Deploying and Configuring SMF through Ops Center
Summary Data
Table 1. Summary Data
Applicable Product(s) or Functional Area SMF
Applicable Platform(s) SMI
Feature Default Setting Disabled - Configuration Required
Related Changes in this Release Not Applicable
Related Documentation Not Applicable
Revision History
Table 2. Revision History
Revision Details Release
First introduced. Pre-2020.02.0
Feature Description
The SMF deployment and configuration procedure involves deploying the SMF through the Subscriber Microservices Infrastructure (SMI) Cluster Deployer and configuring the settings or customizations through the SMF Operations (Ops) Center. The Ops Center is based on the ConfD CLI. The SMF configuration includes the NRF profile data configuration and the externally visible IP addresses and ports.
SMF Ops Center
The Ops Center is a system-level infrastructure that provides the following functionality:
  • A user interface to trigger a deployment of microservices with the flexibility of providing variable helm chart parameters to control the scale and properties of Kubernetes objects (deployment, pod, services, and so on) associated with the deployment.
  • A user interface to push application-specific configuration to one or more microservices through Kubernetes configuration maps.
  • A user interface to issue application-specific execution commands (such as show and clear commands). These commands:
    • Invoke some APIs in application-specific pods
    • Display the information returned on the user interface application
The following screenshot is a sample of the web-based command line interface presented to the user.
Figure 1. Web-based CLI of Ops Center
The SMF Ops Center allows you to configure the features such as licensing, SMF engine, REST Endpoint, and CDL.
Prerequisites
Before deploying SMF on the SMI layer:
  • Ensure that all the virtual network functions (VNFs) are deployed.
  • Run the SMI synchronization operation for the SMF Ops Center and Cloud Native Common Execution Environment (CN-CEE)
Deploying and Accessing SMF
This section describes how to deploy SMF and access the SMF Ops Center.
Deploying SMF
The SMI platform is responsible for deploying and managing the Cloud Native 5G SMF application and other network functions.
For deploying SMF Ops Center on a vCenter environment, see Deploying and Upgrading the Product section in the UCC SMI Cluster Deployer Operations Guide.
For deploying SMF Ops Center on a OpenStack environment, see UAME-based VNF Deployment section in the UAME-based 4G and 5G VNF Deployment Automation Guide, Release 6.9
Accessing the SMF Ops Center
You can connect to the SMF Ops Center through SSH or the web-based CLI console.
  • SSH:
    ssh admin@ops_center_pod_ip -p 2024
  • Web-based console:
    1. Log in to the Kubernetes master node.
    2. Run the following command:
      kubectl get ingress <namespace>
      The available ingress connections get listed.
    3. Select the appropriate ingress and access the SMF Ops Center.
    4. Access the following URL from your web browser:
      cli.<namespace>-ops-center.<ip_address>.nip.io
By default, the Day 0 configuration is loaded into the SMF.
Day 0 Configuration
To view the Day 0 configuration, run the following command.
show running-config
The following is a sample Day 0 configuration:
root@smf-cluster# ssh -p 2024 admin@$(kubectl get svc -n smf-smf --no-headers | grep smf-ops-center| grep 2024 |awk '{print $3}')
admin@1.1.1.1's password:
Welcome to the CLI
admin connected from 2.2.2.2 using ssh on ops-center-smf-smf-ops-center-76bbc7f4df-rkrff
product smf# show running-config
helm default-repository base-repos
helm repository base-repos
url
https://engci-maven-master.cisco.com/artifactory/smi-fuse-internal-snapshot/mobile-cnat-smf/smf-products/master/
exit
k8s namespace smf-smf
k8s registry dockerhub.cisco.com/smi-fuse-docker-internal
k8s single-node false
k8s use-volume-claims false
k8s ingress-host-name 1.1.1.2.nip.io
aaa authentication users user admin
 uid        117
 gid        117
 password   $1$fvlWGa/b$GW6OyeqG77lQ.Xu/qcbgu.
 ssh_keydir /tmp/admin/.ssh
 homedir    /tmp/admin
exit
aaa ios level 0
 prompt "\h> "
exit
aaa ios level 15
 prompt "\h# "
exit
aaa ios privilege exec
 level 0
  command action
  exit
  command autowizard
  exit
  command enable
  exit
  command exit
  exit
  command help
  exit
  command startup
  exit
 exit
 level 15
  command configure
  exit
 exit
exit
nacm write-default deny
nacm groups group LI
 user-name [ liadmin ]
exit
nacm groups group admin
 user-name [ admin ]
exit
nacm rule-list admin
 group [ admin ]
 rule li-deny-tap
  module-name       lawful-intercept
  path              /lawful-intercept
  access-operations *
  action            deny
 exit
 rule li-deny-clear
  module-name       tailf-mobile-smf
  path              /clear/lawful-intercept
  access-operations *
  action            deny
 exit
 rule any-access
  action permit
 exit
exit
nacm rule-list confd-api-manager
 group [ confd-api-manager ]
 rule any-access
  action permit
 exit
exit
nacm rule-list lawful-intercept
 group [ LI ]
 rule li-accept-tap
  access-operations *
  action            permit
 exit
 rule li-accept-clear
  access-operations *
  action            permit
 exit
exit
nacm rule-list any-group
 group [ * ]
 rule li-deny-tap
  access-operations *
  action            deny
 exit
 rule li-deny-clear
  access-operations *
  action            deny
 exit
exit
SMF Service Configuration
The SMF service requires the basic configuration to process PDU Session Management API calls.
Configuring SMF
The SMF configuration is provided using the Ops Center infrastructure.
The following is a sample SMF configuration:
smf-settings base-url-nrf http://10.81.71.223:8082/NRF
 smf-settings base-url-amf http://10.81.71.223:8090
 smf-settings base-url-udm http://10.81.71.224:8099
 smf-settings upf-ip-addr 10.81.71.224
 smf-settings n4-peer-addr 10.81.71.224
 smf-settings n4-peer-port 8809
 smf-settings datastore-endpoint datastore-ep-smf:8980
 smf-settings redis-endpoint redis-primary:6379
 smf-settings rest-ep no-of-replicas 1
 smf-settings rest-ep external-ip [ 10.81.71.224 ]
 smf-settings service no-of-replicas 1
 smf-settings upmgmt no-of-replicas 1
 smf-settings protocol no-of-replicas 1
 smf-settings protocol external-ip [ 10.81.71.228 ]
The following table describes the supported SMF commands:
Table 3. Supported SMF Commands
No.
Configuration
Description
smf-services service_name
Configures a new SMF service. Entering this command results in a sub command mode. service_name is the name of the SMF service.
smf-name node_name
Specifies the NF name that is sent to the NRF during the SMF registration. This is a command in the smf-services mode.
http-endpoint base-url url
Configures the base endpoint URL to be sent in the NRF registration of the SMF. This is a command in the smf-services mode.
dnn dnn_name
Specifies the SMF-served DNN name. This is sent to the NRF during the SMF registration. This is a command in the smf-services mode.
slices name slice_name sdt sdt_value sst sst_value
Specifies the slice information to which the SMF belongs. This includes the slice type (sst) and slice descriptor (sdt). This is sent to the NRF during the SMF registration. This is a command in the smf-services mode.
6
smf-settings base-url-nrf nrf_url
smf-settings base-url-amf amf_url
smf-settings base-url-pcf pcf_url
smf-settings base-url-udm udm_url
smf-settings rest-ep no-of-replicas num_replicas
Specifies the URL for the SBI interface towards the NRF, UDM, AMF, and PCF. These configurations are used when the nodes are not discovered through the NRF discovery procedure.
Specifies the number of replicas for the different microservices of the SMF.
7
smf-settings upf-ip-addr upf_ip_address
smf-settings n4-peer-addr upf_ip_address
smf-settings n4-peer-port upf_port
Specifies the peer UPF IP address and port configuration.
8
smf-settings n4-addr pfcp_intf_address
Specifies the N4 interface IP address of the SMF towards the peer UPF.
9
smf-settings datastore-endpoint datastore_endpoint
smf-settings redis-endpoint redis_store_endpoint
Specifies the endpoints for the mongodb and redis data stores.
smf-settings service no-of-replicas num_replicas
smf-settings upmgmt no-of-replicas num_replicas
smf-settings protocol no-of-replicas num_replicas
11
smf-settings rest-ep external-ip [ restep_external_ip ]
smf-settings protocol external-ip [ smfprot_external_IP ]
Specifies the service IP to be exposed for the rest-ep and smf-protocol services.
12
ue-pool ipv4_address
Specifies the IP pool to assign the IPv4 address in the CIDR notation to the UE session.
Contact your Cisco Account representative for the corresponding yang and render.yaml files.
Loading Day 1 Configuration
To load the Day 1 configuration for SMF, run the following command:
ssh admin@ops_center_pod_ip -p 2024  < Day1config.cli
Note
The Day1config.cli file contains the necessary parameters required for the Day 1 configuration.
Alternatively, you can copy the configuration and paste it in the SMF Ops Center CLI to load the Day 1 configuration.
configure
  <Paste the Day 1 configuration here>
  commit
  exit
A sample Day1config.cli file, which contains the Day 1 configuration for SMF is shown below.
Day1config.cli
The following is a sample Day1config.cli file, which contains the Day 1 configuration for the SMF.
config
ipam
 source local
 address-pool ipv6
  vrf-name ISP
  tags
   dnn intershat
  exit
  ipv6
   prefix-ranges
    prefix-range 2001:4870:e00b:1500:: length 56
   exit
  exit
 exit
 address-pool poolv4
  vrf-name ISP
  tags
   dnn intershat
  exit
  ipv4
   split-size
    per-cache 1024
    per-dp    256
   exit
   address-range 0.0.0.1 0.0.0.254
  exit
 exit
exit
group nf-mgmt NFMGMT1
 nrf-mgmt-group MGMT
 locality       LOC1
exit
group nrf discovery udmdiscovery
 service type nrf nnrf-disc
  endpoint-profile epprof
   capacity   10
   priority   1
   uri-scheme http
   version
    uri-version v1
     full-version 1.1.1.[1]
    exit
   exit
   endpoint-name endpointName
    priority 1
    capacity 100
    primary ip-address ipv4 3.3.3.3
    primary ip-address port 8082
   exit
  exit
 exit
exit
group nrf mgmt MGMT
 service type nrf nnrf-nfm
  endpoint-profile mgmt-1
   priority   1
   uri-scheme http
   endpoint-name mgmt-1
    secondary ip-address ipv4 3.3.3.3
    secondary ip-address port 8083
    tertiary ip-address ipv4 3.3.3.3
    tertiary ip-address port 8084
   exit
  exit
 exit
exit
cdl node-type smf-cdl
cdl zookeeper replica 2
cdl kafka replica 2
etcd replicas 1
endpoint nodemgr
exit
endpoint gtp
 replicas 1
 vip-ip 4.4.4.4
exit
endpoint pfcp
 replicas 1
 nodes    2
exit
endpoint service
 replicas 1
 nodes    1
exit
endpoint protocol
 replicas 1
 nodes    2
 vip-ip 4.4.4.4
exit
endpoint sbi
 replicas 1
 nodes    2
 vip-ip 4.4.4.4
 interface nrf
  loopbackPort 7005
  vip-ip 20.20.20.5 vip-port 9005
 exit
 interface n7
  loopbackPort 7001
  vip-ip 20.20.20.1 vip-port 9001
 exit
 interface n10
  loopbackPort 7004
  vip-ip 20.20.20.4 vip-port 9004
 exit
 interface n40
  loopbackPort 7003
  vip-ip 20.20.20.3 vip-port 9003
 exit
exit
logging level application trace
logging level transaction trace
logging level tracing off
logging name infra.config.core level application debug
logging name infra.config.core level transaction warn
logging name infra.config.core level tracing warn
logging name infra.resource_monitor.core level application warn
logging name infra.resource_monitor.core level transaction warn
deployment
 app-name     SMF
 cluster-name Local
 dc-name      DC
 model        small
exit
k8 label protocol-layer key smi.cisco.com/node-type value smf-proto
exit
k8 label service-layer key vm-type value smf-svc
exit
k8 label cdl-layer key smi.cisco.com/node-type value smf-cdl
exit
k8 label oam-layer key smi.cisco.com/node-type value oam
exit
helm default-repository smf
helm repository smf
 url https://engci-maven-master.cisco.com/artifactory/smi-fuse-internal-snapshot/mobile-cnat-smf/smf-products/master/
exit
helm repository smf-stage
 url https://engci-maven-master.cisco.com/artifactory/smi-fuse-internal-snapshot/mobile-cnat-smf/smf-products/dev-smf-stage/
exit
k8s namespace     smf
k8s ingress-host-name 1.1.1.1.nip.io
profile dnn intershat
 dns primary ipv4 11.11.1.1
 dns primary ipv6 66:66:1::aa
 dns secondary ipv4 22.22.2.2
 dns secondary ipv6 66:66:2::bb
 network-element-profiles chf chf1
 network-element-profiles amf amf1
 network-element-profiles pcf pcf1
 network-element-profiles udm udm1
 dnn starent.com network-function-list [ upf ]
 charging-profile chgprf1
 virtual-mac      b6:6d:47:47:47:47
 pcscf-profile    pcscf1
 ssc-mode 1
 session type IPV4 allowed [ IPV4V6 ]
 upf apn cisco.com
exit
profile dnn profDnn1
 dnn cisco.com network-function-list [ chf pcf udm upf ]
 ssc-mode 1
 session type IPV4
exit
profile dnn profDnn2
 dnn cisco.com network-function-list [ chf pcf rmgr udm upf ]
 ssc-mode 1
 session type IPV4
exit
profile charging chgprf1
 method                  [ offline ]
 limit volume 20
 limit duration 60
 tight-interworking-mode true
 reporting-level online rating-group
 reporting-level offline service-id
exit
profile pcscf pcscf1
 v4-list
  precedence 3
   primrary 3.3.3.1
   secondary 3.3.3.2
  exit
  precedence 5
   primrary 5.5.5.1
   secondary 5.5.5.2
  exit
  precedence 7
   primrary 7.7.7.1
   secondary 7.7.7.2
  exit
 exit
 v6-list
  precedence 3
   primrary 33:33::1
   secondary 33:33::2
  exit
  precedence 5
   primrary 55:55::1
   secondary 55:55::2
  exit
 exit
 v4v6-list
  precedence 3
   primrary ipv4 46.46.33.1
   primrary ipv6 46:46:33::1
   secondary ipv4 46.46.33.2
   secondary ipv6 46:46:33::2
  exit
  precedence 5
   primrary ipv4 46.46.55.1
   primrary ipv6 46:46:55::1
   secondary ipv4 46.46.55.2
   secondary ipv6 46:46:55::2
  exit
  precedence 7
   primrary ipv4 46.46.77.1
   primrary ipv6 46:46:77::1
   secondary ipv4 46.46.77.2
   secondary ipv6 46:46:77::2
  exit
 exit
exit
profile charging-characteristics 1
exit
profile icmpv6 icmpprf1
 options virtual-mac b6:6d:57:45:45:45
exit
profile smf smf1
 locality      LOC1
 bind-address ipv4 4.4.4.4
 bind-port     8090
 fqdn          5.5.5.5
 allowed-nssai [ slice1 slice2 ]
 plmn-id mcc 123
 plmn-id mnc 456
 service name nsmf-pdu
  type               pdu-session
  schema             http
  version            1.Rn.0.0
  http-endpoint base-url http://smf-service
  icmpv6-profile     icmpprf1
  compliance-profile dec18
  access-profile     access1
  policy subscriber polSub
 exit
exit
profile compliance dec18
 service nsmf-pdusession
  version uri v1
  version full 1.0.0
  version spec 15.2.0
 exit
 service namf-comm
  version uri v1
  version full 1.0.0
  version spec 15.2.0
 exit
 service n1
  version uri v1
  version full 1.0.0
  version spec 15.2.0
 exit
 service n2
  version uri v1
  version full 1.0.0
  version spec 15.2.0
 exit
 service nudm-sdm
  version uri v1
  version full 1.0.0
  version spec 15.2.1
 exit
 service nudm-uecm
  version uri v1
  version full 1.0.0
  version spec 15.2.1
 exit
 service nnrf-disc
  version uri v1
  version full 1.0.0
  version spec 15.2.0
 exit
 service nnrf-nfm
  version uri v1
  version full 1.0.0
  version spec 15.2.0
 exit
 service npcf-smpolicycontrol
  version uri v1
  version full 1.0.0
  version spec 15.2.0
 exit
 service nchf-convergedcharging
  version uri v2
  version full 1.0.0
  version spec 15.2.1
 exit
exit
profile network-element amf amf1
 nf-client-profile        amfP1
 failure-handling-profile FH3
 query-params [ dnn ]
exit
profile network-element pcf pcf1
 nf-client-profile        pcfP1
 failure-handling-profile FH1
 rulebase-prefix          cbn#
 predefined-rule-prefix   crn#
exit
profile network-element udm udm1
 nf-client-profile        udmP1
exit
profile network-element upf upf1
 n4-peer-address ipv4 6.6.6.6
 n4-peer-port 8805
 keepalive    60
 dnn-list     [ dnn1 intershat starent ]
exit
profile network-element chf chf1
 nf-client-profile                chfP1
 failure-handling-profile         FH2
 nf-client-profile-offline        CP2
 failure-handling-profile-offline FH2
exit
profile qos abc
 ambr ul "250 Kbps"
 ambr dl "500 Kbps"
 qi5      7
 arp priority-level 14
 arp preempt-cap NOT_PREEMPT
 arp preempt-vuln PREEMPTABLE
 priority 120
 max data-burst 2000
 dscp-map qi5 2 arp-priority-level 3 uplink user-datagram dscp-marking 0x1c
 dscp-map qi5 2 arp-priority-level 3 downlink user-datagram dscp-marking 0x1a encsp-header dscp-marking 0x1b
 dscp-map qi5 3 arp-priority-level 3 uplink user-datagram dscp-marking 0x4
 dscp-map qi5 3 arp-priority-level 3 downlink user-datagram dscp-marking 0x3 encsp-header copy-inner
exit
profile access access1
 eps-fallback cbr delay 500 max-retry 10 timeout 3
 n26 idft enable timeout 15
 n2 idft enable timeout 15
exit
profile nf-client nf-type udm
 udm-profile udmP1
  locality LOC1
   priority 30
   service name type nudm-sdm
    endpoint-profile EP1
     capacity   30
     uri-scheme http
     endpoint-name EP1
      primary ip-address port 9007
     exit
    exit
   exit
   service name type nudm-uecm
     capacity   30
     uri-scheme http
     endpoint-name EP1
      primary ip-address port 9001
     exit
    exit
   exit
  exit
 exit
exit
profile nf-client nf-type pcf
 pcf-profile pcfP1
  locality LOC1
   priority 30
   service name type npcf-am-policy-control
     capacity   30
     uri-scheme http
     endpoint-name EP1
      priority 50
      primary ip-address port 9003
     exit
    exit
   exit
   service name type npcf-smpolicycontrol
     capacity   30
     uri-scheme http
     endpoint-name EP1
      priority 5
     exit
     endpoint-name realPCF
      priority 10
      primary ip-address ipv4 7.7.7.7
      primary ip-address port 9082
     exit
    exit
   exit
  exit
 exit
exit
profile nf-client nf-type amf
 amf-profile amfP1
  locality LOC1
   priority 10
   service name type namf-comm
     capacity   20
     uri-scheme http
     endpoint-name EP1
      priority 30
      primary ip-address port 9002
     exit
    exit
   exit
  exit
 exit
exit
profile nf-client nf-type chf
 chf-profile CP2
  locality LOC1
   priority 31
   service name type nchf-convergedcharging
     capacity   30
     uri-scheme http
     version
      uri-version v2
      exit
     exit
     endpoint-name EP1
      priority 56
      primary ip-address port 9906
     exit
    exit
   exit
  exit
 exit
 chf-profile chfP1
  locality LOC1
   priority 10
     capacity   30
     uri-scheme http
     version
      uri-version v2
      exit
     exit
     endpoint-name EP1
      priority 50
      primary ip-address port 9904
     exit
     endpoint-name EP2
      priority 80
      primary ip-address port 9905
     exit
    exit
   exit
  exit
 exit
exit
profile nf-pair nf-type UDM
 locality client LOC1
 locality geo-server GEO
exit
profile nf-pair nf-type AMF
exit
profile nf-pair nf-type PCF
exit
profile nf-pair nf-type UPF
 nrf-discovery-group udmdiscovery
 locality preferred-server LOC1
exit
profile nf-pair nf-type CHF
exit
profile nf-client-failure nf-type chf
 profile failure-handling FH2
   message type ChfConvergedchargingCreate
    status-code httpv2 0
     action continue
    exit
   exit
   message type ChfConvergedchargingUpdate
     action continue
    exit
   exit
  exit
 exit
exit
 precedence 1
  sst              01
  sdt              ABcd01
  serving-plmn mcc 123
  serving-plmn mnc 456
  supi-start-range 100000000000001
  supi-stop-range  999999999999999
  gpsi-start-range 1000000000
  gpsi-stop-range  9999999999
  operator-policy  opPol1
 exit
exit
policy operator opPol1
 policy dnn opPolDnn1
exit
policy dnn dnnPol1
 profile default
 dnn starent profile abc.com
exit
 dnn intershat profile intershat
 dnn intershat1 profile profDnn1
exit
policy dnn polDnn
 profile default
 dnn intershat2 profile profDnn2
exit
nssai name slice1
 sst 01
 sdt ABcd01
 dnn [ intershat ]
exit
nssai name slice2
 sst 02
 sdt 000003
 dnn [ cisco.com ]
exit
active-charging service acs1
 packet-filter pkt1
  ip local-port range 2 to 23
  ip protocol = 23
  ip remote-address = 10.10.10.0/24
  ip remote-port range 12 to 34
  ip tos-traffic-class = 23 mask = 23
  priority 23
 exit
 packet-filter pkt2
  direction uplink
  ip local-port = 100
  ip protocol = 100
  ip remote-address = 1.1.1.1/32
  ip remote-port = 140
  priority  100
 exit
 packet-filter pkt3
  direction downlink
  ip local-port = 111
  ip protocol = 111
  ip remote-address = 2.2.2.2/31
  ip remote-port = 111
  priority  111
 exit
 charging-action ca1
  allocation-retention-priority 12 pci NOT_PREEMPT pvi NOT_PREEMPTABLE
  flow limit-for-bandwidth direction uplink peak-data-rate 1000000 peak-burst-size 100 violate-action discard committedDataRate 2000000 committed-burst-size 100 exceed-action discard
  flow limit-for-bandwidth direction downlink peak-data-rate 2000000 peak-burst-size 100 violate-action discard committedDataRate 3000000 committed-burst-size 100 exceed-action discard
  qos-class-identifier 3
  tft-notify-ue
  tos af11
  tft packet-filter pkt1
 exit
 charging-action ca10
  flow limit-for-bandwidth direction uplink peak-data-rate 2000000000 peak-burst-size 100 violate-action discard
  flow limit-for-bandwidth direction downlink peak-data-rate 3000000000 peak-burst-size 100 violate-action discard
  tos af11
 exit
 charging-action ca11
 exit
 charging-action ca12
  flow limit-for-bandwidth direction uplink peak-data-rate 2000000 peak-burst-size 100 violate-action discard
  flow limit-for-bandwidth direction downlink peak-data-rate 3000000 peak-burst-size 100 violate-action discard
 exit
 charging-action ca13
 exit
 charging-action ca2
  allocation-retention-priority 13 pci NOT_PREEMPT pvi NOT_PREEMPTABLE
  flow limit-for-bandwidth direction uplink peak-data-rate 2000000000 peak-burst-size 100 violate-action discard committedDataRate 3000000000 committed-burst-size 100 exceed-action discard
  flow limit-for-bandwidth direction downlink peak-data-rate 3000000000 peak-burst-size 100 violate-action discard committedDataRate 4000000000 committed-burst-size 100 exceed-action discard
  qos-class-identifier 2
  tft-notify-ue
  tos af11
  tft packet-filter pkt2
 exit
 charging-action ca20
  flow limit-for-bandwidth direction downlink peak-data-rate 1000000 peak-burst-size 100 violate-action discard
 exit
 charging-action ca21
 exit
 charging-action ca22
 exit
 charging-action ca23
 exit
 charging-action ca3
  allocation-retention-priority 14 pci NOT_PREEMPT pvi NOT_PREEMPTABLE
  flow limit-for-bandwidth direction uplink peak-data-rate 2000000 peak-burst-size 100 violate-action discard committedDataRate 1000000 committed-burst-size 100 exceed-action discard
  flow limit-for-bandwidth direction downlink peak-data-rate 4000000 peak-burst-size 100 violate-action discard committedDataRate 3000000 committed-burst-size 100 exceed-action discard
  qos-class-identifier 1
  tft-notify-ue
  tos af11
  tft packet-filter pkt3
 exit
 charging-action ca4
  allocation-retention-priority 11 pci NOT_PREEMPT pvi NOT_PREEMPTABLE
  flow limit-for-bandwidth direction uplink peak-data-rate 2000000 peak-burst-size 100 violate-action discard committedDataRate 3000000 committed-burst-size 100 exceed-action discard
  flow limit-for-bandwidth direction downlink peak-data-rate 4000000 peak-burst-size 100 violate-action discard committedDataRate 4000000 committed-burst-size 100 exceed-action discard
  qos-class-identifier 4
  tft-notify-ue
  tos af11
 exit
 charging-action ca5
  tft-notify-ue
  tos af11
 exit
 charging-action ca6
  tft-notify-ue
  tos af11
 exit
 charging-action ca7
  allocation-retention-priority 1 pci NOT_PREEMPT pvi NOT_PREEMPTABLE
  flow limit-for-bandwidth direction downlink peak-data-rate 400000 peak-burst-size 100 violate-action discard
  qos-class-identifier 7
  tft-notify-ue
  tos af11
 exit
 charging-action caGyGz
  billing-action egcdr
  cca charging credit rating-group 102
  content-id         102
  service-identifier 202
 exit
 charging-action caOffline
  content-id         100
  service-identifier 200
 exit
 charging-action caOffline1
  content-id         11
  service-identifier 21
 exit
 charging-action caOffline2
  content-id         12
  service-identifier 22
 exit
 charging-action caOffline3
  content-id         13
  service-identifier 23
 exit
 charging-action caOffline4
  content-id 40
 exit
 charging-action caOfflineOnline
  cca charging credit
  content-id         30
  service-identifier 60
 exit
 charging-action caOfflineOnline1
  cca charging credit
  content-id         31
  service-identifier 61
 exit
 charging-action caOnline
  cca charging credit rating-group 100
  content-id         100
 exit
 charging-action caOnline1
  cca charging credit rating-group 101
  content-id         101
  service-identifier 201
 exit
 charging-action caOnline2
  cca charging credit
  content-id         102
 exit
 charging-action caOnline3
  cca charging credit
  content-id         103
  service-identifier 203
 exit
 charging-action caOnline4
  cca charging credit
  content-id 110
 exit
 charging-action nocharging
 exit
 rulebase cbn#spp-tmobile
  action priority 1 ruledef crn#test_1 charging-action ca1
  action priority 2 ruledef crn#test_2 charging-action ca2
 exit
 rulebase rba1
  action priority 1 dynamic-only ruledef rda1 charging-action ca1 description myrule1
  action priority 2 dynamic-only ruledef rda2 charging-action ca2 description myrule2
  action priority 3 dynamic-only ruledef rda3 charging-action ca3 description myrule3
 exit
 rulebase rba2
  action priority 10 ruledef rda10 charging-action ca10 description myrule10
  action priority 11 ruledef rda11 charging-action ca11 description myrule11
  action priority 12 dynamic-only ruledef rda12 charging-action ca12 description myrule12
  action priority 13 dynamic-only ruledef rda13 charging-action ca13 description myrule13
 exit
 rulebase rba3
  action priority 20 ruledef rda20 charging-action ca20 description myrule20
  action priority 21 ruledef rda21 charging-action ca21 description myrule21
  action priority 22 dynamic-only ruledef rda22 charging-action ca22 description myrule22
  action priority 23 dynamic-only ruledef rda23 charging-action ca23 description myrule23
 exit
 rulebase rba4
  action priority 30 ruledef rda3 charging-action ca3 description myrule3
  action priority 31 dynamic-only ruledef rda3 charging-action ca3 description myrule3
 exit
 rulebase rba5
  action priority 50 dynamic-only ruledef rda50 charging-action ca4 description myrule50
  action priority 51 dynamic-only ruledef rda51 charging-action ca5 description myrule51
  action priority 52 dynamic-only ruledef rda52 charging-action ca6 description myrule52
 exit
 rulebase rba6
  action priority 60 dynamic-only ruledef rda60 charging-action ca1 description myrule60
  action priority 61 dynamic-only ruledef rda61 charging-action ca1 description myrule61
  action priority 62 dynamic-only ruledef rda62 charging-action ca1 description myrule62
 exit
 rulebase rba7
  action priority 50 ruledef rda50 charging-action ca4 description myrule50
  action priority 51 ruledef rda51 charging-action ca5 description myrule51
  action priority 52 ruledef rda52 charging-action ca6 description myrule52
 exit
 rulebase rba8
  action priority 60 ruledef rda60 charging-action ca1 description myrule60
  action priority 61 ruledef rda61 charging-action ca1 description myrule61
  action priority 62 ruledef rda62 charging-action ca1 description myrule62
 exit
 rulebase rbaStatic
  action priority 10 ruledef rda20 charging-action caOffline
 exit
 rulebase rbaStatic-Online
  action priority 20 ruledef rdaStatic charging-action caOnline
 exit
 rulebase rbaStatic1
 exit
 rulebase rba_GyGz
  egcdr threshold volume downlink 100000 uplink 100000
  action priority 20 dynamic-only ruledef rdaPredefined charging-action caGyGz
  action priority 30 ruledef rda20 charging-action caGyGz
 exit
 rulebase rba_charging_StaticDynamic_Offline_Online_mix
  cca diameter requested-service-unit sub-avp volume cc-input-octets 11000 cc-output-octets 12000 cc-total-octets 23000
  credit-control-group onlineoffline
  egcdr threshold interval 100
  egcdr threshold volume downlink 150000 uplink 150000 total 300000
  action priority 20 dynamic-only ruledef rdaPredefined charging-action caOffline1
  action priority 21 dynamic-only ruledef rdaPredefined1 charging-action caOnline1
  action priority 31 ruledef rdaStatic charging-action caOfflineOnline
 exit
 rulebase rba_charging_StaticDynamic_offline
  action priority 30 ruledef rda20 charging-action caOffline
 exit
 rulebase rba_charging_StaticDynamic_online
  action priority 20 ruledef rda20 charging-action caOnline
  action priority 30 dynamic-only ruledef rdaPredefined charging-action caOnline1
 exit
 rulebase rbs1
  action priority 1 ruledef rds1 charging-action ca1 description myrules1
  action priority 2 ruledef rds2 charging-action ca2 description myrules2
 exit
 urr-list urr_smf
  rating-group 10 service-identifier 20 urr-id 1
  rating-group 11 service-identifier 21 urr-id 2
  rating-group 12 service-identifier 22 urr-id 3
  rating-group 13 service-identifier 23 urr-id 4
  rating-group 30 service-identifier 60 urr-id 20
  rating-group 31 service-identifier 61 urr-id 21
  rating-group 100 service-identifier 200 urr-id 5
  rating-group 101 service-identifier 201 urr-id 6
  rating-group 102 service-identifier 202 urr-id 7
  rating-group 103 service-identifier 203 urr-id 8
 exit
 ruledef rda1
  ip server-ip-address = 10.10.10.10
 exit
 ruledef rda10
  ip any-match = TRUE
 exit
 ruledef rda11
  ip any-match = TRUE
 exit
 ruledef rda12
  ip any-match = TRUE
 exit
 ruledef rda13
  ip any-match = TRUE
 exit
 ruledef rda2
  ip server-ip-address = 10.165.161.77/32
 exit
 ruledef rda20
  ip any-match = TRUE
 exit
 ruledef rda21
  ip any-match = TRUE
 exit
 ruledef rda22
  ip any-match = TRUE
 exit
 ruledef rda23
  ip any-match = TRUE
 exit
 ruledef rda3
  ip server-ip-address = 8.8.8.8/28
 exit
 ruledef rda40
  ip any-match = TRUE
 exit
 ruledef rda50
  ip server-ip-address = 50.50.50.50
 exit
 ruledef rda51
  ip server-ip-address = 51.51.51.51
 exit
 ruledef rda52
  ip server-ip-address = 52.52.52.52
 exit
 ruledef rda60
  ip dst-address = 60.60.60.60
 exit
 ruledef rda61
  ip dst-address = 61.61.61.61
 exit
 ruledef rda62
  ip dst-address = 62.62.62.62
 exit
  ip any-match = TRUE
 exit
 ruledef rdaStatic
  ip any-match = TRUE
 exit
 ruledef rdaStatic1
  ip any-match = TRUE
 exit
 ruledef rdaStatic2
  ip any-match = TRUE
 exit
 ruledef rds1
  ip any-match = TRUE
 exit
 ruledef rds2
  ip any-match = TRUE
 exit
 credit-control group onlineoffline
  diameter ignore-service-id true
 exit
exit
apn intershat
 gtpp group group1
 active-charging rulebase rba1
exit
gtpp group group1
 gtpp egcdr service-data-flow threshold interval 60
 gtpp egcdr service-data-flow threshold volume downlink 100000 uplink 100000 total 200000
apn intershat
gtpp group group1
exit
smiuser add-user username liadmin password Cisco@123
smiuser change-password username liadmin current_password Cisco@123 new_password Mitg_123 confirm_password Mitg_123
smiuser add-group groupname LI
smiuser assign-user-group username liadmin group LI
smiuser add-user username liadmin2 password Cisco@123
smiuser change-password username liadmin2 current_password Cisco@123 new_password Mitg_123 confirm_password Mitg_123
smiuser add-group groupname LI2
smiuser assign-user-group username liadmin2 group LI2
smiuser add-user username liadmin3 password Cisco@123
smiuser change-password username liadmin3 current_password Cisco@123 new_password Mitg_123 confirm_password Mitg_123
smiuser add-group groupname LI3
smiuser assign-user-group username liadmin3 group LI3
nacm groups group LI2
user-name [ liadmin2 ]
exit
nacm groups group LI3
user-name [ liadmin3 ]
exit
group [ LI LI2 LI3 ]
commit
end
config
system mode running
commit
end
exit
