DSCP Marking
Summary Data
Applicable Product(s) or Functional Area
SMF
Applicable Platform(s)
SMI
Feature Default Setting
Disabled – Configuration Required
Related Changes in this Release
Not Applicable
Related Documentation
Not Applicable
Revision History
Revision Details
Release
First introduced.
Pre-2020.02.0
Feature Description
DSCP Marking supports granular configuration of DSCP. For Interactive Traffic Class (ITC), the SMF supports per-APN configurable DSCP marking for Uplink and Downlink direction that is based on 5QI and ARP-Priority level. This allows users to assign different DSCP values for flows with the same 5QI but different ARP priority values. For example, the ability to assign DSCP values that are based on 5QI+ARP can be used to meet compliance on priority and emergency calling via VoLTE.
DSCP Marking is a CLI-controlled feature, which enables to create and map 5QI and ARP values to enforceable QoS parameters.
How it Works
Allocation of different DSCP values for flows with the same 5QI, but different ARP values, works as follows:
  • Allows DSCP marking of packets that is based on 5QI+ARP combination.
  • 5QI+ARP configuration overrides any pre-entry of DSCP marking of packets that was based on 5QI+ARP combination.
  • 5QI-only DSCP entry overrides all existing 5QI+ARP configuration.
  • Allows implementation of associated DSCP marking for 5QI+ARP for Uplink and Downlink functionality.
Configuring 5QI-QoS Mapping
Use the following CLI commands to create and map 5QI values to enforceable QoS parameters.
configure
   profile qos qos_name
      dscp-map qi5 qi5_value [ arp-priority-level arp_value ] uplink user-datagram dscp-marking dscp_marking_value
      dscp-map qi5 5qi_value [ arp-priority-level arp_value ] downlink { encaps-header { copy-inner | dscp-marking dscp_marking_value } | user-datagram dscp-marking dscp_marking_value encaps-header { copy-inner | dscp-marking dscp_marking_value } }
      commit
NOTES:
  • dscp-map : Configures 5QI (referred as qi5 in the code) to DSCP-Marking mapping.
  • qi5 5qi_value : Identifier for the authorized QoS parameters. The 5qi_value must be within the range of 0 through 255.
  • arp-priority-level arp_value : Configures the ARP Priority Level. The arp_value must be an integer from 1 through 15.
  • downlink : Configures the downlink traffic.
  • uplink : Configures the uplink traffic.
  • user-datagram : Specifies the DSCP value to be applied to user datagram. Use this keyword to set the DSCP in the inner IP header in uplink/downlink direction.
  • dscp-marking : Specifies the DSCP value to be applied to packets with this 5QI. The dscp_marking_value must be a hexadecimal number from 0x00 through 0x3F.
  • encaps-header : Configures the DSCP value to be applied to encaps header. Use this keyword to set the DSCP in the outer-ip header in downlink direction.
  • copy-inner : Copies the DSCP value from inner IP header to the outer IP header.
  • The following is a sample configuration.
    profile qos test
     dscp-map qi5 1 downlink encaps-header copy-inner
     dscp-map qi5 1 downlink encaps-header dscp-marking 0x3b
     dscp-map qi5 2 downlink user-datagram dscp-marking 0x3b
     dscp-map qi5 3 downlink user-datagram dscp-marking 0x3b encaps-header copy-inner
     dscp-map qi5 4 downlink user-datagram dscp-marking 0x3b encaps-header dscp-marking 0x3f
     dscp-map qi5 2 uplink user-datagram dscp-marking 0x3b
     dscp-map qi5 1 arp-priority-level 1 downlink encaps-header copy-inner
     dscp-map qi5 2 arp-priority-level 2 downlink encaps-header dscp-marking 0x3b
     dscp-map qi5 4 arp-priority-level 3 downlink user-datagram dscp-marking 0x3b
     dscp-map qi5 2 arp-priority-level 4 downlink user-datagram dscp-marking 0x3b encaps-header copy-inner
     dscp-map qi5 4 arp-priority-level 5 downlink user-datagram dscp-marking 0x3b encaps-header dscp-marking 0x3f
     dscp-map qi5 4 arp-priority-level 5 uplink user-datagram dscp-marking 0x3b
