RADIUS Client for SMF
Summary Data
Table 1. Summary Data
Applicable Product(s) or Functional Area SMF
Applicable Platform(s) SMI
Feature Default Setting Disabled – Configuration Required
Related Changes in this Release Not Applicable
Related Documentation Not Applicable
Revision History
Table 2. Revision History
Revision Details Release
Added support for the following:
  • PAP, CHAP, and MSCHAP-based RADIUS authentication
  • Multiple RADIUS NAS-IP source addresses
  • Handling RADIUS Disconnect and CoA Requests
  • RADIUS Accounting on SMF
  • New attributes in the RADIUS Access Response message
2020.02.5.t1
First introduced.
Pre-2020.02.0
Feature Description
Remote Authentication Dial-In User Service (RADIUS) is a client and server protocol. The RADIUS client is typically a Network Access Server (NAS) and the RADIUS server is usually a daemon process running on a UNIX or Windows NT machine. The client passes user information to designated RADIUS servers and acts on the response that is returned. RADIUS servers receive user connection requests, authenticate the user, and then return the configuration information necessary for the client to deliver service to the user.
RADIUS provides Authentication and Accounting services to the users. The SMF provides the following configuration support to —
  • add RADIUS server details
  • enable RADIUS accounting and authentication
  • add RADIUS interface as an option for virtual APN configuration within DNN profile
  • enable CC trigger reporting
  • define volume and time limits
The RADIUS Client feature supports the following functions:
  • Server Selection
    RADIUS servers are configured with IP:Port as the key. The algorithm CLI specifies the failover or load balancing algorithm to select the RADIUS server to which the authentication or accounting request must be sent. Servers that are marked "dead" are not considered for selection until they are marked "alive". The supported algorithms are first-server and round-robin.
    • First-server—Specifies that the request must be sent to RADIUS server with the highest priority. If the server becomes unreachable, the request is sent to the server with the next highest configured priority. This is the default algorithm.
    • Round-robin—Specifies that the request must be sent based on load balancing in a circular queue manner. The server that is last used is stored to maintain the round-robin selection. The order of the list is purely based on the configuration sequence.
  • Monitor Server and Dead Server Detection
    Monitor Server revisits the server database and marks the server which has not received response beyond the configured "response-timeout" value after the first request is sent. The server is marked "dead" and remains in dead-state for minutes configured as "deadtime". After the "deadtime" elapses, the server's dead-variable is reset again to mark it as ready to process requests. If the server is still not reachable, it is marked "dead" as part of the next request response timeout.
  • Timeout and Retry
    After a server is selected and request is sent to the server, an entry is maintained in the request queue until response is received from the RADIUS server or until timeout occurs. Monitor Requests is called to check on the requests queue for response timeouts and retry. It walks through all the entries and checks if any request timeout value configured as "timeout" is hit. For such requests, if the number of retries is less than the configured "max-retries" value, the request is resent to the RADIUS server. Else, if the "max-retries" count is reached, the request is deleted from the request queue. After a request is deleted, even if response comes for such requests, the response is discarded and not sent to the user.
Architecture
RADIUS Integration in Mobile CNAT Architecture
The Mobile CNAT architecture has four distinct layers:
  1. Cloud—Host OS + Kubernetes installation.
  2. Runtime—Plugins to Kubernetes provided by the Cloud. This layer includes the container runtime (docker version) and Kubernetes plugins for volume (storage), networking, and load balancing.
  3. Orchestration—Kubernetes functionality. Kubernetes provides abstractions for provided plugins (networking, volumes, load balancing) so that the CNAT components can be unware of them.
  4. Mobile CNAT Components—Application layer where the applications are built for mobility depending only on Kubernetes as much as possible.
5GC Network Functions (NFs) run in the Application or CNAT Component layer of this architecture. RADIUS Client is an integral part of the SMF.
RADIUS Client Integration in SMF
The SMF consists of loosely coupled microservices. The microservice decomposition is based on the following three-layered architecture:
  1. Layer 1—Protocol and Load Balancer services (stateless)
  2. Layer 2—Application services (stateless)
  3. Layer 3—Database services (stateful)
The Protocol layer integrates with the RADIUS Client POD.
The following figure illustrates the integration of RADIUS Client in SMF.
Figure 1. RADIUS Client Integration
Radius-EP App (RADIUS-Client POD)—The RADIUS Client functionality is added in a new POD. It handles RADIUS protocol-specific functions such as authentication and accounting.
SMF Service App (SMF Service POD)—The SMF Service App provides PDU session service. During session establishment, the SMF service decides if the secondary authentication is required or not, and acts accordingly.
UDP-Proxy App (UDP-Proxy POD)—The UDP-Proxy App is enabled with host-networking and, sends and receives packets using external Virtual-IPs. All RADIUS packets are transmitted and received from an outside cluster using this application.
RADIUS Authentication
Authentication and key management are fundamental to the security of mobile networks because they provide mutual authentication between users and the network.
5G defines various authentication methods to authenticate a user. In the 5G architecture, the serving network authenticates the Subscription Permanent Identifier (SUPI), and key agreement between the UE and the network using primary authentication mechanism.
5G supports EAP-based secondary authentication between the UE and the network. The SMF performs the role of the EAP Authenticator and relies on external AAA server (for example, RADIUS server) to authenticate and authorize the UE’s request for PDU session establishment.
The RADIUS Client function resides within the SMF to enable the generic Cloud Native 5G RADIUS functionality for authentication purposes. When the RADIUS Client feature is enabled, the SMF performs secondary authentication with the configured external RADIUS server as per 3GPP TS 23.501.
For information on enabling the RADIUS Client feature, see Configuring the RADIUS Client.
RADIUS Accounting
Accounting collects and sends subscriber usage and access information used for billing, auditing, and reporting. For example, user identities the start and stop times, performed actions, number of packets, and number of bytes. Accounting enables an operator to analyze the services that the users access and the amount of network resources they consume. Accounting records comprise accounting Attribute Value Pairs (AVPs) and are stored on the accounting server. This accounting information can then be analyzed for network management, client billing, and/or auditing.
The SMF implements the RADIUS Accounting functionality through the use of CLI configuration. For more details on the configuration, see Configuring the RADIUS Client.
If the RADIUS accounting is enabled and server-group is configured within the DNN profile, the SMF sends server-group as AAA group in charging-params in N4 session establishment request. When the SMF sends AAA group which is not present on UPF, then it does not account the traffic for static and predefined rules in RADIUS URR and fails to report. In this scenario, the SMF considers only the dynamic rules traffic for accounting in the RADIUS URR.
RADIUS Access Management
RADIUS supports the following timeout functionality:
  • Idle Timeout—The SMF supports CP-Idle-Timeout which handles the Idle Timeout functionality of Control-Plane. The same functionality is leveraged for the idle timeout value received in the Radius-Access-Accept message.
    The RADIUS returned values have higher precedence over the configuration unless there is a specific configuration to choose between RADIUS returned values and the pre-existing configuration in SMF.
  • Session Timeout—The SMF supports Absolute-Session-Timeout which handles the Session Timeout functionality of a session. This functionality is leveraged for the session timeout value received in the Radius-Access-Accept message.
RADIUS NAS-IP Support
SMF supports the RADIUS NAS-IP address functionality for accounting and authentication requests.
In releases prior to 2021.1.0, only one common RADIUS NAS-IP address was used for all requests. This feature is extended to support multiple RADIUS NAS-IP source addresses.
The NAS-IP configuration is supported at the following levels:
  • Global NAS-IP
  • Global accounting NAS-IP
  • Per server-group common NAS-IP
  • Per server-group accounting NAS-IP
The selected NAS-IP is encoded in authentication or accounting requests as per RFC2865 and is also used in the "source-ip" address of outbound UDP packets. This feature supports only the IPv4 NAS-IP address.
For more information, see the Configuring RADIUS NAS-IP section.
Dynamic Authorization Client (DAC) initiates Disconnect-Request packet through UDP port to terminate the user session(s) on Network Access Server (NAS). It also discards all the associated session contexts.
The NAS responds with a Disconnect-ACK message if the session is identified, removed, and no longer valid. The NAS sends a Disconnect-NAK message if it is unable to disconnect the session.
This feature uses a combination of the following session keys to identify the sessions for termination:
  • 3GPP-IMSI + 3GPP-NSAPI
  • ACCT-SESSION-ID
  • CALLED-STATION-ID (DNN) + FRAMED-IP-ADDR
  • CALLED-STATION-ID (DNN) + FRAMED-IPV6-PREFIX
Important
If multiple key combination is provided for the same session, it is accepted. However, if the multiple key combination leads to multiple session contexts or non-existing session context, the behavior is non-deterministic.
The SMF supports only one session context per Disconnect-Message (DM) request. The SMF supports the following attributes in the DM request to identify the NAS and the user sessions to be terminated.
Attribute Reference Specification Encoding Type
3GPP-IMSI 3GPP 29.061 - 16.4.7.2-1 String
3GPP-NSAPI
3GPP 29.061 - 16.4.7.2-10
3GPP 29.561 – 11.3
String
Accounting-Session-Id RFC2866 String
FRAMED-IP RFC2865 - 5.1 IPV4 Address
FRAMED-IPV6-PREFIX
RFC3162
PrefixLen & String
RFC2865 - 5.30
String
NAS-IP-Address
RFC2865 – 5.4 (optional)
String
NAS-Identifier
RFC2864 – 5.32 (optional)
String
The SMF silently discards other attributes present in the DM request if the packet decoding is successful.
The SMF supports the following attributes in the DM ACK or NAK response.
ERROR-CAUSE RFC5176 – 3.5 Integer
REPLY-MESSAGE RFC2865 – 5.18 String
The RADIUS endpoint (radius-ep) pod supports the following error codes if the Disconnect Request is rejected by radius-ep:
  • 402 (Missing Attribute) - Triggered due to invalid key combination
  • 403 (NAS Identification Mismatch) - Triggered if NAS-IP attribute in DM request does not match the endpoint COA-NAS VIP-IP or if NAS-Identifier attribute in the request does NAS identifier configuration within RADIUS Dynamic Authorization or CoA configuration
  • 407 (Invalid Attribute) - Triggered due to format error, encode error, and so on
  • 405 (Unsupported Service) - Triggered if the request is not a disconnect request
  • 503 (Session Context Not Found) - Triggered if the session cannot be located
For more information on configuring this feature, see the Configuring the Session Disconnect Feature section.
How it Works
This section describes how the SMF supports RADIUS authentication and accounting functionality.
RADIUS Interaction for Authentication
The RADIUS server supports various methods to authenticate the user. When the server is provided with the username and original password of the user, it can support Point-to-Point Protocol (PPP), Password Authentication Protocol (PAP), Challenge-Handshake Authentication Protocol (CHAP), or Microsoft CHAP (MSCHAP), UNIX login, and other authentication methods.
In releases prior to 2021.01.0: The SMF uses only MSISDN values for user authentication.
In release 2021.01.0 and later: The SMF supports user authentication using PAP, CHAP, or MSCHAP protocol. The SMF configuration aids in the protocol selection for the user authentication. If the secondary authentication is enabled in DNN profile, the SMF interacts with the RADIUS server to perform RADIUS authentication. To implement the authentication, the RADIUS client residing within the SMF sends the User-Name and User-Password attributes in Access-Request message to the RADIUS server.
The SMF uses more attributes to facilitate the RADIUS authentication function. For the complete list of attributes supported, see the RADIUS Attribute Definition section.
The RADIUS server validates the user with the authentication information. If the validation is successful, the server sends the Access-Accept response to the SMF.
PAP-, CHAP-, MSCHAP-based Authentication
The SMF decodes the Protocol Configuration Options (PCO), Extended PCO (ePCO), or Additional PCO (APCO) IE received from UE. Then, the SMF retrieves the values related to PAP (User Name and Password), CHAP (Challenge and Response), or MSCHAP (Challenge and Response) from the IE. If any of the protocols have higher precedence in configured priority under DNN, the SMF sends the received values in RADIUS Access-Request message to the RADIUS server.
Note
The SMF does not include the authentication information received from the UE in the RADIUS Access-Request message if the priority is not configured.
By default, the SMF uses the configured host password under DNN for authentication until additional configuration is enabled to use the password received in PCO, ePCO, or APCO. The SMF allows the operator to configure the host password at DNN profile either in plain-text or encrypted form and always displays the same in encrypted format only wherever applicable.
The SMF sends MSISDN as the User Name if the UE does not provide the username explicitly in PCO IE for PAP-based authentication.
For CHAP-based authentication, the SMF converts the received CHAP Challenge and Response to MSCHAP if the convert-to-mschap command option is enabled, CHAP is enabled, and the received CHAP Response length is 49 bytes. By default, the SMF uses MSCHAPv1 as the authentication algorithm.
For MSCHAP-based authentication, the SMF sends User Name, Challenge, and Response received in PCO to the RADIUS server if Protocol ID is LCP and LCP container specifies the algorithm as CHAP/MSCHAPv1 (128) as per RFC 2433 or CHAP/MSCHAPv2 (129) as per RFC 2795.
The SMF forwards the authentication information from RADIUS server to UE in Create-Session-Response PCO/EPCO/APCO IE for a 4G/Wi-Fi session, and in N1 Container EPCO IE for a 5G session.
Consider the following important points while implementing the RADIUS authentication functionality.
  • Perform the length validation of different AVPs applicable for this feature based on RFC 2865. Also, reject the authentication if any violation is identified.
    • The minimum length of CHAP Challenge is 5 bytes (even though it is 1 byte as per RFC 1334 and RFC 1994).
  • The SMF sends the received authentication information from UE to RADIUS server based on the configured authentication algorithm at DNN level. The SMF does not manipulate any data received from UE and it only applies the configurations related to authentication before sending the information to RADIUS server.
  • The SMF does not validate the use case of incrementing the Identifier value for every authentication as it does not allow multiple authentication during the PDU session lifetime.
  • The SMF sends the encrypted NULL (empty) password in Access-Request when it receives empty password from UE and no host level password configured at SMF or password-use-pco option is enabled.
  • The SMF falls back to the default authentication where Access-Request carries the configured server secret as User Password in the following scenarios:
    • If none of the algorithm preference is enabled with priority
    • If the UE provided information is not applicable for the configured algorithm preferences, if any
    • When the UE sends the empty PAP or CHAP containers without any data (the container length is 0)
  • The SMF rejects the authentication in the following scenarios:
    • When there is no other algorithm configured for authentication
    • Whenever there is a mismatch in CHAP identifier received in both CHAP Challenge and CHAP Response containers (the SMF currently copies the CHAP-ID from CHAP Challenge container)
      • CHAP-ID in CHAP Password must be taken from CHAP Response as per RFC 2865.
      • Response Identifier must be copied from the Identifier field of the Challenge Response as per RFC 1334.
      • Whenever the validation criteria of the current algorithm fails
  • The SMF allows to configure the same priority through CLI for different algorithms because configuring 0 explicitly disables the configuration. In this scenario, any one of the algorithms is considered and the selection is purely implementation dependent. It is the responsibility of operator to ensure different algorithms have different priorities to resolve the conflicts whenever UE sends multiple authentication containers to the SMF.
  • The SMF allows to configure the password-use-pco option without configuring PAP due to the limitation of Yang defined syntax format. The same is applicable for convert-to-mschap option. But the functionality will work only if the corresponding algorithm is enabled with the valid priority.
  • By default, the SMF encrypts the operator given Host level password using AES-128-CFB encryption algorithm, if it’s a plain-text. It ignores the encryption if the operator gives the already encrypted password which has to meet the AES-128-CFB encryption standard.
  • By default, the SMF considers the authentication algorithm as MSCHAPv1(128) whenever the received CHAP Challenge and Response converted to MSCHAP if received CHAP-Response length is 49 bytes and convert-to-mschap option is enabled.
  • The following are the list of MSCHAP specific AVPs supported at SMF and its RFC references:
    • MSCHAP-CHALLENGE (MSCHAP)  RFC2548 Section 2.1.2
    • MSCHAP-RESPONSE  RFC2548 Section 2.1.3
    • MSCHAP2-RESPONSE  RFC2548 Section 2.3.2
    • MSCHAP-ERROR  RFC2548 Section 2.1.5
    • MS-CHAP2-Success (RFC 2548, Section 2.3.3) is not supported as there is no clear information on MS-CHAP success AVP for v1 in RFC 2548.
  • When the RADIUS server sends both MSCHAP-Error and Reply-Message AVPs in Access-Reject message, the preference is given to MSCHAP-ERROR while filling the CHAP container for NACK in PCO/APCO/EPCO. MSCHAP-Error is common for both MSCHAPv1 and MSCHAPv2 algorithm and it is encapsulated in the Message field of the CHAP Failure container.
  • In MSCHAP, only the authentication functionality is supported.
Important
The SMF uses the inbuilt encryption algorithm “AES-128-CFB” for encrypting the host level password (outbound password) provided by NETCONF-YANG data model. The SMF Ops Center creates a global key, for AES-128-CFB encryption, which is used for encrypting the operator given plain-text password. It shares the key with all the pods via SSH for decrypting the encrypted data in the respective pods. The key is exported as a ENV variable “CONFD_AES_KEY” in SMF-SERVICE pod. If the operator wishes to configure the already encrypted password, then the AES-CFB-128 encrypted string should be prefixed with “$8$” as follows, $8$<encrypted-data> to indicate that the given input is already AES-128-CFB encrypted string to NETCONF-YANG model.
For CLI details associated with authentication, see the Configuring the RADIUS Client section.
RADIUS Authentication Attributes
RADIUS Access Request Attributes
The following table lists the supported attributes in the RADIUS Access-Request message.
USER-NAME RFC2865 - 5.1 String
PASSWORD RFC2865 - 5.2 Encrypted String
CALLING-STATION-ID RFC2865 - 5.31 String
CALLED-STATION-ID RFC2865 - 5.30 String
NAS-IP-ADDRESS RFC2865 - 5.4 IPv4 Address
NAS-IDENTIFIER RFC2865 - 5.32 String
SERVICE-TYPE RFC2865 - 5.6 Octets - 4 bytes
FRAMED-PROTOCOL RFC2865 - 5.7 Octets - 4 bytes
NAS-PORT-TYPE RFC2865 - 5.41 Octets - 4 bytes
NAS-PORT RFC2865 - 5.5 Octets - 4 bytes
3GPP-CHARGING-ID 3GPP 29.061 - 16.4.7.2-2 Octets - 4 bytes
3GPP-PDP-TYPE 3GPP 29.061 - 16.4.7.2-3 Octets - 4 bytes
3GPP-CHARGING-GATEWAY-ADDR 3GPP 29.061 - 16.4.7.2-4 IPv4 Address
3GPP-GPRS-NEG-QOS-PROFILE 3GPP 29.061 - 16.4.7.2-5 Special Encoded Octets
3GPP 29.274 - 8.7
3GPP-SGSN-ADDRESS 3GPP 29.061 - 16.4.7.2-6 IPv4 Address
3GPP-GGSN-ADDRESS 3GPP 29.061 - 16.4.7.2-7 IPv4 Address
3GPP-IMSI-MCC-MNC 3GPP 29.061 - 16.4.7.2-8 String
3GPP-GGSN-MCC-MNC 3GPP 29.061 - 16.4.7.2-9 String
3GPP-NSAPI
3GPP 29.561 – 11.3
String
3GPP-SELECTION-MODE 3GPP 29.061 - 16.4.7.2-12 String
3GPP-CHARGING-CHARACTERISTICS 3GPP 29.061 - 16.4.7.2-13 String
3GPP-SGSN-MCC-MNC 3GPP 29.061 - 16.4.7.2-18 String
3GPP-IMEISV 3GPP 29.061 - 16.4.7.2-20 String
3GPP-RAT-TYPE 3GPP 29.061 - 16.4.7.2-21 Octet - 1 byte
3GPP-USER-LOCATION
3GPP 29.061 - 16.4.7.2-22
3GPP 29.274 - 8.21-4, 8.21-5
3GPP 38.413 – 9.3.1.7, 9.3.3.10
3GPP-MS-TIMEZONE 3GPP 29.061 - 16.4.7.2-23 Special Encoded Octets
3GPP 29.274 - 8.44
3GPP-NEGOTIATED-DSCP 3GPP 29.061 - 16.4.7.2-26 Octet - 1 byte
CHAP-PASSWORD (CHAP)
RFC2865 – 5.3
String
CHAP-CHALLENGE (CHAP)
RFC2865 – 5.40
String
RFC2548 – 2.1.2
String
MSCHAP-RESPONSE
RFC2548 – 2.1.3
Octets
MSCHAP2-RESPONSE
RFC2548 – 2.3.2
Octets
MSCHAP-ERROR
RFC2548 – 2.1.5
String
REPLY-MESSAGE
RFC2865 – 5.18
String
Note
The WiFi call attributes are the same as the 4G call.
RADIUS Access Response Attributes
The following table lists the supported attributes in the RADIUS Access-Response message.
FRAMED-IP RFC2865 - 5.1 IPv4 Address
FRAMED-IPv6-PREFIX RFC3162 PrefixLen and String
IDLE-TIMEOUT RFC2865 - 5.28 Integer
SESSION-TIMEOUT RFC2865 - 5.27 Integer
Note
For complete description of the RADIUS authentication attributes, see the RADIUS Attribute Definition section in this guide.
Call Flows
RADIUS Authentication Call Flow
The following figure illustrates the end to end call flow between the SMF server and RADIUS-EP.
Table 3. RADIUS Authentication Call Flow
Step Description
Bringing up RADIUS-POD: Add the respective endpoint configuration, with VIP-IP similar to Protocol-EP VIP-IP. Add the RADIUS-server information to the profile-RADIUS configuration.
Add the secondary authentication configuration to the required DNN profiles.
During session-bringup, the DNN profile checks if secondary authentication is enabled after successful UDM validation.
  • If authentication is not enabled, continue with PCF.
  • If authentication is enabled, send inter-process communication (IPC) message to RADIUS-POD to authenticate the subscriber.
4 The RADIUS-POD prepares the Access Request packet that is destined to a configured RADIUS-server, sends the packet to UDP Proxy pod to proxy the packet out.
6 The UPD Proxy pod creates a socket (if not already present) and sends the packet to the RADIUS-server.
7 The RADIUS-server validates the Access Request. If accepted, it responds with the Access Accept message. Else, it responds with the Access Reject message.
8 The UDP Proxy responds to the respective RADIUS-EP instance.
9 The RADIUS-EP instance validates the response, fetches the framed-IP (if present), and updates the SMF-service.
10 The SMF-service, upon successful response from RADIUS-EP, continues with the PCF flow. Else, the SMF-service disconnects from the subscriber.
RADIUS Interaction for Accounting
The SMF exchanges the following messages with RADIUS server through the RADIUS-client RADIUS-EP.
  • Accounting-Request: This message carries any of the following packets to relay the accounting information to the RADIUS server.
    • Accounting Start packet: This packet describes the type of service being delivered and the user it is being delivered to.
      The SMF sends accounting-start packet during the session establishment procedure. The RADIUS Accounting server returns an acknowledgement upon receiving the accounting-start packet.
      For details on configuring the RADIUS Accounting, see Configuring the RADIUS Client section.
    • Accounting Stop packet: This packet describes the type of service that was delivered and optionally statistics such as elapsed time, input and output octets, or input and output packets.
      At the end of service delivery, the SMF sends the accounting-stop packet for all session deletion scenarios and when the RADIUS accounting is enabled during the call setup.
    • Accounting-Request Interim-Update: During the session, the SMF sends the updated cumulative usage report to the RADIUS accounting server.
  • Accounting-Response: For each successfully processed accounting request, the RADIUS server returns an accounting acknowledgment confirming the receipt of the information.
For CLI details associated with accounting, see the Configuring the RADIUS Client section.
RADIUS Accounting Attributes
The following table lists the RADIUS accounting attributes supported in the accounting-request message.
Attribute Reference Spec Encoding Type Supported Accounting Type
USER-NAME RFC 2865 - 5.1 String Start, Stop, Interim update
CALLING-STATION-ID RFC 2865 - 5.31 String Start, Stop, Interim update
CALLED-STATION-ID RFC 2865 - 5.30 String Start, Stop, Interim update
NAS-IP-ADDRESS RFC 2865 - 5.4 IPV4 Address Start, Stop, Interim update
NAS-IDENTIFIER RFC 2865 - 5.32 String Start, Stop, Interim update
SERVICE-TYPE RFC 2865 - 5.6 Octets - 4 bytes Start, Stop, Interim update
FRAMED-PROTOCOL RFC 2865 - 5.7 Octets - 4 bytes Start, Stop, Interim update
NAS-PORT-TYPE RFC 2865 - 5.41 Octets - 4 bytes Start, Stop, Interim update
NAS-PORT RFC 2865 - 5.5 Octets - 4 bytes Start, Stop, Interim update
3GPP-IMSI 3GPP 29.061 - 16.4.7.2-1 String Start, Stop, Interim update
3GPP-CHARGING-ID 3GPP 29.061 - 16.4.7.2-2 Octets - 4 bytes Start, Stop, Interim update
3GPP-PDP-TYPE 3GPP 29.061 - 16.4.7.2-3 Octets - 4 bytes Start, Stop, Interim update
3GPP-CHARGING-
GATEWAY-ADDR
3GPP 29.061 - 16.4.7.2-4 IPV4 Address Start, Stop, Interim update
3GPP-GPRS-NEG-
QOS-PROFILE
3GPP 29.274 - 8.7
Special Encoded Octets Start, Stop, Interim update
3GPP-SGSN-ADDRESS 3GPP 29.061 - 16.4.7.2-6 IPV4 Address
This attribute is not included in the 5G accounting-start message.
3GPP-GGSN-ADDRESS 3GPP 29.061 - 16.4.7.2-7 IPV4 Address Start, Stop, Interim update
3GPP-IMSI-
MCC-MNC
3GPP 29.061 - 16.4.7.2-8 String Start, Stop, Interim update
3GPP-GGSN-
MCC-MNC
3GPP 29.061 - 16.4.7.2-9 String Start, Stop, Interim update
3GPP-NSAPI 3GPP 29.061 - 16.4.7.2-10 String Start, Stop, Interim update
3GPP-SELECTION
-MODE
3GPP 29.061 - 16.4.7.2-12 String Start, Stop, Interim update
3GPP-CHARGING
-CHARACTERISTICS
3GPP 29.061 - 16.4.7.2-13 String Start, Stop, Interim update
3GPP-SGSN
-MCC-MNC
3GPP 29.061 - 16.4.7.2-18 String Start, Stop, Interim update
3GPP-IMEISV 3GPP 29.061 - 16.4.7.2-20 String Start, Stop, Interim update
3GPP-RAT-TYPE 3GPP 29.061 - 16.4.7.2-21 Octet - 1 byte Start, Stop, Interim update
3GPP-USER
-LOCATION
3GPP 29.274 - 8.21-5
3GPP-MS-TIMEZONE
3GPP 29.274 - 8.44
3GPP-NEGOTIATED
-DSCP
3GPP 29.061 – 16.4.7.2-26 Octet – 1 byte
This attribute is sent only if the associated configuration is present.
Acct-Status-Type RFC 2866 Start/Stop/Interim Start, Stop, Interim update
Accounting-Session-Id RFC 2866 String Start, Stop, Interim update
Acct-Delay-time RFC 2866 Octet Start, Stop, Interim update
Acct-Input-Octets RFC 2866 Integer Stop, Interim update
Acct-Output-Octets RFC 2866 Integer Stop, Interim update
Acct-Input-Gigawords RFC 2869 Integer Stop, Interim update
Acct-Output-Gigawords RFC 2869 Integer Stop, Interim update
Acct-Input-packets RFC 2866 Integer Stop, Interim update
Acct-Output-Packets RFC 2866 Integer Stop, Interim update
Acct-Session-Time RFC 2866 Integer Stop, Interim update
Acct-Terminate-Cause RFC 2866 String Stop
Framed-MTU RFC 2866 String Start, Stop, Interim update
3GPP-Session
-Stop-Indicator
3GPP 29.061 Bit String Stop
Framed-Ip-Addr RFC 2866 IPV4 Address Start, Stop, Interim update
Acct-Authentic RFC 2866 String Start, Stop, Interim update
EventTimeStamp RFC 2869 String Start, Stop, Interim update
Note
For complete description of the RADIUS accounting attributes, see the RADIUS Attribute Definition section in this guide.
Call Flows
This section describes the following call flows:
  • RADIUS Accounting Start Call Flow
  • RADIUS Accounting Stop Call Flow
  • RADIUS Accounting Interim-update Asynchronous Call Flow
  • RADIUS Accounting Interim-update Synchronous Call Flow
This section describes the call flow associated with the initiation of RADIUS accounting procedure.
Figure 2. RADIUS Accounting Start Call Flow
This section describes the call flow associated with the termination of RADIUS accounting procedure.
Figure 3. RADIUS Accounting Stop Call Flow
Asynchronous Accounting Interim-Update Call Flow
This section describes the call flow associated with the asynchronous interim-update request.
Figure 4. Asynchronous Accounting Interim-Update Call Flow
Synchronous Accounting Interim-Update Call Flow
This section describes the call flow associated with the synchronous interim-update request.
Figure 5. Synchronous Accounting Interim-Update Call Flow
Processing of Usage Reporting Rules
After enabling the RADIUS accounting, the SMF creates the Usage Reporting Rule (URR) and relays the rule to the UPF through the Create URR Information Element (IE). The Create URR IE is present in the N4 Session Establishment Request and it contains the volume and time limits as per the configuration.
The SMF associates the RADIUS URR only to the dynamic Packet Detection Rules (PDRs) and not for the static and predefined rules. With AAA group name in N4 session establishment request, the UPF associates the static and predefined PDRs with the RADIUS URR. The UPF sends the usage report for the RADIUS URR when the Volume limit or the Time limit is hit. Then, the SMF sends the usage in the Interim-Update Accounting-Request message to the RADIUS server.
The SMF receives the usage report for RADIUS URR in N4 Modification Response or N4 Deletion Response when any one of the following conditions are met:
  • CC event condition is hit and the SMF performs Query URR
  • Session Delete Response is sent
The SMF stores the values of Volume and Time thresholds reported for a previous session and reports the cumulative usage by adding the currently reported value to the stored value. The SMF sends the cumulative usage report in Accounting-Request Interim-Update and Accounting-Stop messages.
On receiving the usage report from UPF, the SMF identifies the URR IDs that are to be sent to the CHF server and to the RADIUS server. For example, if the URR ID is associated to “0x80 00 00 09”, then the SMF sends this URR ID to the RADIUS server, and the other URR IDs to the CHF server.
Dynamic Configuration Update
The SMF allows you to dynamically change the RADIUS accounting configuration without impacting the existing sessions.
The following table identifies the impact of dynamic update to the various RADIUS accounting configurations.
Table 4. Dynamic Update of RADIUS Accounting Configuration
Configuration
Dynamic Change
Impact on Existing Sessions
Enabling and disabling of RADIUS accounting configuration
Allowed at the system level
The existing sessions continue to use the old value.
CC trigger updates
Allowed as per current pod replica
The existing session uses the new value.
Volume and time limit changes
The detailed description of each attribute is as follows:
  • USER-NAME
    Description: String value encoded as per RFC 2865.
    • 5G call: GPSI value is used, with stripped-off "msisdn-"
    • 4G call: MSISDN value is used, with stripped-off "msisdn-"
      Note
      PAP, CHAP, and MSCHAP authentication methods are not supported in releases prior to 2020.02.x.
      In release 2020.02.x and beyond, the PAP, CHAP, and MSCHAP authentication methods are supported.
  • PASSWORD
    Description: Encrypted string value encoded as per RFC 2865.
    For both 5G and 4G calls, selected RADIUS server's "secret" is set as user-password.
  • CALLING-STATION-ID
    5G call: GPSI value is used, with stripped of "msisdn-"
    4G call: MSISDN value is used, with stripped of "msisdn-"
  • CALLED-STATION-ID
    For both 5G and 4G calls, DNN value is set as called-station-id.
  • NAS-IP-ADDRESS
    Description: IPv4 address value encoded as per RFC 2865.
    For both 5G and 4G calls, user-configured RADIUS Client interface-type's VIP-IP is used.
  • NAS-IDENTIFIER
    For both 5G and 4G calls, user-configured nas-identifier attribute value is used.
  • SERVICE-TYPE
    Description: 4-byte octet (int) value encoded as per RFC 2865.
    For both 5G and 4G calls, "FRAMED (2)" value is set.
  • FRAMED-PROTOCOL
    For both 5G and 4G calls, "GPRS-PDP-CONTEXT (7)" value is set.
  • NAS-PORT-TYPE
    For both 5G and 4G calls, "WIRELESS-OTHER (18)" value is set.
  • NAS-PORT
    For both 5G and 4G calls, the base value of respective instance is used. That is:
    0x4000... 0x407F is set for replica-0
    0x4080... 0x40FF is set for replica-1
  • 3GPP-IMSI
    Description: String value encoded as per 3GPP TS 29.061.
    5G call: SUPI value is used.
    4G call: IMSI value is used.
  • 3GPP-CHARGING-ID
    Description: 4-byte octet (int) value encoded as per 3GPP TS 29.061.
    For both 5G and 4G calls, charging-ID is set.
  • 3GPP-PDP-TYPE
    For both 5G and 4G calls, pdp-type is set as follows:
    • 0 = IPv4
    • 2 = IPv6
    • 3 = IPv4v6
  • 3GPP-CHARGING-GATEWAY-ADDR
    Description: 4-byte octet (IPv4-address) value encoded as per 3GPP TS 29.061.
    For both 5G and 4G calls, charging gateway address is set.
  • 3GPP-GPRS-NEG-QOS-PROFILE
    Description: Octets (special encoding) value encoded as per 3GPP TS 29.061 and 29.274.
    For 5G call, the values from default-qos profile of the system are used and the encoding is performed as follows:
    Table 5. Non-GBR case
    1-2 <Release indicator>- = "15" (UTF-8 encoded)
    3 "-" (UTF-8 encoded)
    4-5 ARP (UTF-8 encoded)
    6-7 5QI (UTF-8 encoded)
    8-9 UL Session-AMBR length (UTF-8 encoded)
    10-m UL Session-AMBR (UTF-8 encoded)
    (m+1) - (m+2) DL Session-AMBR length (UTF-8 encoded)
    (m+3) – n DL Session-AMBR (UTF-8 encoded)
    Table 6. GBR case
    1-2 <Release indicator> = "15" (UTF-8 encoded)
    8-9 UL MFBR length (UTF-8 encoded)
    10-m UL MFBR (UTF-8 encoded)
    (m+1)-(m+2) DL MFBR length (UTF-8 encoded)
    (m+3)-n DL MFBR (UTF-8 encoded)
    (n+1)-(n+2) UL GFBR length (UTF-8 encoded)
    (n+3)-o UL GFBR (UTF-8 encoded)
    (o+1) – (o+2) UL GFBR length (UTF-8 encoded)
    (o+3) - p DL GFBR (UTF-8 encoded)
    For 4G call, the values from the default-qos profile of the system are used and the encoding is performed as follows:
    Table 7. Non-GBR case
    1-2 <Release indicator>- = "08" (UTF-8 encoded)
    8-11 UL Session-AMBR (UTF-8 encoded)
    12-15 DL Session-AMBR (UTF-8 encoded)
    Table 8. GBR case
    1-2 <Release indicator> = "08" (UTF-8 encoded)
    8-11 UL MBR (UTF-8 encoded)
    12-15 DL MBR (UTF-8 encoded)
    16-19 UL GBR (UTF-8 encoded)
    20-23 DL GBR (UTF-8 encoded)
  • 3GPP-SGSN-ADDRESS
    For 5G call, the AMF address is set.
    For 4G call, the S-GW address is set.
  • 3GPP-GGSN-ADDRESS
    For both 5G and 4G calls, the SMF-Service IP is set.
  • 3GPP-IMSI-MCC-MNC
    For 5G call, SUPIs MCC and MNC values are set.
    For 4G call, IMSIs MCC and MNC values are set.
    MCC is first 3 bytes, MNC is next 2 or 3 bytes.
    If MCC value is any of the following, then MNC will be of 3 bytes, else MNC will be of 2 bytes.
    300 302 310 311 312 313 316 334 338 342 344 346 348 354 356 358 360 365 376 405 708 722 732
  • 3GPP-GGSN-MCC-MNC
    For both 5G and 4G calls, configured MCC and MNC value of SMF is used.
    MCC is first 3 bytes, and MNC is next 2 or 3 bytes.
  • 3GPP-SGSN-MCC-MNC
    For 5G call, AMFs MCC and MNC values are set.
    For 4G call, SGWs MCC and MNC values are set.
  • 3GPP-NSAPI
    For 5G call, QFI value from the defaultQos profile is set.
    For 4G call, EPS bearer ID is set.
  • 3GPP-SELECTION-MODE
    For both 4G and 5G calls, the value is set to "0".
  • 3GPP-CHARGING-CHARACTERISTICS
    For both 4G and 5G calls, generic charging character is set.
  • 3GPP-IMEISV
    For 5G call, PEI value is set.
    For 4G call, IMEI value is set.
  • 3GPP-RAT-TYPE
    Description: 1-byte octet encoded as per 3GPP TS 29.061.
    For 5G call, value "NR (51)" is set.
    For 4G call, value "EUTRAN (6)" is set.
    For WLAN call, value "WLAN (3)" is set.
  • 3GPP-USER-LOCATION
    Description: Special octet value encoded as per 3GPP TS 29.061.
    For 5G call, the following encoding logic is used:
    Location-Type
    Only TAI = 136
    Only NCGI = 135
    Both TAI + NCGI =137
    2-7
    TAI-Encoding (if present)
    8-15
    NCGI-Encoding (if present)
    TAI Encoding header:
    1 MCC digit 2 MCC digit 1
    2 MNC digit 3 MCC digit 3
    3 MNC digit 2 MNC digit 1
    4-6 TAC value
    NCGI Encoding header:
    4 SPARE NCI
    5-8 NR Cell Identifier (NCI)
    For 4G call, the following encoding logic is used:
    1 Location-Type
    Only TAI = 128
    Only ECGI = 129
    Both TAI + ECGI =130
    2-6 TAI-Encoding (if present)
    7-13 ECGI-Encoding (if present)
    4-5 TAC value
    ECGI Encoding header:
    4 Spare ECI
    5-7 EUTRAN Cell Identifier (ECI)
  • 3GPP-MS-TIMEZONE
    Timezone string (for example: -07:00+1) is encoded as two-byte value as mentioned in the following table.
    TIMEZONE
    The first byte timezone is encoded as per 3GPP 29.061, 3GPP 29.274, 3GPP 24.008, and 3GPP 23.040 (section 9.2.3.11).
    DAYLIGHT SAVING 0, or +1 or +2
    The second byte daylight consists of two bits used (00-0, 01-+1, 10-+2, 11 – Unused).
  • 3GPP-NEGOTIATED-DSCP
    For both 5G and 4G calls, DSCP configuration from DNN qos-profile configuration is used.
    Sub -> DNN profile -> QosProfile -> DSCPMap -> Qi5 value check -> ARP priority check
  • Acct-Status-Type
    Description: Enum value encoded as per RFC 2866. The value of this attribute can be one of the following:
    • 1 - Start
    • 2 - Stop
    • 3 - Interim Update
  • Acct-Delay-Time
    Description: Integer value encoded as per RFC 2866. This attribute represents the amount of time client is trying to send the accounting record.
  • Acct-Input-Octets
    Description: Integer value encoded as per RFC 2866. This attribute represents the amount of bytes received. This attribute contains 4 bytes.
    The SMF wraps values when the number crosses the maximum value.
  • Acct-Output-Octets
    Description: Integer value encoded as per RFC 2866. This attribute represents the amount of bytes transmitted. This attribute contains 4 bytes.
  • Acct-Input-Packets
    Description: Integer value encoded as per RFC 2866. This attribute represents the amount of packets received. This attribute contains 4 bytes.
  • Acct-Output-Packets
    Description: Integer value encoded as per RFC 2866. This attribute represents the amount of packets transmitted. This attribute contains 4 bytes.
  • Acct-Input-Gigawords
    Description: Integer value encoded as per RFC 2869. This attribute indicates how many times the Acct-Input-Octets counter has wrapped around 2^32 over the course of this service being provided. This value is incremented whenever Acct-Input-Octets is wrapped.
  • Acct-Output-Gigawords
    Description: Integer value encoded as per RFC 2869. This attribute indicates how many times the Acct-Output-Octets counter has wrapped around 2^32 over the course of this service being provided. This value is incremented whenever Acct-Output-Octets is wrapped.
  • Acct-Session-Id
    Description: String value encoded as per RFC 2866. This attribute represents the unique accounting ID of subscriber. The accounting ID is unique to make it easy to match start and stop records in a log file. The start and stop records for a given session MUST have the same Acct-Session-Id. An Accounting-Request packet MUST have an Acct-Session-Id.
    An Access-Request packet MAY have an Acct-Session-Id; if it does, then the NAS MUST use the same Acct-Session-Id in the Accounting-Request packets for that session. The Acct-Session-Id contains UTF-8 encoded 10646 characters.
  • Acct-Session-Time
    Description: Integer value encoded as per RFC 2866. This attribute represents the amount of time the subscriber is active.
  • Framed-MTU
    Description: This attribute indicates the Maximum Transmission Unit to be configured for the user, when it is not negotiated by some other means (such as PPP). The default value is 1500.
    It MAY be used in Access-Accept packets. It MAY be used in an Access-Request packet as a hint by the NAS to the server that it would prefer that value, but the server is not required to honour the hint.
  • Acct-Terminate-cause
    Description: Enum value encoded as per RFC 2866. This attribute represents the reason for termination of subscriber.
  • FRAMED-IP
    The IPv4 address value decoded as per RFC 2865.
    For both 4G and 5G calls, the received value is set as the IPv4 address for the subscriber.
  • FRAMED-IPv6-PREFIX
    The IPv6 Prefix + Length value decoded as per RFC 3162.
    For both 4G and 5G calls, the received value is set as the IPv6 prefix for the subscriber.
    Important
    If the received prefix-length is !=64, the SMF overrides to 64.
  • IDLE-TIMEOUT
    The 4-byte octet (integer) value encoded as per RFC 2865. This attribute is supported in the inbound RADIUS packet.
    For both 4G and 5G calls, the received value is used as the maximum number of consecutive seconds of idle time that the user is permitted before being disconnected by the NAS.
  • SESSION-TIMEOUT
    For both 4G and 5G calls, the received value is used as the maximum number of seconds that the user is allowed to remain connected by the NAS.
Note
Standards Compliance
The RADIUS Client feature complies with the following standards:
  • RFC 2865: Remote Authentication Dial in User Service (RADIUS)
  • RFC 2866: RADIUS Accounting
  • RFC 3162: RADIUS and IPv6
  • 3GPP TS 29.061
  • 3GPP TS 29.274
Limitations and Restrictions
The SMF has the following limitations:
  • The SMF supports only single RADIUS attribute profile, and does not support dictionary selection.
  • If RADIUS accounting is enabled and server-group is configured within DNN profile, the SMF sends server-group as AAA group in charging-params in N4 session establishment. The UPF displays an error if there is a server group mismatch between SMF and UPF.
    In this scenario, static and predefined usage are not accounted in the RADIUS URR. However, the dynamic rules traffic is accounted in the RADIUS URR.
  • Currently, VLAN tagging for outbound RADIUS packets is based on the static routes configured on SMF. So, the overlapping AAA server addresses for different MVNOs where the VLAN tag must be different from SMF is not supported.
The RADIUS client provides both RADIUS authentication and accounting functionalities. For using these functionalities, it is important to enable the RADIUS authentication and accounting framework through the associated CLI configuration.
This section describes how to configure the RADIUS client.
Important
Configuring the VIP-IP of the RADIUS client interface is mandatory for the RADIUS client to work. Also, the VIP-IP must be the same as the IP of the UDP proxy pod.
Configuring the RADIUS Client feature involves the following:
Configuring RADIUS Server
Use the following sample configuration to configure the RADIUS server.
config
   profile radius
      server ipv4_address port_num
         secret secret_key
         priority priority_value
         type { acct | auth }
         commit
NOTES:
  • profile radius : Enter the RADIUS configuration mode.
  • server ipv4_address port_num : Specify the IPv4 address and port of the RADIUS server.
  • secret secret_key : Specify the secret key.
  • priority priority_value : Specify the server priority.
  • type { acct | auth } : Specify the type of the RADIUS server. The server can be one of the following:
    • acct : RADIUS server used for the accounting requests
    • auth : RADIUS server used for the authentication requests
  • commit : Commit the configuration.
Example
The following is an example of the RADIUS server configuration.
profile radius
 server 1.2.3.4 1812
  secret   $8$73a0i4G3ILj0Np+8tn2QOoWDj3QkB+oefPc2ZK6RE6A=
  priority 1
 exit
 server 1.2.5.6 1812
  secret   $8$VccEEUVou7m5ptA9WZRPR7KDmxQ/L3KlJ3QqgHjexkk=
  priority 2
 exit
exit
Verifying the RADIUS Configuration
Use the show radius command to display information about the RADIUS servers (both accounting and authentication) that are configured in the system.
The following configuration is a sample output of the show radius command:
bng# show radius
radius
 Server: 10.0.0.1, port: 1812, status: up, port-type: Auth
 2 requests, 0 pending, 0 retransmits
 1 accepts, 1 rejects, 0 timeouts
 0 bad responses, 0 bad authenticators
 0 unknown types, 0 dropped, 4 ms latest rtt
 Server: 10.0.0.1, port: 1813, status: up, port-type: Acct
 3 requests, 0 pending, 0 retransmits
 3 responses, 0 timeouts
 0 unknown types, 0 dropped, 1 ms latest rtt
Configuring RADIUS Server Selection Logic
Use the following sample configuration to configure the RADIUS server selection logic.
config
   profile radius
      algorithm { first-server | round-robin }
      commit
NOTES:
  • algorithm { first-server | round-robin } : Define the algorithm for selecting the RADIUS server.
    • first-server : Set the selection logic as highest priority first. This is the default behavior.
    • round-robin : Set the selection logic as round-robin order of servers.
Example
The following is an example of the RADIUS server selection logic configuration.
config
   profile radius
      algorithm round-robin
      exit
Configuring RADIUS Attributes
Use the following sample configuration to configure the RADIUS attributes for authentication and accounting.
config
   profile radius
      attribute { nas-identifier value | nas-ip ipv4_address }
      commit
NOTES:
  • attribute { nas-identifier value | nas-ip ipv4_address } : Configure the RADIUS identification parameters.
    • nas-identifier value : Specify the attribute name by which the system will be identified in Accounting-Request messages. value must be an alphanumeric string.
    • nas-ip ipv4_address : Specify the NAS IPv4 address. ipv4_address must be an IPv4 address in dotted decimal notation.
Example
The following is an example of the RADIUS attributes configuration.
config
   profile radius
      attribute
      nas-identifier CiscoSmf
      exit
   exit
Configuring RADIUS Detect Dead Server
Use the following sample configuration to configure the RADIUS detect dead server.
config
   profile radius
      detect-dead-server response-timeout value
      commit
NOTES:
  • detect-dead-server response-timeout value : Set the timeout value that marks a server as "dead" when a packet is not received for the specified number of seconds.
    value must be an integer in the range of 1–65535. Default: 10 seconds.
Example
The following is an example of the RADIUS detect dead server configuration.
config
   profile radius
      detect-dead-server response-timeout 100
      exit
Configuring RADIUS Dead Time
Use the following sample configuration to configure the RADIUS dead time.
config
   profile radius
      deadtime value
      commit
NOTES:
  • deadtime value : Set the time to elapse between RADIUS server marked unreachable and when we can reattempt to connect.
    value must be an integer in the range of 1–65535. Default: 10 minutes.
Example
The following is an example of the RADIUS dead time configuration.
config
   profile radius
     deadtime 15
     exit
Configuring RADIUS Retries
Use the following sample configuration to configure the maximum RADIUS retries.
config
   profile radius
      max-retry value
      commit
NOTES:
  • max-retry value : Set the maximum number of times that the system will attempt retry with the RADIUS server.
    value must be an integer in the range of 0–65535. Default: 2
Example
The following is an example of the RADIUS retries configuration.
config
   profile radius
      max-retry 2
      exit
Configuring RADIUS Timeout
Use the following sample configuration to configure the RADIUS timeout.
config
   profile radius
      timeout value_in_seconds
      commit
NOTES:
  • timeout value_in_seconds : Set the time to wait for response from the RADIUS server before retransmitting.
    value_in_seconds must be an integer in the range of 1–65535. Default: 2 seconds.
Example
The following is an example of the RADIUS timeout configuration.
config
   profile radius
      timeout 4
      exit
Configuring RADIUS Pod
Use the following sample configuration to configure the RADIUS pod.
config
      endpoint radius
         replicas number_of_replicas
         commit
NOTES:
  • endpoint radius : Enter the RADIUS endpoint configuration mode.
  • replicas number_of_replicas : Set the number of replicas required.
Example
The following is an example of the RADIUS pod configuration.
config
      endpoint radius
         replicas 3
         exit
This section describes how to configure the RADIUS NAS-IP.
Multiple RADIUS NAS-IP Configuration
Use the following sample configuration to configure multiple RADIUS NAS-IP addresses at various levels.
config
   profile radius
      attribute nas-ip-address ipv4_address
      accounting attribute nas-ip-address ipv4_address
      server-group group_name attribute nas-ip-address ipv4_address
      server-group group_name accounting attribute nas-ip-address ipv4_address
      commit
NOTES:
  • attribute nas-ip-address ipv4_address : Set the global NAS-IP address value.
  • accounting attribute nas-ip-address ipv4_address : Set the global accounting NAS-IP address value.
  • server-group group_name attribute nas-ip-address ipv4_address : Set the per server-group common NAS-IP address value.
  • server-group group_name accounting attribute nas-ip-address ipv4_address : Set the per server-group accounting NAS-IP address value.
Example:
The following is an example of the multiple RADIUS NAS-IP configuration.
config
 profile radius
  attribute
   nas-ip-address 1.2.3.4
  exit
  accounting
   attribute
    nas-ip-address 1.2.3.5
   exit
  exit
  server-group grp1
   attribute
    nas-ip-address 1.2.3.6
   exit
   accounting
   attribute
    nas-ip-address 1.2.3.7
   exit
  exit
 server-group grp2
   attribute
    nas-ip-address 1.2.3.78
   exit
   accounting
   attribute
    nas-ip-address 1.2.3.9
   exit
  exit
 exit
exit
Configuring Secondary Authentication Method
Use the following sample configuration to configure the secondary authentication method.
config
   profile dnn dnn_name
      authentication secondary radius [ group group_name ]
      commit
NOTES:
  • profile dnn dnn_name : Enter the DNN Profile configuration mode.
  • authentication secondary radius [ group group_name ] : Enable secondary authentication under the DNN profile and sets method as RADIUS.
    group group_name : This keyword is optional. This keyword defines the RADIUS server group name.
Example
The following is a configuration example of the secondary authentication method.
config
   profile dnn intershat
   exit
Verifying the RADIUS Authentication Configuration
Use the show radius auth-server command to display detailed statistics for RADIUS authentication server and port.
The following configuration is a sample output of the show radius auth-server command:
bng# show radius auth-server
Configuring PAP, CHAP, or MSCHAP-based Authentication
This section provides the configuration to enable the PAP, CHAP, and MSCHAP-based RADIUS authentication. This configuration aids in converting the CHAP Challenge and Response received in PCO IE as MSCHAP Challenge and Response.
Defining Priority for Authentication Algorithm
Use the following sample configuration to define the priority for different authentication algorithms (PAP or CHAP or MSCHAP) for RADIUS-based authentication in SMF.
config
   profile dnn profile_name
      authentication { { secondary radius [ group group_name  ] | { algorithm { pap priority_value [ password-use-pco ] | chap priority_value [ convert-to-mschap ] | mschap priority_value } }
      end
NOTES:
  • password-use-pco : This keyword overrides the DNN configured password with PCO password. The default setting is disabled.
    If the host level password is not configured at DNN, then the SMF uses the UE given password for PAP-based authentication even though this configuration is disabled.
  • convert-to-mschap : This keyword converts the received CHAP Challenge and Response to MSCHAP if the CHAP Response length is 49 bytes. Otherwise, the SMF sends as CHAP only even though this configuration is explicitly enabled.
  • The default priority for PAP, CHAP, and MSCHAP algorithms is 0 which means that the configuration is disabled. The valid values are 1, 2, and 3. Lower the value, higher is the priority. It is used to resolve conflicts if the UE sends multiple authentication parameters in the PCO, EPCO, or APCO IE.
Configuring Host Password
Use the following sample configuration to specify the host password at DNN level which is used as a password for PAP-based authentication.
config
      outbound password password
      end
NOTES:
  • profile dnn profile_name : Specify the DNN profile name as an alphanumeric string to enter the DNN configuration mode.
  • outbound password password : Specify the DNN host password for authentication. By default, the SMF sends this password in PAP user-password if it is not explicitly overridden using the password-use-pco option.
    By default, the SMF encrypts the given password using AES-128-CFB encryption algorithm.
Enabling RADIUS Accounting
Use the following sample configuration to enable RADIUS accounting on SMF and configure the RADIUS accounting specific parameters.
config
   profile charging charging_profile_name
      accounting limit { duration value | volume { downlink value | total value | uplink value } }
      accounting triggers [ ambr-change | plmn-change | qos-change | rat-change | serv-node-change |  ue-time-change | user-loc-change ]
      commit
NOTES:
  • profile charging charging_profile_name : Specify the charging profile name. charging_profile_name must be an alphanumeric string.
  • accounting : Specify this option to enable RADIUS accounting on SMF for the subscribesrs.
  • limit { duration value | volume { downlink value | total value | uplink value } } : Specify the volume and time limits for RADIUS accounting.
    duration value : Specify the time duration value as an integer in the range of 0–2147483647.
    downlink value : Specify the downlink volume limit for interim generation in bytes, as an integer in the range of 100000–4000000000.
    total value : Specify the total volume limit for interim generation in bytes, as an integer in the range of 100000–4000000000.
    uplink value : Specify the uplink volume limit for interim generation in bytes, as an integer in the range of 100000–4000000000.
  • accounting triggers [ ambr-change | plmn-change | qos-change | rat-change | serv-node-change | ue-time-change | user-loc-change ] : Enable the appropriate RADIUS accounting triggers according to the following conditions:
    • AMBR change
    • PLMN change
    • Quality of Service change
    • Routing Area Information change
    • Serving node change
    • Traffic Flow Template (TFT) change
    • UE time change
    • User Location Information change - applicable only for P-GW and GGSN.
    Important
    Enabling any one of these triggers turns off the remaining triggers.
Defining RADIUS Server Group in DNN Profile
Use the following sample configuration to set RADIUS server-group to use for accounting in DNN profile.
All subscribers under the specified DNN will have RADIUS accounting enabled.
configure
   profile dnn dnn_profile_name
      accounting server-group group_name
      commit
NOTES:
  • profile dnn dnn_profile_name : Specify the DNN profile name to enter the DNN configuration mode. dnn_profile_name must be an alphanumeric string.
  • accounting server-group group_name : Specify the RADIUS server-group to use for accounting in the configured DNN profile. group_name must be an alphanumeric string.
Configuring RADIUS Accounting Options
Use the following sample configuration to configure the RADIUS accounting options.
config
   profile radius accounting
      deadtime value
      max-retry value
      timeout value
      commit
NOTES:
  • profile radius accounting : Enter the RADIUS accounting configuration mode.
  • deadtime value : Set the time to elapse between RADIUS server marked unreachable and when we can re-attempt to connect.
    value must be an integer from 0 through 65535. Default: 10 minutes.
    value must be an integer from 1 through 65535. Default: 10 seconds.
  • timeout value : Set the time to wait for response from the RADIUS server before retransmitting.
    value must be an integer in the range of 1–65535. Default: 2 seconds.
  • All the keyword options under the RADIUS accounting configuration mode are also available within the RADIUS configuration mode.
Configuring RADIUS Accounting Server Group
Use the following sample configuration to configure the RADIUS server group.
config
   profile radius
      commit
NOTES:
  • server group group_name : Specify the name of server group for use in RADIUS accounting. group_name must be an alphanumeric string.
Verifying the RADIUS Accounting Configuration
Use the show radius acct-server command to display statistics for RADIUS accounting server and port.
The following configuration is a sample output of the show radius acct-server command:
bng# show radius acct-server
This section describes how to configure the Session Disconnect feature.
Configuring the Session Disconnect feature in SMF involves the following steps:
Configuring the Dynamic Authorization Service
Use the following sample configuration to enable the NAS as an authentication, authorization, and accounting (AAA) server for the dynamic authorization service. This service supports the RADIUS Disconnect and Change of Authorization (CoA) functionality.
config
   profile radius-dynamic-author
      client ipv4_address [ secret shared_secret ]
      end
NOTES:
  • profile radius-dynamic-author : Enter the dynamic authorization configuration mode.
  • client ipv4_address [ secret shared_secret ] : Specify the IP address of the Dynamic Authorization Client. ipv4_address must be in standard IPv4 dotted decimal notation.
    You can add a list of client IPs from which the Disconnect message is accepted.
    secret shared_secret : This is an optional keyword. Specify the secret key at the client level.
    Important
    Configuring the server key at the client level overrides the server key configured at the global level.
  • nas-identifier value : Specify the dynamic authorization specific NAS-Identifier value. value must be an alphanumeric string of 1 to 64 characters.
    If this keyword is configured, it is validated against the value received in DM request. If this keyword is not configured, the input value is silently ignored. That is, the DM requests from unlisted or unauthenticated clients are silently discarded.
  • secret shared_secret : Specify the global shared secret key of the server.
Verifying the Session Disconnect Feature Configuration
This section describes how to verify the configuration associated with the Session Disconnect feature.
To view the information about the RADIUS Dynamic Authorization Clients that are configured in the system, use the show radius-dyn-auth command.
The following is a sample output of the show radius-dyn-auth command.
[unknown] smf# show radius-dyn-auth
radius-dyn-auth
 IP: 10.0.0.2
 COA:
 0 total-requests     0 inprocess-requests
     0 retry-request-drops  0 invalid-requests
     0 bad-authenticators   0 internal-errors
 0 ack-sent             0 nak-sent
 DISCONNECT:
 UnknownTypesRcvd: 0
Configuring the CoA-NAS Interface
Use the following sample configuration to define Change of Authorization (CoA) NAS interface in the RADIUS endpoint.
config
      endpoint radius
         interface coa-nas
            vip-ip ipv4_address vip-port port_number
            end
NOTES:
  • interface coa-nas : Enter the CoA NAS interface configuration mode. This keyword defines a new interface "coa-nas".
  • vip-ip ipv4_address vip-port port_number : Specify the IP address of the host. ipv4_address must be in standard IPv4 dotted decimal notation.
    You can configure a list of VIP-IPs to listen to the inbound CoA or DM requests.
    vip-port port_number : Specify the port number of the UDP proxy. By default, the port number is 3799. This default value is used only when the VIP-IP is specified.
    Important
    This configuration allows only port to be specified per IP.
    The SMF (udp-pxy) listens to the inbound CoA or DM request messages on these ports, and ACK or NAK messages sent with the respective source IP and port.
RADIUS Test CLI support
The RADIUS test CLI provides a mechanism for testing network connectivity with and configuration of RADIUS authentication and accounting servers.
This functionality is useful in determining the accuracy of the system RADIUS configuration, the configuration of the subscriber profile on the RADIUS server and troubleshooting the server response time.
Testing a RADIUS Accounting Server
When used to test a RADIUS accounting server, the tool generates an accounting request message for a specific username.
Note
The user name must already be configured on the RADIUS authentication server prior to executing the test.
To execute the RADIUS authentication test tool, enter the following command:
test-radius accounting { all | server-group group_name | server server_name port server_port }  { user_nameclient_nas_ip_address }
NOTES:
  • all : Specify that all configured RADIUS accounting servers be tested.
  • radius group group_name : Specify the configured RADIUS authentication servers in a RADIUS server group named group_name for server group functionality.
  • server_name : Specify the IP address of a specific RADIUS accounting server to test.
  • server_port : Specify the TCP port over that the system must use when communicating with the RADIUS accounting server to test.
  • user_name : Specify a username that is supplied to the RADIUS server for accounting.
  • client_nas_ip_address : Specify the IP address of the source NAS that is supplied to the RADIUS server for accounting.
Example
The following command verifies all the RADIUS servers.
test-radius accounting all
The following command verifies the RADIUS accounting for user user1 for the sampleServer .
test-radius accounting server sampleServer port 5000 username user1
The following command verifies the RADIUS accounting server group star1 for user user1 .
test-radius accounting server-group star1 username user1
Testing a RADIUS Authentication Server
When used to test a RADIUS authentication server, the tool generates an authentication request message for a specific user name.
Note
To execute the RADIUS authentication test tool, in the Exec mode, use the following command:
test-radius authentication { all | server-group group_name | server server_name port server_port }  { user_namepasswordclient_nas_ip_address }
NOTES:
  • all : Specify that all configured RADIUS authentication servers be tested.
  • server_name : Specify the IP address of a specific RADIUS authentication server to test.
  • server_port : Specify the TCP port over that the system must use when communicating with the RADIUS authentication server to test.
  • user_name : Specify a username that is supplied to the RADIUS server for authentication.
  • password : Specify the password associated with the username that is supplied to the RADIUS server for authentication.
Example
test-radius authentication all
The following command verifies the RADIUS authentication for user user1 for the sampleServer .
test-radius authentication server sampleServer port 5000 username user1 password dummyPwd
The following command verifies the RADIUS authentication server group star1 for user user1 .
test-radius authentication server-group star1 username user1
RADIUS Client OA&M Support
This section describes operations, administration, and maintenance information for this feature.
Statistics Support
RADIUS Authentication Statistics
This feature supports the following statistics related to RADIUS Authentication:
  • SMF-Service:
    • Number of Secondary-Authentication requests sent
    • Number of Secondary-Authentication response received
  • RADIUS-EP:
    • Number of RADIUS packets sent
    • Number of RADIUS packets received
RADIUS Accounting Statistics
The SMF maintains the following statistics to track the total number of attempted, successful, and failed RADIUS Accounting Start, Accounting Update Interim and Accounting Terminate requests and responses.
  • SMF_SERVICE_STATS for the following procedure types:
    • radius_initial: This counter gets incremented for Accounting Start request and response.
    • radius_update: This counter gets incremented for Accounting Interim Update request and response.
    • radius_terminate: This counter gets incremented for Accounting Terminate request and response.
RADIUS Access Management Statistics
The following statistics track the number of times the AVP is received in the RADIUS Access-Accept messages at SMF.
  • SmfRadiusMessageStats
    INBOUND:
    • radius_access_accept
      • radius_avp_session_timeout
      • radius_avp_idle_timeout
PAP, CHAP, or MSCHAP-based Authentication Statistics
The SMF supports the following statistics to track the number of times the AVP sent in Access-Request messages.
Group: smf_radius_message_stats
Format: {app_name, cluster, data_center, direction, instance_id, message_type, radius_avp_type, rat_type, service_name}
message_type: radius_access_request
radius_avp_type:
  • radius_avp_pap_user_password
  • radius_avp_pap_username
  • radius_avp_chap_challenge
  • radius_avp_chap_response
  • radius_avp_mschap_challenge
  • radius_avp_mschap_response
Example:
smf_radius_message_stats{app_name="SMF",cluster="Local",data_center="DC",direction="outbound",
instance_id="0",message_type="radius_access_request",radius_avp_type="radius_avp_pap_user_password",
rat_type="NR",service_name="smf-service"} 1
direction="outbound",instance_id="0",message_type="radius_access_request",
radius_avp_type="radius_avp_pap_username",rat_type="NR",service_name="smf-service"} 1
The SMF supports these additional statistics to track the number of attempted, successful and failed responses received due to PAP, CHAP, and MSCHAP authentication.
Group: radius_authentication_message_stats
Format: {app_name, cluster, data_center, dnn, instance_id, radius_auth_algorithm, rat_type, reason, service_name, status}
radius_auth_algorithm:
  • radius_auth_algorithm_default
  • radius_auth_algorithm_pap
  • radius_auth_algorithm_chap
  • radius_auth_algorithm_mschap
rat_type:
  • NR
  • EUTRA
  • WLAN
status:
  • decode_failed
  • encode_failed
  • attempted
  • success
  • failed
  • timeout
reason:
  • parse_error
  • invalid_code
  • invalid_option
  • invalid_pco
  • invalid_epco
  • invalid_apco
  • write_error
Example:
radius_authentication_message_stats{app_name="SMF",cluster="Local",
data_center="DC",dnn="intershat2",instance_id="0",
radius_auth_algorithm="radius_auth_algorithm_default",rat_type="NR",reason="",
service_name="smf-service",status="attempted"} 2
data_center="DC",dnn="intershat2",instance_id="0",radius_auth_algorithm="radius_auth_algorithm_default",
rat_type="NR",reason="",service_name="smf-service",status="success"} 2
radius_authentication_message_stats{app_name="SMF",cluster="Local",data_center="DC",
dnn="intershat",instance_id="0",radius_auth_algorithm="radius_auth_algorithm_chap",
rat_type="EUTRA",reason="",service_name="smf-service",status="attempted"} 2
data_center="DC",dnn="intershat",instance_id="0",radius_auth_algorithm="radius_auth_algorithm_chap",
rat_type="EUTRA",reason="",service_name="smf-service",status="failed"} 2
RADIUS Disconnect and CoA Request Related Statistics
The RADIUS endpoint (radius-ep) pod supports the following statistics.
Radius_Server_Status
Description: Display the active or inactive status of RADIUS server.
Metrics-Type: Gauge
Metrics-Value: 1 – ActiveServer, 0 – Inactive Server
Labels:
  • Label: radSvrIP
    • Description: Server IP Address
    • Value: <any-ip-address>
  • Label: radSvrPort
    • Description: Server Port
    • Value: <any-port>
  • Label: radSvrPortType
    • Description: Authentication or Accounting type
    • Value: Auth, Acct
Radius_Requests_Current
Description: Displays the outstanding authentication and accounting requests
Metrics-Type: Gauge
Labels:
  • Label: radMsgCode
    • Description: RADIUS Message Type
    • Values: SecondaryAuthenReq, RadiusAcctReq, TestAuth, TestAcct
  • Label: radSvrIP
  • Label: radSvrPort
    • Value: <any-port>
    • Value: Auth, Acct
  • Label: dnn
    • Description: DNN of subscriber
    • Value: <string>
  • Label: procType
    • Description: Procedure-type
    • Value: <string>
  • Label: ratType
    • Description: RAT type of subscriber
    • Value: <string>
  • Label: sessType
    • Description: Session-type of subscriber
    • Value: <string>
Radius_Requests_Statistics
Description: Displays the total authentication and accounting requests transmitted, retransmitted, and responses received
Metrics-Type: Counter
Labels:
  • Label: radMsgCode
    • Description: Radius Message Type
  • Label: radPacketType
    • Description: Direction of packet
    • Value: Tx, Rx, Retry_Tx
  • Label: radResult
    • Description: Result of operation
    • Value: Success, Failed, Timeout, Failure_Reject, ...
  • Label: radSvrIP
  • Label: radSvrPort
    • Value: <any-port>
    • Value: Auth, Acct
  • Label: dnn
    • Value: <string>
  • Label: procType
    • Value: <string>
  • Label: ratType
    • Value: <string>
  • Label: sessType
    • Value: <string>
Radius_CoaDM_Requests_Current
Description: Displays the outstanding CoA and DM requests being processed.
Metrics-Type: Gauge
Labels:
  • Label: radMsgCode
    • Values: DisconnectRequest, CoARequest
  • Label: radSvrIP
Radius_CoaDM_Requests_Statistics
Description: Displays the total CoA and DM requests received and processed.
Labels:
  • Label: radMsgCode
    • Values: DisconnectRequest, DisconnectACK, DisconnectNAK, CoARequest, CoaDMReq, CoAACK
    • Value: Tx, Rx
  • Label: radResult
    • Value: Success, Failure_Invalid_Request, Failure_Drop_Retry_Coa, Failure_Unknown_Error...
  • Label: radSvrIP
  • Label: nakErrorCause
    • Description: Error-cause set during COA-NAK / DM-NAK (not applicable for other cases)
    • Value: Missing-Attribute, NAS-Identification-Mismatch, Unsupported-Service, Invalid-Attribute-Value, Session-Context-Not-Found, Internal-Error
