3GPP Specification Compliance for SMF Interfaces
This chapter covers the following topics:
Summary Data
Table 1. Summary Data
Applicable Product(s) or Functional Area
SMF
Applicable Platform(s)
SMI
Default Setting
Enabled – Always-on
Related Changes in this Release
Not Applicable
Related Documentation
Not Applicable
Revision History
Table 2. Revision History
Revision Details Release
First introduced.
Pre-2020.02.0
Feature Description
The SMF currently supports either the December 2018 compliance version of 3GPP specification or the June 2019 compliance version of 3GPP specification for the SMF interfaces such as N1, N2, N4, N7, N10, N11, N40, and Nnrf. The SMF processes the messages from these interfaces as per the compliance profile configured for the corresponding services. For information on the compliance profile configurations, see the Configuring Interfaces section.
Currently, only IE encoding and decoding is supported. The existing features work with the June 2019 specification versions. No additional features in the June 2019 version are supported.
Note
The SMF continues to support the older versions of 3GPP specifications and the compliance profile configuration controls the same for the SMF interfaces.
Standards Compliance
The SMF is one of the control plane (CP) NFs of the 5G core network. The SMF uses different interfaces to communicate with the other NFs or nodes. For example, the N4 interface exists between the SMF and User Plane Function (UPF). Each of the SMF interfaces comply to a specific version of the 3GPP specification depending on the compliance version supported.
Use the following table to determine the compliance mapping of each SMF interface and the 3GPP Standards specification versions.
Interface Relationship 3GPP Specification Version
N11
Between AMF and SMF
29.518
29.502
For December 2018 Compliance Support: 15.2.0
For June 2019 Compliance Support: 15.4.0
N7
Between PCF and SMF
29.512
N4
Between UPF and SMF
29.244
Nnrf
Between NRF and SMF
29.510
For December 2018 Compliance Support: 15.0.0
N10
Between UDM and SMF
29.503
For December 2018 Compliance Support: 15.2.1
N40
Between SMF and CHF
32.291
For December 2018 Compliance Support: 15.1.0
For June 2019 Compliance Support: 15.3.0
N1
Between UE and SMF
24.501
For June 2019 Compliance Support:15.4.0
N2/NGAP
Between RAN and SMF
38.314
Use the following commands to configure the SMF interfaces in compliance with the 3GPP specifications.
configure
   profile compliance profile_name
      service
         n1 version full version_format spec spec_version uri_version uri_version
         n2 version full version_format spec spec_version uri_version uri_version
         namf-comm version full version_format spec spec_version uri_version uri_version
         nchf-convergedcharging version full version_format spec spec_version uri_version uri_version
         nnrf-disc version full version_format spec spec_version uri_version uri_version
         nnrf-nfm version full version_format spec spec_version uri_version uri_version
         npcf-smpolicycontrol version full version_format spec spec_version uri_version uri_version
         nsmf-pdusession version full version_format spec spec_version uri_version uri_version
         nudm-sdm version full version_format spec spec_version uri_version uri_version
         nudm-uecm version full version_format spec spec_version uri_version uri_version
         range
Important
Service selection is based only on the specification version. In future releases, the full API version will be used.
NOTES:
  • version full : Specifies the API full version for each service in the following format:
    <Major-version>.<Minor-version>.<patch-version>.[alpha-<draft-number>]
    The format is specified in 3GPP TS 29.501 V15.2.0, section 4.3.1.1.
  • version spec : Specifies the 3GPP specification version number. It can be one of the following values:
    • 15.0.0
    • 15.1.0
    • 15.2.0
    • 15.2.1
    • 15.4.0
    Important
    Configuring the 3GPP specification version value depends on the SMF interface. Not all the preceding versions are options for the SMF interfaces. Only a combination of the preceding versions exist as options for the 3GPP version compliance configuration. For details on the compliance version, see the Standards Compliance section.
    For example, to support 3GPP June 2019 specification compliance for the N7 (PCF) interface, configure the specification version as 15.4.0.
    The default version number depends on the SMF interface. For example, the default version is 15.2.0 for the N7 interface. Similarly, for the N10 interface, the default version is 15.2.1.
  • version uri : Specifies the API version URI for each service in the following format:
    "v" concatenated with a number
    It can be both v1 and v2, or either v1 or v2.
    For example, for the compliance version 15.4.0 in the NRF configuration for the service type nudm-sdm/nudm-uecm, mandate the configuration of the uri-version in the versions to ‘v2’. For compliance version 15.2.1, this configuration is optional.
    For example, version v1: (- url: '{apiRoot}/nsmf-pdusession/v1')
  • service : The service names as specified in 3GPP TS 29.510 V15.2.0, section 6.1.6.3.11.
Sample Configuration
The following is a sample output of the interface configuration:
product smf(config-compliance-comp1)# show full
profile compliance comp1
   service nsmf-pdusession
      version uri v1
      version full 1.0.0
      version spec 15.2.0
product smf(config-service-nsmf-pdu)# compliance-profile comp1
product smf(config)# show full-configuration profile smf
profile smf smf1
   service name nsmf-pdu
