5G SMF Serviceability CLI Enhancements
Summary Data
Table 1. Summary Data
Applicable Product(s) or FunctionalArea
SMF
Applicable Platform(s)
SMI
Feature Default Setting
Enabled – Always-on
Related Changes in this Release
Not Applicable
Related Documentation
Not Applicable
Revision History
Table 2. Revision History
Revision Details
Release
First introduced.
2020.02.0
Feature Description
This chapter describes serviceability CLI enhancements to display the information about the deployed pods.
show subscriber pei <imei>
Table 3. show subscriber pei <imei>
Field
Description
policy
Specifies policy information.
ipv4-addr
Specifies IPv4 pool name.
dnn
Specifies DNN value.
pcf
Specifies PCF Address.
rat
Specifies RAT Type - nr/e-utran/wlan information.
connectivity
Specifies connectivity 4g/5g
ipv4-range
Specifies IPv4 address range.
chf
Specifies CHF address.
pei
Specifies Permanent Equipment Identifier.
udm
Specifies the UDM address.
upfEpKey
Specifies the UPF address EP key information.
ipv6-pfx
Specifies the IPv6 prefix information.
ipv6-pool
Specifies IPv6 Pool name.
chfGroupId
Specifies the CHF address group ID information.
gpsi
Specifies Generic Public Subscription Identifier.
pcfGroupId
Specifies PCF Address group ID.
upf
Specifies UPF Address.
ipv4-pool
Specifies IPv4 Pool name.
ipv6-range
Specifies IPv4 Address-Range.
amf
Specifies AMF address.
supi
Specify SUPI value.
access
Specifies access information.
show subscriber <gpsi>
Table 4. show subscriber pei <imei>
Field
Description
policy
ipv4-addr
dnn
pcf
rat
connectivity
ipv4-range
chf
pei
udm
upfEpKey
ipv6-pfx
ipv6-pool
chfGroupId
gpsi
pcfGroupId
upf
ipv4-pool
ipv6-range
amf
supi
Specify SUPI value.
access
show endpoint info
Table 5. show endpoint info
Field
Description
endpoint
Specifies the Name of the endpoint.
address
Specifies Host and Port of endpoint.
type
Specifies type of endpoint.
status
Specifies current Status of endpoint.
interface
Specifies Interface name of endpoint.
internal
Specifies type of endpoint (Internal/External).
start Time
Specifies Start time of endpoint.
stop Time
Specifies Stop time of endpoint.
