION TYPE
Displays the PDU connection type. The possible values are:
“ipv4”
“ipv6”
“ipv4v6”
PDU STATE
Displays the PDU state. The possible values are:
“idle”
“connected”
SMF Protocol Microservice
This section describes the supported counters and set of labels for the SMF Protocol microservice.
Counters
The SMF service includes the following counters:
Table 5. SMF Service Counters
Number
Metric
Description
smf_service_stats
This counter is incremented with every query made to the smf-service.
smf_service_counters
This is a gauge counter and can be incremented/decremented based on the functionality with every query made to the smf-service.
Labels
The SMF Protocol service includes the following labels for the counters:
Table 6. SMF Protocol Service Labels for Counters
Number
Label
Description
MESSAGE NAME
This label can take any value depending on the procedure queried for:
"session_establishment_req"
"session_establishment_res"
"session_modification_req"
"session_modification_res"
"session_report_req"
"session_report_res"
"session_deletion_req"
"session_deletion_res"
"association_setup_req"
"association_setup_res"
"association_update_req"
"association_update_res"
"association_release_req"
"association_release_res"
"prime_pfd_management_req"
"prime_pfd_management_res"
"heartbeat_req"
"heartbeat_res"
"node_report_req"
"node_report_res"
MESSAGE DIRECTION
“inbound”
“outbound”
STATUS
Displays the status of the message. The possible values are:
“accepted”
“denied”
“discarded”
Converged Core Refactoring Changes
This section describes the changes related to converged core refactoring in this chapter.
For the SMF Protocol service, the "n4" prefix in the procedure names for the "Message Name" label is removed.
