Customized Configuration for Controlling Subscription Messages over N10
Summary Data
Table 1. Summary Data
Applicable Product(s) or Functional Area SMF
Applicable Platform(s) SMI
Feature Default Setting Disabled – Configuration Required
Related Changes in this Release Not Applicable
Related Documentation Not Applicable
Revision History
Table 2. Revision History
Revision Details Release
First introduced. 2020.03.0
Feature Description
The SMF introduces new RAT type configuration options with the existing configuration authorization local in the DNN profile. With this optional configuration, the SMF stops the Subscription Data Management (SDM) messages from sending over N10 interface towards Unified Data Management (UDM).
How it Works
This feature works with the customized RAT-type configuration in the DNN profile configuration.
When the SMF skips UDM subscription, then it stops sending Fetch-Subscription and Subscribe-for-Notification during session establishment.
When the SMF skips the UDM subscription, then it stops sending Unsubscribe-to-Notification during session release. The SMF sends Unsubscribe-to-Notification only when the UDM receives the UECM messages.
The SMF supports dynamic change for UDM subscription skip configuration. That is, new configuration is applicable for the new session getting established. The existing sessions continue as per the old behavior of configuration.
For information on the complete configuration commands, see the following section.
Configuring Options for Controlling SDM Messages
This section describes how to configure this feature for controlling SDM messages over the N10 interface.
Configuring RAT-type in DNN Profile
To configure the RAT-type with the local authorization under the DNN profile, use the following commands:
configure
   profile dnn dnnprofile
      authorization local rat-type [ nr | eutra | wlan ]
      end
NOTES:
  • authorization local : This command skips the SDM messages for EPS sessions only. Upon configuring this command under the selected DNN profile, the SMF skips the UDM interaction for fetch subscription. The SMF uses the values received in the ‘Create Session Request’ message. The SMF skips the UDM interaction to receive ‘Subscribe-for-Notification’ from the UDM.
  • rat-type [ nr | eutra | wlan ] : This keyword skips the following SDM messages based on the specified RAT-type.
    • udm subscription-fetch
    • subscribe-to-notification
    • unsubscribe-to-notifications
    Upon configuring the RAT-type with authorization local command in the selected dnn-profile, then for sessions on that RAT-type, the SMF skips the following interactions:
    • the UDM interaction for ‘UDM fetch subscription’ during session establishment
    • the UDM interaction to ‘subscriber-for-notification’ during session establishment
    • the UDM interaction to ‘unsubscribe-for-notification’ during session release
  • no authorization local rat-type [ nr | eutra | wlan ] : Disables the local authorization under the DNN profile.
