Load-based Selection of UPF
Summary Data
Table 1. Summary Data
Applicable Product(s) or Functional Area
SMF
Applicable Platform(s)
SMI
Feature Default Setting
Enabled – Always-on
Related Changes in this Release
Not Applicable
Related Documentation
Not Applicable
Revision History
Table 2. Revision History
Revision Details
Release
First introduced.
Pre-2020.02.0
Feature Description
Load based User Plane Function (UPF) selection in SMF distributes calls among active UPFs associated with SMF.
SMF Support for Load Control Feature
3GPP specifies Load Control feature as optional feature over N4 reference points. This enables UPF to send its load information to CP functions. To support Load Control feature, SMF can receive UPF provided Load Control information in the following PFCP messages:
  • Session Establishment Response
  • Session Modification Response
  • Session Deletion Response
  • Session Report Request
Load Control procedure details are mentioned in 3GPP TS 29.244 v14.0.0 Release 14 Section 6.2.3 and SMF adheres to the CP functionality.
Load Based UPF Selection
SMF stores the load information provided by UPF and uses it in selecting the UPF for new sessions being established. SMF selects the less loaded UPF among the candidate (DNN based) active UPFs.
This feature considers priority and capacity configured statically against each UPF. In cases where UPF does not send the load information statically, configured capacity is considered while selecting the UPFs.
Standards Compliance
The feature complies with the following standards:
  • 3GPP TS 29.244 v14.0.0 Release 14
