Deploying and Configuring SMF through Ops Center
Summary Data
Table 1. Summary Data
Applicable Product(s) or Functional Area SMF
Applicable Platform(s) SMI
Feature Default Setting Disabled - Configuration Required
Related Changes in this Release Not Applicable
Related Documentation Not Applicable
Revision History
Table 2. Revision History
Revision Details Release
SMF deployment on bare metal server is supported and fully qualified in this release.
2021.01.0
First introduced.
Pre-2020.02.0
Feature Description
The SMF deployment and configuration procedure involves deploying the SMF through the Subscriber Microservices Infrastructure (SMI) Cluster Deployer and configuring the settings or customizations through the SMF Operations (Ops) Center. The Ops Center is based on the ConfD CLI. The SMF configuration includes the NRF profile data configuration and the externally visible IP addresses and ports.
SMF Ops Center
The Ops Center is a system-level infrastructure that provides the following functionality:
  • A user interface to trigger a deployment of microservices with the flexibility of providing variable helm chart parameters to control the scale and properties of Kubernetes objects (deployment, pod, services, and so on) associated with the deployment.
  • A user interface to push application-specific configuration to one or more microservices through Kubernetes configuration maps.
  • A user interface to issue application-specific execution commands (such as show and clear commands). These commands:
    • Invoke some APIs in application-specific pods
    • Display the information returned on the user interface application
The following screenshot is a sample of the web-based command line interface presented to the user.
Figure 1. Web-based CLI of Ops Center
The SMF Ops Center allows you to configure the features such as licensing, SMF engine, REST Endpoint, and CDL.
Prerequisites
Before deploying SMF on the SMI layer:
  • Ensure that all the virtual network functions (VNFs) are deployed.
  • Run the SMI synchronization operation for the SMF Ops Center and Cloud Native Common Execution Environment (CN-CEE)
Converged Core Refactoring Changes
This section describes the changes related to converged core refactoring in this chapter.
The Day1 SMF configuration is updated to include the s11 and sxa interfaces in the GTP endpoint and Protocol endpoint configuration respectively.
Deploying and Accessing SMF
This section describes how to deploy SMF and access the SMF Ops Center.
Deploying SMF
The Subscriber Microservices Infrastructure (SMI) platform is responsible for deploying and managing the Cloud Native 5G SMF application and other network functions.
For information on how to deploy SMF Ops Center on a vCenter environment, see Deploying and Upgrading the Product section in the Ultra Cloud Core Subscriber Microservices Infrastructure — Operations Guide.
For deploying SMF Ops Center on a OpenStack environment, see UAME-based VNF Deployment section in the UAME-based 4G and 5G VNF Deployment Automation Guide.
For information on how to deploy SMF Ops Center on bare metal servers (currently Cisco UCS-C servers) environment, see Operating the SMI Cluster Manager on Bare Metal section in Ultra Cloud Core Subscriber Microservices Infrastructure — Operations Guide.
Accessing the SMF Ops Center
You can connect to the SMF Ops Center through SSH or the web-based CLI console.
  • SSH:
    ssh admin@ops_center_pod_ip -p 2024
  • Web-based console:
    1. Log in to the Kubernetes master node.
    2. Run the following command:
      kubectl get ingress <namespace>
      The available ingress connections get listed.
    3. Select the appropriate ingress and access the SMF Ops Center.
    4. Access the following URL from your web browser:
      cli.<namespace>-ops-center.<ip_address>.nip.io
By default, the Day 0 configuration is loaded into the SMF.
Day 0 Configuration
To view the Day 0 configuration, run the following command.
show running-config
The following is a sample Day 0 configuration:
# show running-config
helm default-repository base-repos
helm repository base-repos
 url https://charts.10.192.1.111.nip.io/ccg.2021.01.0.i60
exit
k8s name          2nd-a18-kub-cluster
k8s namespace     cn-cn3
k8s nf-name       smf
k8s registry      docker.10.192.1.111.nip.io/ccg.2021.01.0.i60
k8s single-node   false
k8s use-volume-claims false
k8s ingress-host-name 10.84.104.34.nip.io
k8s nodes 2nd-a18-kub-cluster-master-11
 node-type   master
 worker-type master
exit
k8s nodes 2nd-a18-kub-cluster-master-22
 node-type   master
 worker-type master
exit
k8s nodes 2nd-a18-kub-cluster-master-33
 node-type   master
 worker-type master
exit
aaa authentication users user admin
 uid        1117
 gid        1117
 password   $1$XNGJOr.C$iZZvQbNfmPN15qG4GpQa8/
 ssh_keydir /tmp/admin/.ssh
 homedir    /tmp/admin
exit
aaa ios level 0
 prompt "\h> "
exit
aaa ios level 15
 prompt "\h# "
exit
aaa ios privilege exec
 level 0
  command action
  exit
  command autowizard
  exit
  command enable
  exit
  command exit
  exit
  command help
  exit
  command startup
  exit
 exit
 level 15
  command configure
  exit
 exit
exit
nacm write-default deny
nacm groups group LI
 user-name [ liadmin ]
exit
nacm groups group admin
 user-name [ admin ]
exit
nacm rule-list admin
 group [ admin ]
 rule li-deny-tap
  module-name       lawful-intercept
  path              /lawful-intercept
  access-operations *
  action            deny
 exit
 rule li-deny-clear
  module-name       tailf-mobile-smf
  path              /clear/lawful-intercept
  access-operations *
  action            deny
 exit
 rule any-access
  action permit
 exit
exit
nacm rule-list confd-api-manager
 group [ confd-api-manager ]
 rule any-access
  action permit
 exit
exit
nacm rule-list ops-center-security
 group [ * ]
 rule change-self-password
  module-name       ops-center-security
  path              /smiuser/change-self-password
  access-operations exec
  action            permit
 exit
 rule smiuser
  path              /smiuser
  action            deny
 exit
exit
nacm rule-list lawful-intercept
 group [ LI ]
 rule li-accept-tap
  access-operations *
  action            permit
 exit
 rule li-accept-clear
  access-operations *
  action            permit
 exit
exit
nacm rule-list any-group
 group [ * ]
 rule li-deny-tap
  access-operations *
  action            deny
 exit
 rule li-deny-clear
  access-operations *
  action            deny
 exit
exit
SMF Service Configuration
The SMF service requires the basic configuration to process PDU Session Management API calls.
Configuring Pod-level Labels
Important
The pod-level labelling configuration is applicable only when the SMF is deployed on a bare metal server.
Use the following sample configuration to configure the SMF pod layout when the virtual machine is short of CPU and memory resources.
config
      endpoint protocol
         labels key label_key value label_value
         cpu { max-process process_thread_count | request resource_request_number}
         memory { limit max_resource_limit | request resource_request_number}
         end
NOTES:
  • labels key label_key value label_value : Specify the K8 node affinity label key and value.
    label_key and label_value accept alphanumeric characters. For example, the key can be smi.cisco.com/protocol.
    Important
    The pod-level configuration takes precedence over the layered node-level configuration, that is, at the protocol, service, or session level configuration.
  • cpu { max-process process_thread_count | request resource_request_number } : Enables the K8 pod CPU configuration.
    • max-process process_thread_count : Specify the maximum number of parallel OS threads to use. process_thread_count must be an integer in the range of 1-32.
    • request resource_request_number : Specify the CPU resource request in millicores. resource_request_number must be an integer in the range of 100-1000000.
  • memory { limit max_resource_limit | request resource_request_number } : Enables the K8 pod memory configuration.
    • limit max_resource_limit : Specify the maximum number of used memory resources in megabytes. max_limit must be an integer in the range of 100-200000.
    • request resource_request_number : Specify the memory resource request in megabytes. request_number must be an integer in the range of 100-200000.
Use the following table for node-level labelling.
Node
OAM
Protocol
CDL
SMF
Node 1
Yes
Yes
Yes
No
Node 2
Yes
Yes
Yes
No
Node 3
Yes
No
No
Yes
Node 4
No
No
No
Yes
Loading Day 1 Configuration
To load the Day 1 configuration for SMF, run the following command:
ssh admin@ops_center_pod_ip -p 2024  < Day1config.cli
Note
The Day1config.cli file contains the necessary parameters required for the Day 1 configuration.
Alternatively, you can copy the configuration and paste it in the SMF Ops Center CLI to load the Day 1 configuration.
configure
  <Paste the Day 1 configuration here>
  commit
  exit
A sample Day1config.cli file, which contains the Day 1 configuration for SMF is shown below.
Day1config.cli
The following is a sample Day1config.cli file, which contains the Day 1 configuration for the SMF.
