About this Guide
This preface describes the 5G Session Management Function Guide, how it is organized and its document conventions.
This guide describes the Cisco Session Management Function (SMF) and includes infrastructure and interfaces, feature descriptions, specification compliance, session flows, configuration instructions, and CLI commands for monitoring and troubleshooting the system.
Conventions Used
The following tables describe the conventions used throughout this documentation.
Notice Type Description
Information Note
Provides information about important features or instructions.
Caution
Alerts you of potential damage to a program, device, or system.
Warning
Alerts you of potential personal injury or fatality. May also alert you of potential electrical hazards.
Typeface Conventions Description
Text represented as a screen display
This typeface represents displays that appear on your terminal screen, for example:
Login:
Text represented as commands
This typeface represents commands that you enter, for example:
show ip access-list
This document always gives the full form of a command in lowercase letters. Commands are not case sensitive.
Text represented as a command variable
This typeface represents a variable that is part of a command, for example:
show card slot_number
slot_number is a variable representing the desired chassis slot number.
Text represented as menu or sub-menu names
This typeface represents menus and sub-menus that you access within a software application, for example:
Click the File menu, then click New
