DNS Proxy Integration
Summary Data
Table 1. Summary Data
Applicable Product(s) or Functional Area
SMF
Applicable Platform(s)
SMI
Feature Default Setting
Disabled – Configuration Required
Related Changes in this Release
Not Applicable
Related Documentation
Not Applicable
Revision History
Table 2. Revision History
Revision Details
Release
First introduced.
Pre-2020.02.0
Feature Description
The Domain Name System (DNS) is a network of servers that translates numeric IP addresses into readable, hierarchical Internet addresses, and vice-versa. The DNS Proxy allows you to configure the proxy servers (one or more) for resolving the host names. The DNS queries – for resolving host names to their IP addresses – are sent to the configured DNS servers through the DNS proxy servers.
The DNS proxy feature is integrated in the SMF network function.
How it Works
The DNS proxy feature is integrated in the SMF cluster. For sending the list of host names to resolve the DNS Proxy server, the SMF Client Library calls the smfdnsclnt.DNSLookupRequest() Request. The DNS Proxy server forwards the request to the Open source DNS package for host name to IP address resolution.
Figure 1. DNS Proxy Feature Integration
Call Flows
The following call flow illustrates the communication between the DNS client and the Proxy server.
Figure 2. DNS Client and Proxy Server Communication Call Flow
Configuring the DNS Proxy Feature
This section describes how to configure the DNS proxy feature.
Configuring the DNS proxy feature involves the following steps:
  1. Configuring SMF DNS proxy replica
  2. Configuring SMF DNS proxy
Configuring SMF DNS Proxy Replica
Use the following configuration to configure the SMF DNS proxy replica.
configure
   k8 smf profile dns-proxy no-of-replicas integer
   commit
   end
NOTES:
  • k8 smf profile dns-proxy no-of-replicas integer : Specifies the number of replicas of the DNS proxy pod.
  • commit : Commits the configuration.
Use the following configuration to configure the SMF DNS proxy feature.
configure
   profile dns-proxy
      timeout integer
      query-type { ipv4v6 | ipv4 | ipv6 }
      servers string
      ip string
      port integer
      priority integer
      protocol { tcp | udp }
      commit
NOTES:
  • profile dns-proxy – Enters the DNS Proxy Configuration mode.
  • timeoutinteger – Specifies the client timeout value.
  • query-type – Specifies the DNS query type.
  • servers string – Specifies the name of the DNS server. For example, serv1.
  • ip string – Specifies the IP address of the DNS server.
  • port integer – Specifies the priority of the DNS server.
  • protocol – Specifies the protocol of the DNS server.
  • commit – Commits the configuration.
The following is an example configuration where two DNS servers – serv1 and serv2 – are configured:
show running-config profile dns-proxy profile1
   query-type ipv4
   timeout 5
   servers serv1
   ip 10.105.227.227
   port 53
   protocol tcp
   priority 1
   exit
      servers serv2
      ip 10.105.227.228
      port 20
      protocol udp
      priority 2
      exit
exit
