Troubleshooting Information
Summary Data
Table 1. Summary Data
Applicable Product(s) or FunctionalArea
SMF
Applicable Platform(s)
SMI
Feature Default Setting
Not Applicable
Related Changes in this Release
Not Applicable
Related Documentation
Not Applicable
Revision History
Table 2. Revision History
Revision Details
Release
Updated the Troubleshooting information for this release.
Pre-2020.02.0
clear subscriber
Table 3. clear subscriber Command Output Description
Field Description
all Clears all the sessions.
amf Clears subscriber based on AMF address.
chf Clears subscriber based on CHF address.
dnn Clears subscriber based on DNN value.
gtp-peer Clears subscriber based on GTP-PEER address.
ipv4-pool Clears subscriber based on IPv4 pool name.
ipv4-range Clears subscriber based on IPv4 address-range.
ipv6-pool Clears subscriber based on IPv6 pool name.
ipv6-range Clears subscriber based on IPv6 prefix-range.
pcf Clears subscriber based on PCF address.
policy Clears subscriber based on policy information.
purge Clears true, if purged locally.
clear subscriber supi imsi <imsi_value>
Table 4. clear subscriber supi imsi <imsi_value> Command Output Description
Field Description
ebi Clears subscriber based on EPS bearer ID.
imsi Clears subscriber based on IMSI.
| Output modifier.
clear subscriber supi imsi <imsi_value> psid <psid_value>
Table 5. clear subscriber supi imsi <imsi_value> psid <psid_value> Command Output Description
Field Description
psid Clears subscriber based on Service ID.
| Output modifier.
show subscriber
This commands displays the existing show subscriber CLI output with the newly added CLI output.
Table 6. show subscriber Command Output Description
Field Description
amf Displays the AMF address.
chf Displays the CHF address.
count Displays the number of sessions.
debug Displays the debugging information.
dnn Displays the DNN value.
gtp-peer Displays the GTP-peer address.
pcf Displays the PCF address.
rat Displays the RAT type as 4G or 5G.
udm Displays the UDM address.
upf Displays the UPF address.
| Displays the output modifiers.
show subscriber count
This command displays the CLI options for the count CLI command.
Table 7. show subscriber count Command Output Description
Field Description
all Displays all the SUPIs.
supi Displays the specific SUPI value.
show subscriber count all
This command displays the total number of sessions for all the SUPIs.
Table 8. show subscriber count all Command Output Description
Field Description
show subscriber count chf <chf_address>
This command displays the total number of sessions for the specified parameters.
Table 9. show subscriber count chf <chf_address> Command Output Description
Field Description
show subscriber count chf <chf_address> dnn <dnn_value>
Table 10. show subscriber count chf <chf_address> dnn <dnn_value> Command Output Description
Field Description
show subscriber count supi <supi_value>
This command displays the total number of sessions for the specific SUPI value.
Table 11. show subscriber count supi <supi_value> Command Output Description
Field Description
show subscriber debug-info supi <supi_value>
This command displays the debug information for the specific SUPI value where the PSID value is optional.
Table 12. show subscriber debug-info supi <supi_value> Command Output Description
Field Description
psid Displays the Provider Service Identifier.
show subscriber debug-info supi <supi_value> psid <psid_value>
This command displays the debug information for the specific SUPI and PSID combination.
Table 13. show subscriber debug-info supi <supi_value> psid <psid_value> Command Output Description
Field Description
Note
Currently, the SMF does not validate the serving PLMN received on N11 interface. Also, the SMF does not validate the UE PLMN when the N11 smContextCreate or GTP createSessionRequest is received.
The PLMN value received in the NSSAI included in the PCO request remain the same as the PLMN configured on the SMF.
